Thanks guys,
The hints and David's textbook tutorial really made things easier. I don't have a Peake meter yet ( It's on the "to-get" list) so I went to Autozone and got a P0012 code and a P0340 code.
From what I saw it was a "******ed timing" code and the "intake CPS on Bank 1" which is the US passenger side.
I checked for part availablility on Friday but they couldn't get one into Peoria, Illinois until Tuesday. I got on Autozone, Napa, Carquest and O'Reilly's websites and found an O'Reilly's 40 miles away that had the only one in the area (Kewanee , Illinois of all places?!)
The long drive with the non-functioning Camshaft position sensor really made me appreciate the change when I finally got the CPS changed.
I bought a few tools to do the job with since I'm staying in a hotel and didn't have my usual set-up with me.
Of course I was too impatient to let the car cool off enough so I had to wait until I could get my hands back there and get that bracket off (the one that's held on by the two 10 mm bolts)
David's idea of getting to know the area by feel was a good one. Having a mirror really helped visualize and learn the area to know what you were feeling around for when you couldn't see. The 5mm ratchet bit was great with a 1/4" stubby ratchet to get the 5mm hexbolt out of the sensor to allow removal.
I removed the old one from the harness, stuck the new CPS on and bolted it back in.
Repositioning the metal bracket was a bit tricky but I finally got it into place and re-seated the two prongs into the wiring harness box which rests above it. By this time the 10MM bolts had cooled sufficiently to allow for fairly easy positioning and starting into the holes- to be tightened with the 10mm socket and stubby 1/4" ratchet. After the the air duct was replaced along with it's filter box.
THe first start-up was still a bit rough but I revved it and let it idle for a minute or two before I tried clearing the codes again. After the warm up I cleared the codes and OH MY GOD IN HEAVEN I COULD NOT BELIEVE THE DIFFERRRRRRRRRRRRENCE!!
THROWN BACK INTO THE SEAT WITH THE SAME FORCE AS A SHUTTLE LAUNCH!
I am so happy! I hadn't realized the changed in power could be so dramatic. As a matter of fact I think I have to go back out and rip around a bit more as a reward.
THanks to all SO VERY MUCH for these valuable DIY tips.
Rich in St. Louis
