Fixed leaking rear door vapor barriers (pics) - Page 11 - BMW M5 Forum and M6 Forums
Like Tree6Likes
Old 20th March 2011, 19:38   #101
atiyeh
atiyeh's Avatar
Garage: 2002 Sterling Grey M5
Originally Posted by Frye View Post
With a water bottle.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Perfect. That settles that.
George
2002 Sterling Grey ///M5 - "Lola"
E60 545i SSK + ZHP Nob
Timmay77 Signature Muffler Delete
SLIMM Alcantara Shift Boot
Brushed Alum. Kidneys
Matte Black OEM Diffuser
Matte Black Rear Badge
New OEM Tri-Stiched Wheel
New OEM Door Panels
New OEM E-Brake
New OEM Titanium Trim
New OEM Dash
OEM Euro Tilt / Slide Armrest
OEM Euro Hella Smoked / Red Tails
ICE VXX Angel Eyes
Intravee II w/extras
ValentineOne v1.8 (Hardwired)
Attempted Homicide committed on 12/24/11 by Chevy Truck - Unsuccessful. Story and Pics Here
atiyeh is offline   Reply With Quote
Old 28th March 2011, 03:49   #102
/// dv/dt
/// dv/dt's Avatar
Garage: 2003 E39 M5 silver
Originally Posted by nightkrawler View Post
the main cause of this repair failing is reusing the original vapor seal. after 10yrs these seals become hard and less pliable. the new ones are redesigned as i just got a set yesterday and they're now a tan color opposed to the original black and much softer. use the factory sealant or variant, butyl tape. i fix these at work all the time and always use the 3m window weld with no issues or comebacks. also you want to do this in warm weather or a heated area...
Can anyone help me find the part numbers for the new tan colored barriers?
/// dv/dt is offline   Reply With Quote
Old 28th March 2011, 05:48   #103
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Consult the sticky DIY Guidepost. I can assure you the part# is in the first post of one of them.
Better still, take the opportunity to become more familiar with the "Parts catalog" websites in the sticky FAQ.
RealOEM.com * BMW E39 M5 Sound insulation/anti-drumming rear
Sound insulation/anti-drumming rear BMW 5' E39, M5 (S62)
chowdah is offline   Reply With Quote
The Following User Says Thank You to chowdah For This Useful Post:
/// dv/dt (28th March 2011)
Old 7th May 2011, 02:48   #104
IRISH M5
IRISH M5's Avatar
Garage: 03 M5 LeMans Blue
Sales Feedback: (4)
Thanks Tim.
Tim, many thanks for repairing my vapor seals today. It's always a pleasure to stop by your house and chat. It was nice that Brian stopped by too with yet another wheel configuration!
I hope I got your track juices flowing by watching the Race School in-car videos....
See you at Timmayfest next month.
Richard...
IRISH M5 is offline   Reply With Quote
Old 7th September 2011, 23:16   #105
Redneck M5
Garage: 2002 M5 Imola Red
Originally Posted by emoshun View Post
Has anyone in sunny Cali experienced this problem? Or are the Easterners the lucky ones?
Heck yes I already (did not)fix mine twice and it needs it again.
I used Window Weld tape and carefully removed all the old stuff.
But I didn't use a heat gun. It was really cold that day too. Like about 60 degrees. No wonder it didn't stick
Redneck M5 is offline   Reply With Quote
Old 23rd September 2011, 23:39   #106
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Carp! I drove my car in some SERIOUS rain today and (thinking of this known issue) opened the back door. Saw some drips of water right where the inner door panel meets the painted door. Guess that means I'm afflicted eh?
I don't have any of the sealants at home mentioned here, but I do have re RTV. Would that be out of the question to use if I just found a few 'loose' spots or must it be silicone?
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline   Reply With Quote
Old 28th November 2011, 05:15   #107
HenryHank
HenryHank's Avatar
Garage: 2002 M5 LMB
Ok, my turn for this repair -- I've had a leaky driver's side rear for a year now, and I'm just getting around to figuring out the problem..at least that part is solved here in this thread! (thanks to all contributors).
I have two questions:
1. How much Dow 732 do you need to repair one door? Amazon has a 3 oz tube and a 10 oz cartridge for a caulking gun. Is the 3oz tube enough for one door? Ebay has some 4.7oz tubes available for $9 each which is another option.
2. How long does it take to cure? I'll likely be doing this in the Northeast in December inside a garage.. so it will be 50-60 degrees inside the garage.
Thanks.
HenryHank is offline   Reply With Quote
Old 28th November 2011, 05:33   #108
jfoj
Garage: 2003 M5 Sterling Gray & 2006 330cic (Vert) Silver Gray
I would guess you will need the caulk gun tube if you plan on using this stuff. You will need a 1/4"- 5/16" bead around the entire perimeter of the door seal.
I used 5/16" Window Weld buytl that I ordered from Amazon for about $20? Used a hair dryer and a 2" wide roller to really seal the stuff to the door.
I ended up buy new vapor barriers as I had no idea if they had been cut for a window regulator repair. Mine turned out to be in good shape, but it was easier to install the new ones.
Only issue you need to sort out is if your car has rear airbags. You need to look closely at the rear door panel and see if it has the word Airbag embossed it the rear part of the door panel, if it does, you need the vapor seal with airbags. I think it is actually the cheaper of the 2 vapor barriers.
Another option might be to use the Dow Corning Gutter Sealant that Home Depot and other hardware/home stores sell. This is a cross between an RTV and buytl sealer. Comes in caulk tube for about $5-$7 as I recall?? This stuff takes longer to cure than RTV, but once it cures it is like a buytl/RTV combo?
Only problem about something other than the straight buytl, is if the vapor seal tries to pull away and/or the door panel does no hold the vapor seal tight to the door.
jfoj is online now   Reply With Quote
Old 31st January 2012, 03:06   #109
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
I paid around $17.00 for the roll. It covered 2 doors with some left over.
Just went over the entire thread, great info. What is the part # for this revised OEM tape/sealant/adhesive? I'm about to work on my rear doors.
Old 31st January 2012, 03:29   #110
jfoj
http://www.amazon.com/3M-08620-Window-Weld-Ribbon-Sealer/dp/B0039752R2/ref=pd_sim_sbs_auto_5
I found this smaller diameter round buytl sealer to work very well. Single roll is enough for 2 doors
I then took a hair dryer an heated the vapor buytl then put the vapor barrier on and heated the vapor barrier and then pressed the vapor barrier down very firmly all over where the buytl sealer was. This seemed to really give a good, solid seal overall and made the sealing area much wider.
I decided to order and install new vapor barriers as I did not know if anyone had ever been in my rear door and cut or tore the vapor seals. At the end of the day I kept the original vapor barriers if I ever need them in the future, but I removed all the old buytl, not hard with a plastic putty knife and the hair dryer, then basically had a full new installation.
Rear door vapor seals looks like they are about $30 each? BMW part numbers -
51488230221- Left rear with airbag
51488230222 - Right rear with airbag
I believe the vapor barrier for airbag equipped cars will work in cars without airbags????
The Following User Says Thank You to jfoj For This Useful Post:
bimmerule (31st January 2012)
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
trentmw
Leaking rear main seal = new clutch? R748 E39 M5 and E52 Z8 Discussion 3 20th March 2008 16:36
FS: e39 left rear door vapor barrier SeattleM5 Parts / Other For Sale or Wanted 0 21st January 2008 18:24
Something leaking from around the rear diff... Jon Baker E34 M5 Discussion 10 26th August 2005 19:34
door rattle fixed slowcar E39 M5 and E52 Z8 Discussion 2 4th June 2005 19:58
door rattle fixed slowcar E39 M5 and E52 Z8 Discussion 0 4th June 2005 17:11
