m5board.com Advertisers are: Download GTBoard.com Supercar Shootout 1 + 2 in HD 1920x1080 360 Forged 503 Motoring (OR) Angel iBright ASR Engineering Bavarian Soundwerks Bimmer Performance Store BMS BMW service CA Automotive CNS RacingDinan Cars EisenmannNA ESS Tuning Eurosport Design Evosport GTboard.com < "Supercar Shooutout II: 40+ car in action incl. BMW M3 E92" Hartge (Member discount) HRE Wheels Kreissieg Medford Tools (OR) Meist GT modbargains.com Neez Powerchip Group Race Precision Revozport Supreme Power (CA) TireRack BMW M5 Upgrade Garage for wheels, tyres and suspension Tubi Style North America Turner Motorsport Umnitza UUC Motorwerks Zeckhausen Racing BLACK LIST OF NON-APPROPRIATE VENDORS Be an m5board.com Advertiser!
Old 20th February 2002, 05:23   #1 (permalink)
rennen
rennen's Avatar
Rolling the fender
Just wanted to know how anyone went about rolling their fenders? The new wheels are a little snug and I want to be safe. Any input is appreciated.
2003 M5 Jet Black/Black sport interior
2000 M5 Jet Black/ Black sport interior
2002 X5 3.0
2002 M3
2002 M3 Cab.
2000 Yukon
1966 427 Cobra S/C
1966 GT350H
1966 Hemi Charger
1969 Corvette
1966 Austin Healey 3000
rennen is offline
Old 20th February 2002, 06:03   #2 (permalink)
Apples
Apples's Avatar
View my 2000 M5 Blue
Well i'm no expert by far.....but l did mine becase l went with 285's on the rear, and much lower suspension. All went well, in my eyes. I used a piece of wooden rod, a few feet long and about 1.5 - 2 inches thick. Thicker is better, as long as you can fit in between the tire and the fender. I then started at the bottom of the inside of the fender, and then folded/pressed the lip back in small sections in more of a rounded look internally, instead of it sticking out and cutting my tire under full loads. I did this by using the tire as the leverage. Do this every 1/4 of an inch or less for about 4 - 6 inches and that will turn that edge back and out of the way. Some of the paint on the inside may come loose, but there is no way you would see it. I will put the odd dab of paint on it soon....no biggie.
I can send you pics next week if you want to see the job.
There is is a good chance a decent shop would do a professional job, so look at that to.
APPLES
2000 M5 LeMans blue
Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/BBS LM 19's.
2003 M5...actually MIB's (master yoda)
2004 Lamborghini Gallardo Pearl Yellow. HRE 840r 19's front 20's rear
2006 Ford GT Heritage blue
www.m5ute.com
Apples is offline
Old 20th February 2002, 06:17   #3 (permalink)
BostonRocket
BostonRocket's Avatar
Send a message via ICQ to BostonRocket
Apples,
Did I ever mention to you that you are my hero!?
'Rocket
H&R Springs
GONE - 2003 TiAg/Black E39 M5
GONE - 2001 TiAg/Black E39 M5
BostonRocket is offline
Old 20th February 2002, 12:39   #4 (permalink)
VanM
VanM's Avatar
View my Le Mans Blue M5
I have also done the same thing with my previous cars when I comes to rolling the fenders. As for the paint coming off on the inside of the fender, a heat gun will solve the problem if you can get your hands on one. Just heat up the area to be worked on before you start rolling and the paint should chip off. Hope that helps.
VanM is offline
Old 20th February 2002, 12:41   #5 (permalink)
VanM
VanM's Avatar
I should probably read my posts more carefully before I post them up.
What I meant was after using the heat gun, the paint should NOT chip off.
Sorry.
VanM is offline
Old 20th February 2002, 13:33   #6 (permalink)
kees
Administrator
View my magic moderator wand
Apples,
The way you describe it sounds like the typical Aussie solution - where a length of wood, some string and some bubble gum are applied successfully no matter the extent of the problem...
However, the method you describe is pretty much how many professional bodywork companies roll fender lips as well.
In my opinion, especially members in colder locations will want to avoid painting chipping / flaking at all costs to avoid any future rust problems.
Some slight variations, which may help to avoid paint chipping/flaking is to spread the pressure you put on the fender lip a bit by putting some thick cloth between the wood and fender lip. Also, using a round piece of wood or metal and actually rolling it between the tire and fender lip will help. Lastly, not bending the fender lip in 1 go, but in gradual steps should help.
/Kees
kees is offline
Old 20th February 2002, 16:29   #7 (permalink)
Apples
Apples's Avatar
Kees...you forgot to mention the duct tape, it's a must in OZ if you want to fix somthing, and do a REAL good.
The paint in that area is sort of softer then the external paint. It's got a rubber sort of feel to it, so a larger piece of wood...base ball bat would be good if it will fit. Protecting the lip is a good idea.
APPLES
Apples is offline
Forum Jump
Fender rolling BostonRocket E39 M5 and E52 Z8 Discussion 2 12th June 2003 01:29
Rolling Thunder Audio $700 Gift Certificate Bay Area bay area kid For Sale or Wanted 0 20th May 2003 01:37
rear tire hitting wheel well GGarai E39 M5 and E52 Z8 Discussion 9 30th November 2002 03:29
rolling road stevie53 E34 M5 Discussion 2 15th August 2002 15:34
Help! Poor paint quality on my rear fender lips? Cerberus E39 M5 and E52 Z8 Discussion 12 27th August 2001 19:55
