how many are installing their own ESS SC kit? - BMW M5 Forum and M6 Forums
Old 8th August 2009, 02:48   #1
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
i know i am, but i know there are 9 others on here who have kits coming in.
who is installing their own goods?
what clutch kit are you running with your kit?
-R
razahyde is offline   Reply With Quote
Old 8th August 2009, 04:22   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
-R
I'll be doing it with my buddy, he has done work for Renntech, so I am good hands. We will do some maintenance while the car is down for a couple of days, including time for the ECU to be reprogrammed.
I am going to run CNS. Only one that made sense to me.
gsfent is online now   Reply With Quote
Old 8th August 2009, 09:36   #3
midtwnman
Garage: 2000 M5 Silverstone Metallic
I hate you both...
midtwnman is offline   Reply With Quote
Old 8th August 2009, 15:13   #4
Super-saloon
Super-saloon's Avatar
Garage: e39 M5, Carbon Black
Originally Posted by midtwnman View Post
I hate you both...
Ditto!
Love to see some images as you install guys....
Rich
2002 Carbon Black e39 M5 Super-Saloon
Miltek Cat Back exhaust system
Miltek Racing 100 cell CATs
De-limited
Re-mapped (Superchips/Thorney stage 2)
AP Racing BBK
KW Variant 3
Super-saloon is offline   Reply With Quote
Old 8th August 2009, 17:32   #5
gsfent
gsfent's Avatar
Sales Feedback: (3)
Originally Posted by Super-saloon View Post
Ditto!
Rich
raza can do it over lunch, it will take me a little time to get it scheduled!
Old 8th August 2009, 17:43   #6
Blockdoc
Blockdoc's Avatar
Garage: 2003 Sterling Gray M5
FWIW,
Roman said it took their shop guys about eight hours to do it on my car...he said it took longer than expected because some of the parts had to be sent out for refabrication. He told me the next one they do will probably take 6 hours or so.
Evidently, replacing the fuel injectors with the higher flow ones in the kit is the most difficult part.
Brian
2003 Sterling Grey M5
ESS kit #1 with RK AUTOWERKS Upgrade! (RK/EVO software, Injectors, Fuel Pump)
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Aquamist HFS3/Howerton Engineering Tank (pre/post SC nozzles)
RK Autowerks CNC Plenum Plates
Blockdoc is offline   Reply With Quote
Old 8th August 2009, 17:46   #7
razahyde
razahyde's Avatar
did you have yours shipped out friday? i believe 5 sets went out friday, im number 9 or 10 on the list.
my estimated ship date is suppose to be this friday, we'll see how that goes. im going to push for express shipping so i can get the sucker in by the next weekend. i should have the V12 clutch wrapped up soon as it comes in tuesday.
Originally Posted by Blockdoc View Post
FWIW,
Brian
wtf the fuel injectors is the hardest part? this will be a cake walk then! LOL!!!
Old 8th August 2009, 17:57   #8
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
Roman just sent me a tracking number for my kit, so I should have it very soon. I will be installing it myself at the same time I install my RMS intercooler setup. Only makes sense to do that at the same time as the SCer, given that the RMS setup includes the CNC plenum plates and o-rings and bolstered aluminum plenum. I'm surprised to learn that installing the larger fuel injectors is the most difficult aspect of the installation, as I would think that would be plug and play. Anyway, I'm going to wait to install the water/meth injection. I need to send the kit out to have the seals upgraded to take 100% meth and to have a tank made that will fit in place of the spare tire compartment anyway, so that aspect of the installation will have to wait regardless.
I have a Rogue Stage 3 280mm v12 clutch kit with a JB Racing LTW flywheel (as yet uninstalled). I don't mind a little flywheel noise, and the entire setup was balanced, which if you talk to some of the more sophisticated tuners is the critical step that has to be taken to ensure that a 280mm conversion works well. Apparently, UUC does NOT balance their 280mm setups, so the tuners I'm referring to always do it themselves as part of a UUC clutch installation. The Rogue setup just struck me as the best alternative to the UUC 280 mm setup, and I was not willing to put up with the CNS break-in period, nor was the CNS flywheel sufficiently lightweight for my purposes. Also, one of the tuners I use and have had a good experience with in NoVa, funktionAuto, highly recommends this setup and has experienced poor customer satisfaction with the CNS setup based on the horrid break-in period. I have no doubt that the CNS setup is more durable than the Rogue, but I'll trade that durability for getting to skip the break-in period.
Probably going to do the installation over Labor Day if I can get my suspension work done and clutch kit in by that point.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
herrubermensch is online now   Reply With Quote
Old 8th August 2009, 18:19   #9
Blockdoc
Blockdoc's Avatar
Before you guys get all worked up, LOL....let me clarify.
I believe that he said replacing the injectors was the most time-consuming part. Remember that his kit was designed to be as "bolt on" as possible...that was the niche they were after.
In fairness...I have not even seen the installation manual. I had to extract all this info myself
I am anxious to compare notes with some other M5board ESS owners!
My headers are on...I pick up the beast Monday...and then the ECU is off to ESS for final reflash
Cheers,
Brian
BTW...the CNS clutch is awexsome at this point. It took about 1500 miles for me, but it now feels pretty close to stock (of course I have also learned to use it better). Money well spent IMHO
Old 8th August 2009, 18:43   #10
gsfent
gsfent's Avatar
Sales Feedback: (3)
I was travelling Thursday and Friday, mine should go out Monday.
Does anybody know if the ESS supercharger kit comes with everything included? T0RQUE E39 M5 and E52 Z8 Discussion 6 26th March 2009 15:06
Installing first Hartge Kit in Saudi Saudi_M5 E60 M5 and E61 M5 Touring Discussion 3 17th October 2006 01:06
ZEX 82021 NOS kit on ESS 540iA ESS540iA E39 M5 and E52 Z8 Discussion 2 10th February 2004 16:21
Need HELP re-installing M-Mobility Kit Wilkie E39 M5 and E52 Z8 Discussion 0 20th August 2002 01:33
Has anyone tried installing the Dinan suspension kit themselves? atomic80 E39 M5 and E52 Z8 Discussion 24 25th March 2002 22:44
