• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 21st February 2002, 00:59   #1 (permalink)
          MAH
          MAH's Avatar
          Great wheel cleaner!
          All,
          Now we all know how much we love to clean the wheels. I have run across a great product that makes cleaning thr wheels a breeze. The product is Simple Green. Has anyone tried this?
          I'm using this on my chrome wheels and it really removes the dust and dirt and road oil just by spraying it on and hosing it off.
          It even removes the dirt on the inside lip!
          I would like to get your feedback.
          Mark
          MY2001 Imola Red
          Lux. Black Interior
          Painted Calipers,
          Autowerke CAI
          Powerchip Software Upgrade
          Tubi Catback Exhaust
          361RWHP
          425HP and growing!
          MAH is offline
          Old 21st February 2002, 06:47   #2 (permalink)
          tfung
          tfung's Avatar
          I heard that simple green was very corrosive and shouldn't be used that often... with our stock rims, I think it might even eat off the shadowchrome on it.. anyone want to verify?
          US Spec 2001 E39 M5 - LHD
          AC Schnitzer
          Dinan
          3.45 differential
          Others
          Euro Spec 1999 E39 M5 - RHD
          2007 Mercedes E63
          2007 Corvette Z06
          2008 Nissan GTR
          tfung is offline
          Old 21st February 2002, 07:08   #3 (permalink)
          TCM
          TCM's Avatar
          Terence is correct. I beleive that Simple Green is not good for the paint on the wheels. Your wheels are clearcoated, so you need to treat them like the paint on your car. Natural Cleaner (Zymol, P21S, EF) and then give them a coat of wax. I would not think cleaning with Simple Green once would cause a problem but excessive use may hurt your rims.
          T.C.
          '01 Silverstone M5
          SuperSprint:X-pipe
          TCM is offline
          Old 21st February 2002, 07:17   #4 (permalink)
          rennen
          rennen's Avatar
          I use the Castrol Super Clean wheel cleaner. It takes two seconds, and removes all the dirt and dust. Non corrosive too.
          2003 M5 Jet Black/Black sport interior
          2000 M5 Jet Black/ Black sport interior
          2002 X5 3.0
          2002 M3
          2002 M3 Cab.
          2000 Yukon
          1966 427 Cobra S/C
          1966 GT350H
          1966 Hemi Charger
          1969 Corvette
          1966 Austin Healey 3000
          rennen is offline
          Old 21st February 2002, 07:35   #5 (permalink)
          TommyGun
          TommyGun's Avatar
          Send a message via AIM to TommyGun
          FWIW, I have been using Simple Green for the last 12 months on my wheels...probably every 2.5 weeks and have noticed no problems with the finish of the wheel...Works great for me...although you guys did make me go and check the wheels very carefully
          Tommy
          Atlanta
          '01/01 LeMans\LeMans (sold 6/15/03)
          03 TiAg M3 SMGII (latest mistress)
          TommyGun is offline
          Old 21st February 2002, 17:26   #6 (permalink)
          rvacha
          rvacha's Avatar
          I, too, will cast a positive vote for Simple Green. I've been using it for over 4 years on my 540 (2 piece riveted & clear coated) and 1.5 years on my M5. I generally buy the refill "concentrate" and dilute it 50% with water. No paint problems at all. It cuts through grease and grime nicely, takes a little more effort to remove tar spots, and definitely does NOT eliminate the need to apply elbow grease. I clean my wheels with a 3" natural bristle varnish brush (the only fast way to clean a gazillion rivets!). Simple Green also rinses off quickly and easily.
          '03 E53 X5 4.4i Topaz/Sand
          '06 E90 330Xi 6MT Sparkling Graphite/Terra
          '08 E92 M3 6MT Jerez/Speed Cloth/Carbon Leather <-- Evil Twin
          rvacha is offline
          Old 21st February 2002, 17:54   #7 (permalink)
          bmurphy
          bmurphy's Avatar
          If you talk to The Wheel Wizard in Atlanta, or any other wheel refurbishing guru, they will tell you soap and water, same stuff you use on your car, just a different bucket. I would always beware of anything that makes it super easy to clean the wheels other than a little elbow grease. My $.02. Murph
          2001 M5 Carbon Black Sport Interior
          Kelleners Exhaust, Dinan Stage III, Strut Tower Braces, AC Schnitzer Pedals, Powerchip V2 ECU Upgrade, M Technic Air Dam, Stainless Brake Lines, UUC Short Shifter, K&N Filters, Stoptech Big Brake Kit w/ Red Calipers, Powder Coated Matching Rear Calipers, Gruppe M CAI, Mintex Brake Pads, Evosport Underpulleys, Royal Purple Tranny Fluid, BeastPower Rear Sway Brackets, K40 Radar, Formula I Window Film, AC Schnitzer Rear Spoiler, Speedlingerie Custom Bra & Mirror Covers
          bmurphy is offline
          Old 21st February 2002, 18:04   #8 (permalink)
          Dux
          Dux's Avatar
          Murph-meister,
          Have Wheel Wizard tried to cure curb rash on these M5 rims?
          Or is it the same old story?
          Dux is offline
          Old 21st February 2002, 18:24   #9 (permalink)
          Bart Carter
          Bart Carter's Avatar
          BMW's recommendation is Meguiars wheel cleaner (for painted wheels)
          -Bart
          2002 Bluewater/caramel
          Any other car is a compromise
          Bart Carter is offline
          Old 21st February 2002, 18:28   #10 (permalink)
          Dux
          Dux's Avatar
          Are u guy's talking about Simple Greens Degreaser or their Foam Wheel cleaner?
          Dux is offline
          Old 21st February 2002, 19:03   #11 (permalink)
          rvacha
          rvacha's Avatar
          I was talking about the degreaser- never tried the foam
          rvacha is offline
          Old 21st February 2002, 19:13   #12 (permalink)
          bmurphy
          bmurphy's Avatar
          Dux, when you say curb rash, do you mean physical damage to the wheel like abrasion? If so, best bet is to buy a new wheel. I had one wheel fixed by a company in CA and it did not match my others worth a flip, ended up paying for the "fixed" wheel and a new one.
          murph
          bmurphy is offline
          Digg this Post!Add Post to del.icio.us
