Originally Posted by razahyde
i know the UUC has a little bit of chatter from the ltw flywheel. so while i have the tranny out i was going to change the fluid and wanted to know what the rest of you guys are running.
pertaining to the differential, is there any recommended fluid?
thanks
-R
There is only one way to 100% cure the rattle....use the stock (or dinan flywheel). You can do the Redline 75w140 NS (1.5L) to D4 ATF (.5L) mix, and it will stop the rattle until the gearbox is up to temp in very hot (TX, FL, AZ) climates. Unfortunately, redline tends to make the seals in the gearbox swell. RP syncromax does work fairly well, but does nothing for the rattle, and then there is always LTF MT2 (OEM fill). I've switched to RP, and just learned to live with the rattle....it really isnt that bad.
For the diff, you can use Castrol XJ (factory fill) or M1 75w140 (it has slip additives) and they work very well. I just tried RP Maxgear 75w140, and dont see any real difference from M1 (it even whines just slightly louder than with M1...somethng im not too thrilled about but I'll switch back when Im not feeling so lazy).
