BlueM5 blew a motor - BMW M5 Forum and M6 Forums
Old 11th August 2009, 04:38   #1
lonny23
lonny23's Avatar
Garage: 2002 LeMans Blue M5
BlueM5 blew a motor
It pains me that I have to start this thread, but I have a story to tell and it's not a fun one. I'd like to start by apologizing to the car. You were awesome and did your job and it's my fault. Somewhere in here, I'm looking for opinions and advice and I have my own ideas and thoughts.
I like to drive fast and I wanted to know how fast the car would go. I put a Shark Injector on the car and it did it's job. I just got back from my vacation and the car was awesome in the mountains and ran like a champ. Ever since I bought the car, I noticed it would use some oil if I ran it at 100 or more for a while or really got in the gas hard in town on a somewhat consistent basis. It was somewhat of a tradeoff for me to show off and have fun and occasionally throw in a quart. It used some oil in the mountains, but not a great amount.
My story starts in Salt Lake City. I checked the oil when getting gas and was about 1/2 a quart low, but didn't add. I went to Bonneville the next morning and the conditions were great with no wind and nobody else running. My tires held up great. I got the car up to 173 on my first run and didn't really shift at optimum times. It was somewhat of a hard pull above 150 out on the salt and hindsight tells me I could've built up speed a lot faster on pavement. I took it mostly easy on my way back to the starting point, but neither checked the oil nor cleaned out any salt. My mechanic doesn't think not checking the oil was a big deal since I probably only did around 2-25 hard miles out there total.
My problem as best I can tell was on the run back to the start where I was determined to shift at max RPM's for each gear. I had my girls with me and I just flat out forgot to shift from 4th to 5th on that run. There was one other time around town here that I forgot to shift from 1st to 2nd or 2nd to 3rd on time and might gotten around 7600-7800 RPM's before shifting, but there was no problem with the engine. Anyway, I was doing around 130 and got it up to around 8000 RPM's and felt the car lose power, but it didn't click. It was like what a "limp home" mode would feel like in my estimation except I had never felt that in the Sharked car. I hit the gas again and it cut out on me a 2nd time and this time I remembered that I was redlining it. I slowed all the way down to either 1st or 2nd and started working the gears again and it seemed fine. I started another run and got back up to 140 in 6th and the engine just died on me. It gave me that nasty engine light and my first thought was, "I blew a motor".
The car coasted for a ways before I got smart and turned it back towards the starting point to be closer for a tow. At some point I turned off the ignition and let it coast until it stopped. At that point I tried to start it and couldn't (I got the nasty engine light and add coolant). The tow truck wouldn't come on the salt flats, so they pulled me back to their truck with a four wheeler. "It Must've Been Love" by Roxette has always been one of my favorite songs, but I've never known why a hopeless romantic like me would love that song so much. Needless to say, I had Roxette music playing while I was out there and listened as I was getting towed back. "It Must've Been Love" came on while I was getting towed and you better believe the line "It must've been love, but it's all over now" from that song hit like a sledgehammer and it was the first time in my life that I truly felt a connection for that song I love so much actually applying to my own life. I didn't even feel that way about the song when I was getting divorced, but I do about the car.
Anyway, they towed me in to the BMW place in Murray, Utah. I've got to give the people there props as they seem like decent people. They gave the girls and me a ride to the mall so we could eat and they called with the bad news. The engine was blown and a piston connecting rod put a hole in the block. They don't know what other damage might be on the car, but they said maybe metal in the exhaust and it's possible I might need a new clutch. The main thing is an engine replacement and they said $28K. I've seen used engine/transmissions on here for $7-8K. I'm going to get the car trucked back to Texas and my mechanic here thinks my best bet would be to buy another M5 and use my current one for parts since he doesn't think I could get mine fixed for less than $10-20K. I might be looking at letting it sit for a while, but I want a running M5 at some point.
What do you guys think about this stuff:
1. Auctions and salvaged vehicles are a potential option. I know they can be crapshoots, but I had a car that was running perfect and my big problem now is just an engine that doesn't work and I might not need much off of another car to get mine running.
2. My car is an 02. How well do the parts from 02 cross over (To mine or from mine) if I bought an E39 from another year?
3. How well do the engines hold up for cars that are in crashes? I know a rear collision wouldn't be much of an issue, but how about side and front collisions? Common sense tells me cars get salvaged because the damage is more than a car is worth and that could be a red flag for engine problems, but I've also read about plenty of salvage vehicles that are totaled even though the damage is far less than the car value.
4. Flood damage vehicles seem to get decent marks for buying as salvage, but what do you think about the mechanical performance of those vehicles?
5. When I broke it, my original desire was to fix my car, but I'm open to using it as parts when I see a deal good enough to buy another car. Do you think my better option is to buy a good working car and just cannibalize from mine when needed? I can't get over thinking that my car could have hidden problems that show up later, but then again, maybe my worst is just replacing an engine.
6. Thanks for any replies! I just wanted to bounce it off of you guys to see what you've experienced or heard.
lonny23 is offline   Reply With Quote
Old 11th August 2009, 04:47   #2
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
i think you should bring it back to tx, and call me.
we can get this squared away pretty easily and for roughly 4500-6000 EASILY and ALL DAY LONG and will only take us a weekend.
if you dont know me, well then hi im raza i have a spare motor and this thread should explain the rest.
My S62 swap comes to a conclusion, the ending
i think you are 30 minutes away from me?
/thread
razahyde is offline   Reply With Quote
Old 11th August 2009, 04:47   #3
kruat
Garage: 01 B5 S4 (but looking for a E39 M5)
wow man, I'm sorry to read that. Hope it works out for you in the end.
--Mike--
01 B5 S4
0? E39 M5 (as soon as I find the right one)
kruat is offline   Reply With Quote
Old 11th August 2009, 05:24   #4
MrCrashRR
Garage: 2003 Alpine White M5
/thread
This is the by FAR the best option IMO. I wouldn't even think twice, except maybe an ESS kit while you are at it
2006 Phantom Grey Tundra 4dr
2004 La Mans Blue CBR1000rr track bike
MrCrashRR is offline   Reply With Quote
Old 11th August 2009, 06:04   #5
GBPackerfan1963
GBPackerfan1963's Avatar
Garage: 2002 Bluewater Metallic M5
/thread
Awesome job stepping up, Raz!
2002 M5 Bluewater Metallic/Black & Silverstone leather/
All options/MKIV NAV/VMR VB3 Wheels Square set-up/3M tint
/BT/Intravee II/Ice V5 angel eyes/smoked side markers/
DINAN Front Strut Brace/PowerChip Alpha-N tune/Smoked taillights/Ultimate pedals/
BSW Stage 1 Upgrade w/Subwoofer package/e60 SSK/ZHP Shift Knob/
CF Kidneys/CNS Racing Cat-back exhaust/LED lighting throughout/Euroclear Headlights/
Angeleye DRL's/HID Foglights/Dinan Stage 2 Suspension/
CNS Racing Clutch/ Sink drain/brake duct modification/ExoticsTuning CF diffuser and fog light covers/SuperSprint Headers
"...when a 400-horse 5-series needed only one letter to make its point: M."
GBPackerfan1963 is online now   Reply With Quote
Old 11th August 2009, 06:05   #6
jimmythefish
jimmythefish's Avatar
Garage: 2001 BMW M5 LeMans Blue/Caramel
Sales Feedback: (11)
Lonny, call Raza he will get you running again. Raza if this happens would you mine if I fly down and watch the swap....always looking to learn more about the beast and and I could take a weekend. I have tons of travel miles.
James
2009 M6
2001 M5: Dinan: Front & Rear BBK, Stage 3 JRZ suspension,Front/Rear strut braces, Headers, Throttle bodies, Vertical stacks, CAI, MAF housings, Stage 5 software, Rims, Floor mats. CNS Racing clutch, Autoillumination interior LEDs, MKIV, Bluetooth retrofit, Intravee
2001 750il Intravee, MKIV, Bluetooth retrofit
jimmythefish is online now   Reply With Quote
Old 11th August 2009, 06:06   #7
malexgcab
malexgcab's Avatar
Garage: M5 CB
/thread
RAZA to the rescue! You gotta love this Board! Folks helping out each other.
malexgcab is offline   Reply With Quote
Old 11th August 2009, 06:34   #8
M Baker
M Baker's Avatar
Garage: 2003 M5 Lemans Blue, Caramel
Sorry to hear about that. I know the sickening feeling of a blown motor - happened to my M3 and $20k later I had a new upgraded drivetrain. But very sad feeling when it happened. Sounds like an incredible offer - and not too far away.
BTW I would never buy a "Flood" drivetrain - a hydrolocked engine has seals blown everywhere. My son found out about that when he tried to plow through a flash flood road crossing in Texas.
'90 M3 | '90 Talon | '99 Tahoe | '03 M5 | '11 Pilot
M Baker is offline   Reply With Quote
Old 11th August 2009, 07:19   #9
mmzcee
mmzcee's Avatar
Garage: TiAg E39 M5
Sales Feedback: (4)
I'm not trying to add insult to injury or anything. but did you seriously think that revving 600-1000rpm over the stock rev limit was gonna be anything but BAD for the piston rods/bearings, which are known to fail under 'normal' use? I must admit, the car running on low oil definitely contributed to your blown motor.
how you got to 8000rpm is beyond me because even the sharked software has a raised limit of only 7400rpm. the only way i can see this happening is if you deliberately downshifted from 4th to 3rd at high speed or something of that nature....
Honestly though, I'm sorry to hear about your beast,
perhaps this good used s62 engine w/ 41k miles for $2.5k would be of good use to you?
2002 Bmw M5 S62 Engine only 41k mils!
mmzcee is offline   Reply With Quote
Old 11th August 2009, 07:57   #10
jt2ma71
jt2ma71's Avatar
Garage: Alpine White E39 M5
Maybe this is another reason for M owners not to go for the extended rev limiter! Both the ECU flashes ive had done, ive request stock rev limiter. I usually shift at around 6500RPM in this car anyway, i think 7000rpm was pushing it from the factory.
That really sucks though, i blew a motor in my old car once, oil pump let loose at 7600rpm while i was running a turbo eclipse! Hopefully Raza can fix her up, and you will be back on your way. I do have a question, what was the mileage on the motor? And how long have you had the Shark Injector for. and roughly how many times in a week would you approach the 7400rpm rev limiter? This may help us with some insight on the whole extending the rev limiter deal!
2003 E55 AMG - Obsidian Black/Black, Eurocharged ECU reflash, 84mm SC pulley, CM30 IC Pump, FTP Heat exchanger, Needswings Dual CAI, Custom exhaust, Forgestar F14's, Lowering links, E63 Spoiler, CF Front lip
2000 BMW M5 - Alpine White/Silverstone Extended Leather/BBS LMs 245.35.19, 285.30.19/Evolve Alpha-N/Tubi Exhaust/AA Intake/Ducts/Dinan Springs - RIP
2001 Yamaha R6 - Yamaha Blue, Yamaha GYT-R Exhaust, Factory Pro +4 Ignition Advance, Factory Pro Jet kit, 03R6 Airbox/Filter, Clear Alternates and fender eliminator, puig windscreen, Yamaha Solo seat, APE CCT
2000 Durango SLT+ - 5.9 V8, 3.92 LSD, 32x11.5 BFG All Terrains, Airaid intake, Hughes F1 Airgap, SCT Tuner, Flowmaster 50 Series, Fully rebuilt 46RE, 2" torsion lift
Glock17 9x19|Vz.58 7.62x39|Mossberg 500
jt2ma71 is offline   Reply With Quote
Think I blew my clutch avry8542 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 15th August 2007 14:24
It blew up!! (again...) Yorldi E34 M5 Discussion 5 20th March 2007 13:58
Blew the engine BradM5 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 2 13th October 2004 13:06
Help - I just blew something in my driveline beanboy E39 M5 and E52 Z8 Discussion 6 7th December 2003 20:21
Battery Blew UP Jim Dolan E39 M5 and E52 Z8 Discussion 8 18th January 2001 00:36
