Chiptuning in E39 M5 with engine at 160.000km (100.000miles) - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 20th August 2009, 18:25   #1
GreenEyes
GreenEyes's Avatar
Garage: E39 M5 Carbon Black
Hello, i asking myself if it would be bad for my engine if i let my car chiptuned. Engin have now 160.000kms (100.000miles).
People advised me to go to 'Power-Plus' (PowerPlus.be - The best choice to be in front), these people from Power-Plus tell me that this will not cause any negative effect to my engine but that will tell probably each tuner. I will have a profit of 30hp and 47NM torque. The car will go before and after the chiptuning on a rolling road.
I want let this do, but only if I am certain that my engin will have the same life span then without chip.
Someone experience?
Thanks!
GreenEyes is offline   Reply With Quote
Old 20th August 2009, 19:53   #2
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
First off, you will see no such gain in BHP or Torque. This is marketing folly and large gains are not possible with remapping, unless you have forced induction to start with. You will likely only see a 5 - 10 BHP rise.
Having said that, I had mine remapped at around 120,000 miles and I only wish I'd done it sooner. This engine is good for over 600BHP in stock form so you certainly will not damage it. The re-map sharpens up the throttle response and seems to give more urgency across the rev range. The car constantly cries out to be revved and pushed harder than it ever did before. It even sounds a little better as the timing is advanced slightly - the exhaust note gets a bit crisper and less woofley. The real dyno will not show you a massive gain, but your butt dyno will be off the scale. Do it!
100%Cocoa is offline   Reply With Quote
Old 20th August 2009, 23:06   #3
GreenEyes
GreenEyes's Avatar
Thanks for your reaction!
So why should i put a chip? What you explain me seems to be the same as pushing on the sport button...
I don't want that the chip changes my throttle response, i have a button for that.
Is there really a difference except the throttle response?
What means 'revved'?
Old 20th August 2009, 23:12   #4
bng4god
bng4god's Avatar
Garage: M5
But imagine if you had Sport Button on top of the Sport Button....
01 Black on Black M5: Custom Exhaust with Straight Pipe & Magnaflow 14816 Mufflers, Angel iBright v3.0, 19x9.5/15mm All Four Beyern Mesh Custom Painted Silver Gray Metallic w/ Hankook Ventus V12 Evo K110 Tires 275/30/19's, Dinan Springs, Koni Yellows, Dinan Rear Sway, Hamann Replica Front Lip custom painted
bng4god is offline   Reply With Quote
Old 20th August 2009, 23:39   #5
Kleintje
Kleintje's Avatar
Garage: E39 M5 Dark Green
I wish there would be different settings.....
Kleintje is offline   Reply With Quote
Old 21st August 2009, 00:42   #6
ARL67
Garage: 2003 M5 Sterling Gray
My thoughts are the same as 100%COCOA above.
I recently installed Supersprint Headers, followed 10 days later by Shark/Conforti software.
I haven't dyno'd my car, but the "new" driving experience is as described by 100%COCOA.
Also, I highly recommend the inexpensive E60 short shift upgrade.
I may do lightened/underdrive pulleys next, then mufflers (not too loud) and then call it quits for mods.
- Andy
ARL67 is offline   Reply With Quote
Old 21st August 2009, 02:11   #7
Need4Spd
Need4Spd's Avatar
It is difficult to describe, but the ECU tuning does more than pressing the sport button. There is more to throttle remapping with the engine software than just making the throttle bodies open wider for a given amount of pedal movement. There are real gains in torque, HP and driveability, but not dramatic. It will be more satisfying to drive is all I can say. As long as the software don't alter the peak rpm limiter (or don't often exceed the stock rpm limit if the limiter is removed), there shouldn't be any significant added wear or risk of damage to the engine. Increasing the rev limits (which is DIFFERENT from removing the top speed governor) just a couple hundred rpm GREATLY increases the stress levels on certain engine components, so I advise not doing that. The option to increase the rpm limiter or not should be present on all good ECU aftermarket software.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline   Reply With Quote
Old 21st August 2009, 02:30   #8
mmzcee
mmzcee's Avatar
Garage: TiAg E39 M5
Sales Feedback: (4)
with the exception of The Shark Injector, ESS/powerchip both offer the option to NOT raise the revlimit.
I will ALWAYS shift at ~6700-6800rpm every time under WOT just to be safe, shark or no shark.
mmzcee is online now   Reply With Quote
Old 21st August 2009, 02:37   #9
GreenEyes
GreenEyes's Avatar
- Andy
Hey Andy!
are the Supersprint Headers the money worth? Big difference?
From which E60 do you recommend the shift upgrade? The E60 M5 is a 7-gear...
What is not expensive? Does it fit in a E39 M5? Modifications to do?
Thanks,
Peter
Old 21st August 2009, 02:39   #10
GreenEyes
GreenEyes's Avatar
OK thanks,
so chiptuning yes but without increasing the RPM...
M5 chiptuning? Is it worth? Ezh E60 M5 and E61 M5 Touring Discussion 17 2nd October 2008 07:09
bmwm5.com Video: Alpina B10 V8 S (E39 w. 375 HP). 60-160 mph on Autobahn! Gustav ALPINABoard.com | BMW Alpina Discussion 8 9th November 2004 20:17
+31 HP with chiptuning. How credible? Dirim E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 13 25th December 2002 01:16
bmwm5.com Video: Alpina B10 V8 S (E39 w. 375 HP). 60-160 mph on Autobahn! Gustav E39 M5 and E52 Z8 Discussion 7 25th October 2002 20:29
Chiptuning for M5 silverstone400 E39 M5 and E52 Z8 Discussion 2 16th October 2002 05:16
