Old 8th August 2009, 20:59   #1
rrdaniel
Garage: 2001 M3 E39 Black on Black
2001 M5 Cranks but won't starts!!!! HELP!!!
Hello Everyone-
I am new to this forum but I am hoping that I will get the help needed.
I have a 2001 M5, Recently my clutch started slipping and decided to replace the clutch. I bought an aftermarket clutch SPEC to replace the worn BMW clutch. The mechanic replaced the clutch with no issues and while connecting the exhaust and electrical under the car, he noticed that the crank sensor was cracked so he went ahead and replaced it.
Once he finished, he tried to start the car but it won't start. The car will crank but no spark"ignition" is given and the car won't start.
The car is getting the fuel it needs and I think that the computer blocked or locked the ignition system for the engine to fire.
I believe, He disconnected the battery when he was doing this job or he might have done that when the car wouldn't start in order to reset the computer.
Anyhow, The car is not in another shop getting looked at hoping that All we need to do is re-flash the computer.
I won't know anything until monday, but has this happened to anyone? or any suggestion what might be the issue?
could unplugging the battery cause the computer to lose memory or block the ignition system? What could have happened to cause the car "NOT START"
Please help!!!!!!!
rrdaniel is offline
Old 8th August 2009, 21:17   #2
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
tell him to check the crank position sensor on the transmission and that its plugged in. i forgot to plug mine and my car would crank but not turn on. also double check all the plugs associated with the transmission. that's more then likely your problem.
-R
razahyde is offline
Old 8th August 2009, 21:56   #3
rrdaniel
2001 BMW won't start
We checked the crank sensor and it is connected just fine. Anything else can I check for?
rrdaniel is offline
Old 9th August 2009, 02:55   #4
gregh86
gregh86's Avatar
Garage: M5 Bluewater
Not 100% sure but doesn't the crank sensor have to be set at the correct depth giving a set clearance between sensor and flywheel.
Greg
gregh86 is offline
Starts but won't run.... Mfiver E28 M5 Discussion 14 20th November 2009 17:42
Hill starts Gus E60 M5 and E61 M5 Touring Discussion 2 9th December 2005 17:48
A beer before it starts! Albert V8 Gumball 3000 Forum 6 28th October 2004 21:56
New M5 starts hitting the mags AUDIRS6 E60 M5 and E61 M5 Touring Discussion 3 13th July 2004 13:21
Cold starts M PWR E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 12th June 2003 05:26
Page generated in 0.09844 seconds with 11 queries
