02 e39 M5 seat is all twisted up - BMW M5 Forum and M6 Forums
Old 4th August 2009, 04:01   #1
RJScotti
Garage: 2002 Gray M5 e39
My son was fiddling with the many power adjustments on the front drivers seat of my 02 e39 M5 last night. Somehow it is now not level (left side is slightly higer than the right) and the backrest is twisted (the left side is about 4" inches further back than the right side. Strangly this makes it nearly impossible to drive the car.
I've tried going the full range thru each of the adjustements but it still is all wacky. It's now in the shop for them to have a look. Anyone on the board ever have this problem?
RJScotti is offline   Reply With Quote
Old 4th August 2009, 04:38   #2
tristan
tristan's Avatar
Garage: M5 carbonblack
Yes,
but it was just on recline and would straighten when the seat was up. I just had to pull the seat back off to fix. Not a big deal
Shouldn't cost too much if you took it in.
Dinan Headers
Tubi Regular
ESSTuning
Ground Control
Dinan rear sway bar
TCDesign rear sway brackets
Stop Tech front BBK
Intravee II ipod interface and Alpine KCA-420i ai-net
V1/S1
tristan is offline   Reply With Quote
Old 4th August 2009, 05:07   #3
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Search on "twisted seat" -- it's there.
chowdah is offline   Reply With Quote
Old 4th August 2009, 07:30   #4
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
You can fix it yourself, it isnt impossible. Chowdah has it right, search for twisted seat...its about 1-2 hours worth of work
E55AMG2 is offline   Reply With Quote
Old 5th August 2009, 00:13   #5
M5 Cab
M5 Cab's Avatar
Garage: 2002 M5 Silver
My wonderful BMW service center wanted $1100 to fix this issue. Have made due for a year. WHere can I find the easy repair?
2002 Sterling Silver M5 with Black Sport Leather
Dinan Exhaust
Dinan Springs
Dinan Rear Antisway Bar
Koni Struts and Shocks
Beastmaster Rear Swaybar Brackets
PIAA HID Angel Eyes
PIAA HID Fog Lights
PIAA HID License Plate Lighting
Full Umnitza Xenon Interior Upgrade
Dice Ipod Adapter
M5 Cab is offline   Reply With Quote
Old 5th August 2009, 09:28   #6
dpbdc
dpbdc's Avatar
Garage: 2002 M5 C.Black, 1987 Jeep Grand Wagoneer Ltd.
Sales Feedback: (5)
As noted just above your post, search for 'twisted seat'.
Or click here -----> Twisted Drivers Seat - anyone experienced this?
Post #27, specifically.
dpbdc is offline   Reply With Quote
The Following 2 Users Say Thank You to dpbdc For This Useful Post:
M5 Cab (6th August 2009), RJScotti (19th August 2009)
Old 19th August 2009, 20:44   #7
RJScotti
Bigger problem
I pulled the seat out to perform the cable shortening procedure and found that it is in fact the gearbox that is the problem. Seems the cable is spinning at the motor with no problem but the bevel gear at the other end of the cable is stripped or otherwise disengaged. Dealer says it's a $1000 for the seat frame and no doubt it too will eventually have the problem again.
So here's my thinking. Advice requested.
- Racing seat? Better for track days but goofy looking for those trips to the mall with the kids. Also this will disable all the airbag stuff.
- eBay seat? Hard to come by, expensive shipping and again. Same problem will likely return.
- Custom machined gearbox. For $1000 I could get a machine shop to make me a billet gearbox to repalce the other end of that cable.
Any suggestions from this group of ?
Old 19th August 2009, 21:13   #8
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
You would actually be lengthening the cable, and shortening the sheathing.
Old 19th August 2009, 21:58   #9
RJScotti
Right. Shorten the sheith. That wasnt the problem. Put it all back together and now it sort of works. HAngs up once in a while but doesnt twist nearly as much. Doesnt seem up to the level of engineering in the rest of the car... well maybe the cup holder is of similar design.
Old 19th August 2009, 22:00   #10
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
There is a trick you can use to lengthen the cable itself, but it requires a careful hand to do so. PM me.
Twisted Drivers Seat - anyone experienced this? LEENA1 E39 M5 and E52 Z8 Discussion 35 28th May 2012 05:33
black kidney grills on, twisted hood?? psiggy E39 M5 and E52 Z8 Discussion 11 9th October 2008 08:00
Twisted. Jahangeer E34 M5 Discussion 18 14th July 2006 14:05
Twisted Turn of Events Ag Surfer Off Topic Forum 5 29th July 2005 14:00
Opps...hard launch twisted the drive axle 1badm5 E39 M5 and E52 Z8 Discussion 20 17th December 2004 02:19
