Old 20th August 2009, 05:07   #1
JohnnyP420
JohnnyP420's Avatar
Garage: 2000 LeMans Blue e39 M5
TPMS reset not working, pls help, have read every article.
I have tried everything, but for the life of me, I can not reset the "TPMS" system on my car. I frequently have been getting Tire Defect or Riffenpanne messages almost daily since i got new tires on my car almost 6 months ago. The warning appears at the exact same spots on my daily commute, and i check the tire pressure weekly. 42psi front 44psi rear (or vice versa, cant remember) or 44 front 48 rear (again not exactly sure but I digress)
Regardless, if I turn off my car and turn it back on (usually at a stoplight) it goes away, and if I'm luck I can continue without it going off again. However I am extremely tired of seeing the message appear almost daily.
I have tried everything to attempt to reset the system, and read everything this site has to offer about it. I know to turn the key to the second position, and hold the TPMS reset or recalibrate button for at least 10 seconds and a message will appear. I have dont it both with the seat belt buckled and not buckled, car on, car off, poisition 1 and 2, upside down, inside out, and have held it upwards of 5 minutes in pure frustration with no magical message appearing.
Is there a fuse associated with this particuar system or reset system that may have gone bad or am I just a complete idiot?
Any help would be greatly appreciated!!!
JohnnyP420 is offline
Old 20th August 2009, 08:30   #2
E55AMG2
E55AMG2's Avatar
1) 44 and 48 are too high for tire pressure. 38F and 43R is about as high as anyone would want to go.
2) You need to get the reset message on, then drive around giving the system time to learn what acceptable wheel speed ranges are. Take as many different types of corners as you can.
E55AMG2 is offline
Old 21st August 2009, 16:10   #3
jclyman
jclyman's Avatar
E55AMG2 is pretty close in his recommendation on tire pressures, or should I say, as I like mine. I actually run 39/42 in town (which isn't often) and 40/43 (or 40/44, if heavily loaded) on the "road" (which is almost always true).
Anyway, to my point for you. BMW driver/instructors at the BMW Advanced M Performance School told us the M5 tire defect system sometimes alerts you with FALSE info. They always come in when they get the warning message, but there is seldom a REAL problem. Switch engine off and back on, and go out again, and play. It seems that L O N G SWEEPING TURNS sometimes produce false triggers. I suppose nothing in life is perfect, but the only time I had a warning message in 6 + years, it was accurate ... and, then thank goodness, I got it, 'cause you typically CAN'T tell by just by looking, that a tire is low. (I always walk around my car before getting in, just in case I have a flat, which I would be able to see. Sometimes, with a tire on very uneven ground, a tire may look low. I check it immediately, before I drive away.)
Key MUST be in position 2, engine off. Press and hold the button for more than 4 seconds, or until the "Set ..." message comes on. Then drive for at least 15 minutes (factory says 10) for the system to complete its set up mission. NOTE: It will NOT report a low tire unless it is about 30% below the others, and unless the car is going UNDER 85 or 90 MPH (can't remember which)! I was very close to schredding the inside of a rear tire due to an "injested" nail, years ago. I had been driving well over 120 MPH with NO WARNING message. Tire pressure was 18 lbs when I saw it. No loss, though, as I was on my way home to have new tires mounted (already had them).
Another point: ALWAYS check your tires when cold (after sitting at least 4 hours). On my last trip, I drove through 115 to 117 degree weather almost ALL day. Curious, I checked a tire to see how much it had increased (the pressure increases when the tires are hot). The front tire (which was set that morning at 40.5 lbs), registered 48 at around 1 PM.
- Daniel Boorstin
jclyman is offline
The Following User Says Thank You to jclyman For This Useful Post:
JohnnyP420 (22nd August 2009)
Old 21st August 2009, 16:40   #4
NAT
NAT's Avatar
Garage: E39 M5 LE MANS BLUE
I am not 100% sure, ( and im sure someone on here will confirm/deny ) but i believe the TPM works off the ABS sensors on the M5. They can get covered in crud. Rumor has it a good session with a jetwash get them going again, or otherwise remove , clean and refit.
Just thinking aloud.
Regards
Nat.
RealOEM.com BMW E39 M5 REAR AXLE SUPPORT/WHEEL SUSPENSION
NAT is offline
Old 21st August 2009, 16:58   #5
jclyman
jclyman's Avatar
Regards
Nat.
Absolutely correct, Nat.
jclyman is offline
Old 21st August 2009, 17:12   #6
Mike S.
Mike S.'s Avatar
Garage: "Bugslayer" 2003 M5 Titanium Silver
Send a message via AIM to Mike S. Send a message via MSN to Mike S. Send a message via Yahoo to Mike S.
One minor point to mention...the reason you should probably have your seat belt buckled is to make sure the "fasten seatbelt" message isn't taking up the message area (where you see the Set... message) as John mentioned above.
I've had one failure message as well, and it was accurate. I had picked up a screw and was down to about 20 psi when I checked it.
"Bugslayer" 2003 M5 - Engine: Magnaflow 14816, Driveline: E60 545i Short Shifter Suspension: TCDesign Rear anti-roll bar brackets Exterior: Stealth Auto Black Kidneys, 30% Ceramic Tint Interior: Hardwired V1, Ultimate Cupholders, OEM AUX Audio Input, Diny custom radio knobs.
Mike S. is offline
Old 21st August 2009, 22:58   #7
jclyman
jclyman's Avatar
Thanks, Mike, I had forgotten to mention the seat belt being buckled ... The "Fasten Seat Belt" message would probably override the "Set Tire Pressure" message.
John
jclyman is offline
Old 21st August 2009, 22:58   #8
Hawkwind
Hawkwind's Avatar
Garage: 2003 M5 Sterling Gray
I've gotten the message twice, both times accurately indicating a problem.
Hawkwind is offline
Old 22nd August 2009, 03:14   #9
JohnnyP420
JohnnyP420's Avatar
See, this is the most frustrating part for me, I cant even get the damn thing to say "Set..." or whatever it may be. Im thinking that maybe I have a faulty switch/ button that recalibrates or resets the system?
Old 22nd August 2009, 03:25   #10
josiahg52
josiahg52's Avatar
Garage: Jet Black 2001 M5
Before getting the warning, what happens when you press the TPMS button?
What happens if you press the button AFTER you get the warning?
Josiah
2001 Jet Black/Black Extended Leather w/ Brushed-Al trim ///M5
Engine: Supersprint Headers, Race Cats, X-pipe, and Magnum mufflers, Dinan CAI, Dinan high-flow MAF housings, Dinan Stage 4 Software, Zionsville Super Duty Radiator/Fan system, Mobil 1 15W-50, Bosch Platinum IR Fusion spark plugs, Odyssey PC925 lightweight battery, Red
powder-coated valve covers
Drivetrain: Dinan brake-duct kit, Ground Control suspension, Stoptech ST-40 BBK, UUC short shift kit, RP Synchromax and 75W-140 gear oil, Rears in front (275s all 'round), PS2s
Interior:
Illuminated ZHP shift knob (did it myself) w/ 540i leather shift boot, V1 w/ Stealth One, Blinder, hard-wired DC-to-AC inverter, S.S. Nav/Radio knobs by member Diny
Exterior: custom sheet metal pork chops, Umnitza Predator Thinline demon eyes and HID fog-lights, fog-lights via relay from battery, fog-light retention with high-beams, matte-black kidney grille bezels/chrome slats
Soon: "Gulf" oil cooler, Black-faced cluster retrofit, painted plenum cover, custom M stiching on shift and e-brake boots, custom M striping on seats (like the E36 M3 probably), Powder-coat OEM Style 65 wheels, rear anti-roll bar and BeastPower brackets, door edge protector repair, complete exterior ///M debadge, amber light conversion
Also a 2001 Tahoe LT Supercharged 4x4 and 1978 Dodge Power Wagon W200.
josiahg52 is offline
radio/ipod not working, help pls psiggy E39 M5 and E52 Z8 Discussion 2 10th December 2008 09:14
service light reset not working maxrpm E39 M5 and E52 Z8 Discussion 3 20th May 2008 02:44
Service light reset IS NOT working.... if lookz kill E39 M5 and E52 Z8 Discussion 4 1st March 2007 21:15
Pls Read: RE: Discovery Automotive aaronmiles E39 M5 and E52 Z8 Discussion 20 23rd February 2007 04:48
the beast is back!!!pls. read... Laidback E39 M5 and E52 Z8 Discussion 13 13th June 2006 02:08
Page generated in 0.16928 seconds with 11 queries
