NavTweak or Splashscreen experts? HELP? - BMW M5 Forum and M6 Forums
post #1 of 19 Old 21st August 2009, 05:13 AM Thread Starter
Hdhntr23
Hdhntr23's Avatar
Hey guys,
Ive spent the past 2-3 hours reading the NavTweak thread on xoutpost.com NavTweak - Xoutpost.com
I cant seem to sort out a few things, I think Im close but Im getting bleary eyed and frustrated. Ive installed the program and the operating environment, I can open up an update disc in the program. I can see the splash, change the splash to the one I want but I cant for the life of me figure out how to get it back to a new disc.
Ive also copied over all the contents from the update disc I want to use (Thanks Lunker) with the "night vision" to a separate directory on my HDD.
When I go to "File/Save" in NavTweak Im not sure where to put the saved file or what to name it. Then when I try to create an ISO from that saved file I get an error from my ISO creation software.
I have NERO so Im pretty sure I can create an ISO but Im stuck.
Can anyone help?
Theres a virtual beer in it for anyone that can walk me thru this.
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
post #2 of 19 Old 21st August 2009, 05:34 AM
ECB
ECB's Avatar
OK, I did this over a year ago and my memory is fading but here goes. I'm not exactly sure what you've done but to change the wording of the accept screen, I opened NavTweak, open folder V_2, open folder RR, open folder 0101, open folder BMWC01S, open folder app_sw, open navboot, then select Strings, language American, and scroll down to 1/706. Change the text to what you want and then save the navboot file. Then I used UltraISO, navigated to the proper folder and hit F3 (add files) and inserted the modified version of navboot. Saved the image and then burned on a DVD with ImgBurn. Search for board member Dereki. He posted modified splash screens a while back and I just used one of them. I'm not sure how to use your own pic in the splash. Good luck. Hope some of this helps.
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete,
H&R Springs, Dinan 17mm rear sway bar, TCD sway bar brackets, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,BSW Speaker Upgrade & 10" Sub
04 M3 Jet Black/Black Nappa/6 spd
Max PSI Turbo, Supersprint Resonated Sect. 2, Eisenmann Race Muffler
Rogue SSK, H&R springs, Koni Yellows, Squared 18's
ECB is offline
post #3 of 19 Old 21st August 2009, 04:11 PM Thread Starter
Hdhntr23
Hdhntr23's Avatar
Is it just the navboot file that Im bringing over to the disc? Cause if it is, thats where Im getting an error.
Does it go something like this?
Drill to the navboot file in navtweak
Edit the settings the way I want allbeit splash screens or accept screens etc
Save the file back in the directory I drilled into and save it as navboot
Drag all those files from the update disc over to my burning software and burn yes?
Hdhntr23 is offline
post #4 of 19 Old 21st August 2009, 04:27 PM
ECB
ECB's Avatar
I'm far from a computer guy, but yes I saved the modified navboot file (like on my desktop) and then inserted it into the Nav program using a program called UltraISO which is a free download, and then saved it. Then burned the DVD with Imgburn which is also a free download.
ECB is offline
post #5 of 19 Old 21st August 2009, 04:29 PM Thread Starter
Hdhntr23
Hdhntr23's Avatar
Just the navboot file or the whole update discs files with the newly saved navboot in it?
Hdhntr23 is offline
post #6 of 19 Old 21st August 2009, 05:22 PM
Mike S.
Mike S.'s Avatar
I've done a splash-screen, wording, British-voice thing on mine as well using navtweak. It was over a year ago, but I'll try to help as well.
What you need to burn to the CD is the .mdf file. The entire .mdf file. The one I created ended up being 294MB in size. I used ImgBurn to burn it.
Rolling Heroin - 2003 M5 TiAg / Tuning by Evolve / Exhaust by Timmay77 / ECM by Valentine / Fast by Nature - "She's fast enough for you old man." Nickname courtesy of Mike Miller (yes, that one.)
What I do in my spare time: Aura Caelestis, Metal Band From Texas. Check us out! Comments welcomed!
Mike S. is offline
post #7 of 19 Old 21st August 2009, 07:00 PM
doc$holliday
doc$holliday's Avatar
Drill to the navboot file in navtweak YES
Edit the settings the way I want allbeit splash screens or accept screens etc YES
Save the file back in the directory I drilled into and save it as navboot YES or put it in a new spot
Hdhntr, it's the 4th line here that I believe isn't working for you. I am not sure if NERO will accomplish what you need for the ISO. Easiest way is to search for that UltraISO program, download it free and you will be putting your navboot file in there to create the entire file - like Mike S. is talking about, it should be several hundred meg in size. It's been awhile since I've done all mine as well so memory is faded but you want to open up an existing Nav ISO file in UltraISO and replace the navboot part with your new modified Navboot file.
hth,
SP
Sean Paul
2003 M5 LeMans Blue with sport blue/black interior
Evolve SW, Alpha-N (MAF-delete) w/ IATS relocation, Dinan Stage 1 suspension, Rogue trans mounts, short shift, E46 ZHP shift knob, Magnaflows, Stoptech Slotted Rotors, Stainless front brake lines, ceramic pads, Beastpower titanium pedals, white LED interior lights.
doc$holliday is offline
post #8 of 19 Old 21st August 2009, 07:42 PM Thread Starter
Hdhntr23
Hdhntr23's Avatar
Ok so, those files that I dragged over to my hdd should be made into an iso image right? Then extract the navboot file, edit it, put it back into the iso image then burn that to a disc?
Hdhntr23 is offline
post #9 of 19 Old 21st August 2009, 08:41 PM
Mike S.
Mike S.'s Avatar
Essentially, yes. Drag the files *out* of the ISO that need changing. Make your changes to those individual files. Then you need to reincorporate the changed files back *into* the ISO file (or .mdf file, depending on the extension) and reburn the large file to the CD.
Mike S. is offline
post #10 of 19 Old 21st August 2009, 09:09 PM Thread Starter
Hdhntr23
Hdhntr23's Avatar
k now I think I get it. Make a virtual CD on my HDD of the update disc, edit the navboot file from that image, put it back in, burn that back to a new CD.
Ill try this tonight. Cant really play with those files like that on the ole work PC. IT tends to get pissed. hahaha
Hdhntr23 is offline
Help:: Navi experts Pancho///M5 E39 M5 and E52 Z8 Discussion 4 8th September 2008 03:46 AM
NavTweak for dummies? ECB E39 M5 and E52 Z8 Discussion 30 10th August 2008 02:14 AM
NavtweaK and V28? Sounds like fun... also V27.1 & V27 download Ocean's M5 E39 M5 and E52 Z8 Discussion 2 27th January 2007 07:43 PM
Help from the experts! Whiteyford E39 M5 and E52 Z8 Discussion 3 30th April 2004 06:37 AM
