Originally Posted by markm5Ireland
I got OC code for Pre-oxygen senor which Is bank 2, passenger side in Ireland (Driver side US) - correct me if I'm wrong.
I got the code a number of times and reset it but it came back very shortly afterwards with Check Engine Light on dash. The last time I didn't bother resetting and ordered the part, it should be in tomorrow. However, I went for a spirited drive last night with a friend and we stopped someone for a few minutes, restarted the car and no check engine light. Still none today - so question is would you bother replacing it or not?
I did the MAF test with light on and got 137 so no issues with performance.
Hiya.
If you are in reality seeing a lean or rich condition then a tired pre cat o2 sensor may not be picking it up, and allowing you your 137 L/Hr...
In my opinion change both your pre cat 02 sensors every 60K miles or so, to help keep your M5 running at its max potential and safely.
I get them (Bosch 13477) for about £72 each (inc Vat and delivery) in the UK.
Cheers
Kumaran
