Old 8th August 2009, 23:10   #1
Mr.Devere
Mr.Devere's Avatar
Garage: 2000 M5 Black Beauty
A bit of a weird one, anyone else had similar?
Alright chaps,
Just wondering if anyone else has experienced this fault before I try to sort it out.
When driving on the motorway at about 70 - 80mph if I let off the accelerator and let the car coast whilst still in gear it seems to miss-fire with a slight hesitation, as soon as I put the power on it picks up and shifts right through the rev range without missing a beat. I can re-create the fault every time. It only happens when it is on extremely light load, i.e. normal - hard accelerate no issue, lift off and just slightly accelerate issue?
I experimented today and took it on a local motorway that I knew had a few hills, set the cruise at 75mph and let the car drive, going up the hill no issues as power is required, as soon as the car passed the crest of the hill and no power was required it started missing / hesitating, repeated every hill. On one hill as it was hesitating I put my foot down and it picked up immediately and as above reved right thro with no issue.
Its certainly weird as the car drives perfectly around town and under acceleration there are no issues whatsoever.......
Any help is appreciated.
Regards
M5 (black) He's back in style........
Baby (2 years in the wilderness)
330ci Sport Conv (silver)
Escort Cosworth (silver)
Sapphire Cosworth (2wd) (magenta)
MKI XR4x4 (white)
MKI XR2 (white)
Mr.Devere is offline
Old 8th August 2009, 23:48   #2
ard
ard's Avatar
How many miles on your plugs?
ard is offline
Old 9th August 2009, 08:34   #3
Mr.Devere
Mr.Devere's Avatar
will check thro' history to see if I can find any info, I have owned the car for 3 months......... any past experience or reason why you would suspect this?
MKI XR4x4 (white)
MKI XR2 (white)
Old 10th August 2009, 14:44   #4
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Two reasons for your problem.
1. The DME is picking up a fault and therefore not firing 1 or more spark plugs.
2. You have a problem with a spark plug or a coil.
Without a code reader you are shooting in the dark as there are 8 plugs and 8 coils. It is strange that it is missfiring on the over run, could be a valve timing issue which would point towards a CPS going bad. Get a code reader.
I'll see you, if you catch me
andy777 is offline
Old 11th August 2009, 04:38   #5
jclyman
jclyman's Avatar
Buy a Peake reader. ~ $ 150. and the best investment (after a radar detector) you can make. Otherwise you are in the dark, guessing.
- Daniel Boorstin
jclyman is offline
Old 11th August 2009, 23:12   #6
Mr.Devere
Mr.Devere's Avatar
nice one fellas, need to get a code reader then, are there varying models of the Peake unit? or is it one fits all?
MKI XR4x4 (white)
MKI XR2 (white)
E34 M5 Similar to New M3!! ECM4 E34 M5 Discussion 6 14th May 2007 01:41
Website similar to RealOEM ECB E39 M5 and E52 Z8 Discussion 11 16th April 2007 02:06
Too similar to a 535 richardDG ALPINABoard.com | BMW Alpina Discussion 4 25th June 2002 11:23
There Is Nothing Similar Mr.M5 GTBoard.com: General Sportscars 3 18th July 2001 19:21
Is there a similar forum for the Z8? kqsmith E39 M5 and E52 Z8 Discussion 3 29th December 2000 16:51
Page generated in 0.11442 seconds with 11 queries
