1st September 2009, 21:08
#351
Moderator Emeritus
Originally Posted by Asbjorn@ESSTuning
Yes, we do. It is not official or supported, but we have it available for people who want to try it.
Awesome. Now I just need to save up some $$
1st September 2009, 21:10
#352
2001 M5 LeMans Blue
Originally Posted by konst
with an air water cooling system, i assume the water used is from the engine cooling sysmtem (apologies if that is wrong), which will be running around 90 degress. so Rom3n/asbjorn, can you tell me what the temperature increase is through the SC?
I cannot believe that the low pressure you are running would cause an temperature increase of 60+ degress (although i am speculating). and if the increase is below that, there will be no point in having an IC
The water used is in its own closed loop system with two air-water heat exchangers, one in the intake path after the SC and one in front of the car.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
2001 Audi S4 6MT -- it's back
1996 Volvo 850R wagon
1st September 2009, 21:17
#353
M330
Ok thanks for pointing that out, i have learnt something today. what is the temperature rise after supercharging, but before cooling?
does this mean there is a separate water pump, is this electric or is it cranksahft driven (would explain the high cost of IC SC systems)?
1st September 2009, 21:25
#354
2001 M5 LeMans Blue
It's a separate pump, electric. The temperature rise depends on the boost level and efficiency of the compressor as the major variables...hence the answer is highly dependent on those. Do some research on intercooling (or as some call it with water-air systems, aftercooling) as the web is full of information. Trick systems are out there for drag racing where there is a reservoir for a large mass of water to further increase the thermal mass of the water in the system, and you can also then put ice into it (and require the ice to change state or course which absorbs lots of heat).
1st September 2009, 21:29
#355
M330
Thanks for your concise answer, but that is information i already posses, let me reiterate what my original question was: (Rom3n and Asbjorn), what is the temperature increase of intake air before and after charging. with the ESS SC kit.
1st September 2009, 22:24
#356
BMW
1st September 2009, 22:46
#357
Originally Posted by razahyde
ess m5 should outrun an E60 easily...have you seen the dyno chart of the ESS kit?
-I put this simple graph together a while back. It shows the stock S62 (blue), Dinan S2 S62 (orange), stock S85 (purple) and ESS S62 (green). The ESS engine is obviously the most powerful.
Note: These dyno pulls were done on different dynos at different times, but I believe them to be accurate given the sources. I have corrected them to flywheel HP.
www.ebsart.com
2011 X3 35i, Alpine White with Nevada Chestnut interior and waveline wood trim
-Ceramic tint on all windows
-DVDinMotion DVD software unlock
-245/275 P Zeros f/r on 18x8.5/10 BBS RG-Rs
2007 Z4 M Coupe, Titanium Silver with Imola Red interior and silver trim
-for paint details: www.myartcar.com
-for mod details: www.mymcoupe.com
2003 M5, Imola Red with black interior and silver trim
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
The Following 6 Users Say Thank You to palantirion For This Useful Post:
1st September 2009, 22:59
#358
01 M5 Black/caramel
If added later, do we have to send the ECU back for a reflash, or can it be included in the original reflash for future use?
1st September 2009, 23:05
#359
BMW
Water/Meth will run just fine on the regular VT550 tune to, but we made a version with higher timing for it especially. I do not recommend using this without meth or high octane fuel.
The Following 2 Users Say Thank You to Asbjorn@ESSTuning For This Useful Post:
2nd September 2009, 00:28
#360
Not to speak for ESS, but I think Chuck answered the question. The temp increase after s/c'g depends on the boost. Probably little/no increase putzing around town under vacume/atmospheric. Keep in mind that during normal driving, including modest acceleration, you will typically not be pressurizing. As soon as you boost, the temp goes up per the ideal gas law PV=nRT. The temp increase will be related to the psi. As for the temp increase during boost in the ESS kit, I'd look at the dyno results... they don't lie. The kit appears to be well tuned for the temperatures the system makes. Brian's been toiling around in hot CA weather, so heat soak also seems acceptable.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
