Side mirror issue / Reverse function - BMW M5 Forum and M6 Forums
Old 1st August 2009, 16:08   #1
Valkman
Garage: BMW M5 Avusblau
I don't know if it's a normal function on all M5's, but the RH mirror (on LHD cars) turns down to show the corner of the car when transmission is on reverse. However, the mirror stays down when I put it on some else gear and I have to lift it back manually from the switch.
If I do it again, it seems to remember the original position and will turn itself back again... but then again, after restart, same issue.
Is there some kind of learning procedure to be done for the mirror, so it will remember its place? The memory function on drivers door doesn't seem to help at all.
Valkman is offline   Reply With Quote
Old 1st August 2009, 16:16   #2
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
There is a switch that changes which mirror you are controlling. If you leave it to the left, the mirror doesn't dip, if you leave it to the right, the mirror dips each time you put the car in reverse, and then it returns when you take it out of reverse. That is the theory at least.
Mine does the same as yours 50% of the time. You can get it to return by putting it in and out of reverse and switching the switch while it's in neutral - saves having to reposition it. To be honest though, it's more of a hinderance than a help so I always leave the switch to the right to disable it.
If anyone knows a fix let us know!
100%Cocoa is offline   Reply With Quote
Old 2nd August 2009, 20:06   #3
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
Not a fix, but a known (and normal) quirk in the mirror operation is that if (assuming the switch is set for auto dip on reverse) you go from reverse to 1st gear BEFORE the mirror has finished dipping, the mirror will stay in the down position. Obviously this is not a common occurrence as the mirror does dip pretty quickly, so you may have different issue.
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is offline   Reply With Quote
Old 2nd August 2009, 20:55   #4
Valkman
Seems the mirror remembers its position after I've done the manual lifting of the mirror, but will not function after ignition is cycled off and on...
Old 2nd August 2009, 21:23   #5
Hakon
Hakon's Avatar
Garage: M5 Carbon 02
I find that if the mirror doesn't get time to go down fully when selecting reverse then it gets stuck in that position and won't come up.
I then have to select reverse again and wait till it goes down fully, stops, then it will come up to the preset position when out of reverse.
Hakon is offline   Reply With Quote
Old 3rd August 2009, 22:02   #6
my03M5
Garage: silver M5
Maybe a little OT but still related to the mirrors...when I unfold the mirrors the drivers side glass clicks back and forth a tiny bit a few times, maybe 4 or 5 seconds. It obviously stops, but does do this every time the mirrors are unfolded. Any advice appreciated!
my03M5 is offline   Reply With Quote
Side view mirror/reverse tilt operation Chessie E39 M5 and E52 Z8 Discussion 27 30th April 2012 02:42
Mirror Tilt on reverse Peter H E60 M5 and E61 M5 Touring Discussion 2 11th June 2007 04:38
Pass mirror does not tilt down in reverse??? Xcargo E39 M5 and E52 Z8 Discussion 11 26th July 2005 19:15
side mirror tilt in reverse et1bill E34 M5 Discussion 7 12th March 2002 13:01
bad mirror when in reverse ? gmm E39 M5 and E52 Z8 Discussion 6 9th May 2000 11:55
