PSA: Check your oil filler cap gasket - BMW M5 Forum and M6 Forums
post #1 of 5 Old 11th August 2009, 01:03 PM Thread Starter
ccieurzo
ccieurzo's Avatar
So I foolishly checked my oil and topped off before a long trip. About 2 miles into the drive, I started smelling oil burning. I stopped and found some smoke rising out of the engine compartment and oil sprayed all over the area around the filler cap. The cap was properly seated, but the gasket was no longer keeping the oil in the engine. I tried bending the tabs for a better seal, and that worked a little, but there was still enough leakage to make a mess. I was fortunately able to find an open parts department on Sat and get a replacement cap. Any recommendations for cleaning all of the oil out of the engine compartment? BTW the car has 90k miles on it.
Chris
2012 X5 50i
2008 M5 Interlagos Blue (traded in)
2003 M5 Carbon/Caramel (Traded in with 103,000 miles and still going strong)
2003 BMW K1200RS (zoom)
ccieurzo is offline
post #2 of 5 Old 11th August 2009, 03:12 PM
gsfent
gsfent's Avatar
Somone suggested the M3 (E46?) oil cap fits and provides a better seal.
I believe there has been some discussion about cleaning oil. I think one of the products is simple green or similar name.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is offline
The Following User Says Thank You to gsfent For This Useful Post:
ccieurzo (15th August 2009)
post #3 of 5 Old 11th August 2009, 04:05 PM
udaideo
udaideo's Avatar
Hi there,
I had exactly the same problem on my E39 and I bought a new filler cap which solved the issue. My friend who is a BMW senior technician said that it is quite common for the seals in the cap to go.
Many thanks
udaideo is offline
post #4 of 5 Old 11th August 2009, 07:21 PM
kosmo
kosmo's Avatar
kosmo is offline
post #5 of 5 Old 11th August 2009, 08:04 PM
josiahg52
josiahg52's Avatar
I don't know your idea of "bling" but Bimmian sells a billet aluminum one here.
I thought about getting one but went with the E46 cap. My original wasn't leaking I just didn't like seeing "Castrol" everytime I opened my hood when I don't even use Castrol. Besides, the E46 cap is a lot cheaper and who can argue with another ///M on the car?
Josiah
josiahg52 is offline
Check filler cap message Osodog E39 M5 and E52 Z8 Discussion 3 6th August 2009 12:35 AM
Welcome the newest member of the "improperly replaced oil filler cap" club Mike S. E39 M5 and E52 Z8 Discussion 30 21st February 2009 04:50 PM
OT; Make sure to double check the oil filler cap!! Sebring NL E34 M5 Discussion 11 3rd March 2006 11:08 PM
What can force oil out of the filler cap? nlk10010 E39 M5 and E52 Z8 Discussion 23 10th September 2003 03:56 PM
Oil Filler Cap Leak M PHATIC E39 M5 and E52 Z8 Discussion 2 7th May 2003 06:59 PM
