23rd August 2009, 23:32
#1
2000 M5 Lemans Blue
ESS Supercharger
Got a question. I should be receiving my kit next week, however I want to install an intercooller. Does anyone know the dimensions on the intercooller that comes with CA Automotive kit?? Or if anyone knows where to buy one that will fit on the buttom of the front bumper.
Chris K.
2000 M5 Lemans Blue w/ Silverstone Interior
ESS TUNING - VT-550 Supercharger system
KELLENERS - Racing Cats & Exhaust, Full Racing Suspension, Sport Pedals.
HAMANN - Custom Headers, Rear Diffuser, Hamann Front splitters
DINAN - Front & Rear Strut Braces, Camber Plates
QUAFEI DIFF - Custom 3:73 differential 100% LSD
UUC - Short Shifter, Lightweight Flyweel, 280mm Clutch.
VORSTEINER - GTR hood
STOPTECH - 4-Wheel Brake Kit
WHEELS & TIRES - 19" BBS LM w/ Michelin Pilot Sport (255-35/19 Fronts 275-30/19 Rears)
EVO SPORT - Power Pulley Kit
ROQUE ENGINEERING - Tranny Mounts
MISC. - Custom Engine Oil cooler, NavTV w/ DVD, Custom Brake Ducts, K-40 Radar, Z8 Start Button, Intake relocation sensor kit, Nowack Style Air Box Plenum, Custom Clutch Stop.
23rd August 2009, 23:37
#2
Chris K.
RMS sells a reasonably expensive in-plenum air-to-water intercooler that comes with new shorty air horns, an aluminum plenum and plenum cover, and aluminum TB-to-plenum plates, as well as a water pump and a heat exchanger that fits neatly in the lower grill area. That is the setup I am using. You can see pictures of it in all of the Discovery Automotive E39 SC builds on their website. According to AJ of ESS, they have used an FMIC air-to-air setup with the ESS VT550 kit by redirecting the intake off the SC downward. Apparently, there is sufficient room to do so. PM Roy at CA Automotive for the dimensions on the CA kit IC. They may sell it separately, I don't know.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
24th August 2009, 00:19
#3
Alpine White E39 M5
I know this is off topic. But why are so many E39 M5 owners named chris? I can think of 3 off the top of my head. And now the OP is Chris K, im also a Chris K lol.
2003 E55 AMG - Obsidian Black/Black, Eurocharged ECU reflash, 84mm SC pulley, CM30 IC Pump, FTP Heat exchanger, Needswings Dual CAI, Custom exhaust, Forgestar F14's, Lowering links, E63 Spoiler, CF Front lip
2000 BMW M5 - Alpine White/Silverstone Extended Leather/BBS LMs 245.35.19, 285.30.19/Evolve Alpha-N/Tubi Exhaust/AA Intake/Ducts/Dinan Springs - RIP
2001 Yamaha R6 - Yamaha Blue, Yamaha GYT-R Exhaust, Factory Pro +4 Ignition Advance, Factory Pro Jet kit, 03R6 Airbox/Filter, Clear Alternates and fender eliminator, puig windscreen, Yamaha Solo seat, APE CCT
2000 Durango SLT+ - 5.9 V8, 3.92 LSD, 32x11.5 BFG All Terrains, Airaid intake, Hughes F1 Airgap, SCT Tuner, Flowmaster 50 Series, Fully rebuilt 46RE, 2" torsion lift
Glock17 9x19|Vz.58 7.62x39|Mossberg 500
24th August 2009, 00:36
#4
Sold&missed - 2001 M5
chrisboard.com?
2001 ///M5 - SOLD
Eisenmann Sport | Supersprint headers | SuperSprint X-pipe | Ground Control | Stoptech ST-40 front brakes | Powerchip | Rogue 280mm clutch | JB Racing lightweight flywheel | Rogue short shift | Dinan rear Swaybar | OEM 9.5" all around with Star Specs | Cosmo Racing CAI | Opened brake ducts
24th August 2009, 01:58
#5
BMW
Keep in mind the design of the FMIC and ducting is crucial to maintain power. You may end up with way less than 550HP if this is not done properly.
I would recommend staying with the off the shelf VT550 kit if your goal is ~550-580HP. The heat developed from such low boost pressures is minimal and you loose more efficiency by forcing the air through a FMIC setup.
24th August 2009, 04:17
#6
2003 M5 Le Mans Blue
Yes that's true that a low-boost setup doesn't generally require a FMIC, but similar to a turbo setup where the boost pressure sensor can be relocated to downstream of/after the FMIC to compensate for pressure drop through the intercooler, can't you just run a 1-2 psi larger pulley to compensate for the FMIC? I mean since there is probably power to spare from the supercharger unit itself it couldn't hurt right? I've never supercharged a car before so if that's a dumb idea then nevermind
Originally Posted by Greco
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
24th August 2009, 04:21
#7
BMW
Yes, but it will cost engine power to drive the SC faster to compensate for pressure loss. The equation typically does not work in your favor on a low boost setup (less than 7PSI) in normal temperature conditions (->90F)
24th August 2009, 04:32
#8
Oh I think I see what you mean...since the drag on the motor created by the 6 psi pulley is relatively low, it's like adding an additional 17-33% of parasitic drag on the engine to make the additional 1-2 psi to end up with maybe 5% additional power from the slightly cooler air?
#9
01 M5 Black/caramel
Wouldn't water/meth injection take care of the IC issue for heat soak without the need of an IC? Something like the Aquamist 6 setup?
24th August 2009, 04:37
#10
BMW
Yes, absolutely.
Plumbing the nozzle into the cast aluminium discharge elbow is no problem at all.
The Following User Says Thank You to Asbjorn@ESSTuning For This Useful Post:
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
