Ok, so here is the result from the dyno once I pulled the right fuses ( 17,30).
Its an exceptionally hot day ( 27c = 80F) here at least for finnish circumstances so I guess the output not being too great and after having read dynan's take on the matter, are still within the realms of normality. Our dyno tends to show quite conservative figure anyway as far as hp is concerned, torque is usually similar to those of other dynos I have compared.
Note that we use engine output and the DIN format to display the results. As its easy to convert this on this dyno computer I also included the output in terms of wheel power and your SAE format. (BANK#2 and #4) Another good thing with this dyno is that one can adjust the scale of the graph so as to accurately scale it to the revlimiter. Hence I I have included both 4th and 5th gear pulls.
the power losses are therefore only applicable to the engine output data. We measure torque in NM here but if you convert it to for your wheel output and sae it would be 318,9ft/lb for the 5th gear pull ( hope thats correct?)
Here are some more pics of the car on the dyno. Its a basic inertia wheel barrel type version. Note the fan housing is strictly patended and may under no circumstances be copied...
Index of /niko/mycorradoweb/m5e39silver/dyno
There is a dyno day at my premises next saturday with among others a couple of m5, so it will be good to be able to compare the output to them. Also I might have a different programme installed by then.
