Old 7th August 2009, 08:51   #1
firehire
firehire's Avatar
Garage: 2002 Bluewater Metallic M5
Send a message via AIM to firehire Send a message via Yahoo to firehire Send a message via Skype™ to firehire
First Oil Change on the "Beast"
Well, I have changed the oil on most of the cars I have owned, but with all of the horror stories of stripped pan bolts and other issues, I paid my indie for the first couple of oil changes on my "Beast".
After lots of research, I decided to buy a Mityvac 7300 and give it the old college try and attempt a DIY oil change. Well, first off I couldn't find a socket big enough to loosen the oil filter cap. I borrowed my neighbors strap wrench and got it off. I then hooked up the Mityvac through the dipstick tube and plugged my compressor in and opened the valve on the Mityvac.
I was pretty impressed, it started filling up the container and steadily extracted the oil. It has a 8.8L capacity, but I didn't find that out until the container was getting close to being full. I actually ran into the house and checked the manual on the capacity of the unit.
Once it was finished, (you can tell by the extraction tube because the oil was thinning out inside the tube) I replaced the oil filter and "o" ring. Now comes the tricky part. It states right on the top of the oil filter cap to torque to 25NM. I have a conversion table on my torque wrench, so that wasn't a problem converting it to ft-lbs. The problem was I didn't have a 36mm socket to use on my wrench.
I took a little trip down to AutoZone to see if the had a 36mm 3/8" drive socket. Unfortunately, they did not. They do have a wonderful tool loaner program. I was able to borrow a 36mm 1/2 drive socket. So, I went home and used my 1/2" -> 3/8" reducer and torqued the filter cap on.
I then added 7L of TWS, started it up, drove it around until the oil temperature was appropriate, came home and checked the level. Bada bing, job done. No leaks.
I will have to say that I didn't have to buy ramps or a low profile jack. I will say that this was the easiest oil change I have ever done. I just have to go and buy me a 36mm 3/8" drive socket before my next oil change.
That's my story and I'm sticking to it.
Curt
2002 M5 Bluewater Metallic/Black & Silverstone leather/
All options/MKIV NAV/Chrome OEM Style #65 Wheels/3M tint
/BT/Intravee II/AngeliBrights V3.0/TEC cupholder/smoked side markers/
DINAN Front Strut Brace/Shark Injector/Smoked taillights/Ultimate pedals/
BSW Stage 1 Upgrade w/Subwoofer package/e60 SSK/ZHP Shift Knob/
CF Kidneys/CNS Racing Cat-back exhaust/LED License lights/Euroclear Headlights/
Angeleye DRL's/HID Foglights/LED light upgrade/Dinan Stage 1 Suspension/
CNS Racing Clutch/ Sink drain/brake duct modification/ExoticsTuning CF diffuser/
ExoticTuning fog light covers/SuperSprint Headers
firehire is online now
Old 7th August 2009, 10:01   #2
chowdah
Garage: sweetness
Sales Feedback: (3)
Hand tight, aided by a rim of oil on the o-ring, should suffice on the filter cap. If you use a big adjustable wrench or other tool there, go slow and steady, brace the housing with your free hand, and minimize transferring the torque to the mounts.
chowdah is offline
Old 7th August 2009, 14:39   #3
Suro
Suro's Avatar
Garage: 2003 Carbon Black M5
+1, I had to replace my mounts a few days ago... about $30 and a pain in the *** to remove due to the bushings being broken.
E39 M5: still the car by which all others are judged.
Suro is online now
Old 7th August 2009, 16:58   #4
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Nice one fire...I did notice while repairing my own oil pan that the diptick tube does come down right over the low spot of the oil pan. Just behind that larger side bolt some people use. So I think you're right on target doing it this way. Sears has that 36mm socket you need by the way. Just so happens my R32 oil filter housing uses that same size. Was nice to see when I got the M that for once I didn't need to buy a new tool just to change the oil!
BTW is compressor mandatory w/ a MityVac?
Members:
If you want your oil pan repaired (see http://www.m5board.com/vbulletin/e39...rain-plug.html) instead of buying a new one or attempting the repair yourself PM me and we'll work something out. Thinking $60 profit is worth it. You pay all shipping of course. At the moment I have four remaining Timesert inserts looking for homes. If the demand is there I'll keep doing them. If not the tool goes on eBay minus one insert.
TMcNasty is offline
The Following User Says Thank You to TMcNasty For This Useful Post:
firehire (7th August 2009)
Old 7th August 2009, 17:09   #5
firehire
firehire's Avatar
The compressor is mandatory on the 7300. Mityvac does make a manual extractor with a "T" handle that you pump instead of using the compressor. The compressor just makes it easier.
Curt
Old 7th August 2009, 17:36   #6
Nabio
Nabio's Avatar
Garage: Jet Black E39 M5
Send a message via AIM to Nabio Send a message via Skype™ to Nabio
I would honestly unscrew your filter cap and redo it by hand. If you put it too tight then good luck getting it off next time around without breaking the mounts.
Jet Black 2000 M5
Nabio is offline
Old 7th August 2009, 17:45   #7
max95se
max95se's Avatar
Garage: '01 CB
drain
how is this compared to draining it though the drain plug? this is definitely easier and faster..
but can we get all the junk at the bottom of the oil pan?
max95se is offline
Old 7th August 2009, 19:20   #8
firehire
firehire's Avatar
I did a lot of research before buying the extractor. There were members of this board who have utilized both methods (extractor and drain plug). The information that I gathered from them is that there is negligible (if any) difference from extracting vs. standard method of draining oil.
Curt
Old 7th August 2009, 21:48   #9
Mike S.
Mike S.'s Avatar
Garage: "Bugslayer" 2003 M5 Titanium Silver
Send a message via AIM to Mike S. Send a message via MSN to Mike S. Send a message via Yahoo to Mike S.
I'm really thinking about one of those oil extractors. I don't suppose the 7300 will also double as a brake/clutch bleeder will it?
"Bugslayer" 2003 M5 - Powertrain: Magnaflow 14816, E60 545i Short Shifter Exterior: Xenonmatch Lamps, Stealth Auto Black Kidneys Interior: Hardwired V1, Ultimate Cupholders, OEM AUX Audio Input.
Mike S. is offline
Old 7th August 2009, 21:56   #10
firehire
firehire's Avatar
Yes, it does. It comes with a specific brake bleeder attachment.
Curt
The Following User Says Thank You to firehire For This Useful Post:
Mike S. (7th August 2009)
Changing brakes; Insurance company want to know the change to my "brake" horse power stumbo E39 M5 and E52 Z8 Discussion 31 2nd December 2008 00:45
says "engine oil low" after oil change, after a drive... redl1nerpm E34 M5 Discussion 21 1st March 2006 23:13
Nav "info" radius - can I set/change it? Redshift E39 M5 and E52 Z8 Discussion 3 8th February 2004 17:23
Does "sport" mode change ride stiffness? WIRELESS E39 M5 and E52 Z8 Discussion 2 10th February 2003 08:03
WEBMASTER - Why did "[IMG] code is OFF" suddenly seem to change on here? Aussie2U Off Topic Forum 4 1st April 2002 17:36
Page generated in 0.15228 seconds with 11 queries
