Dealerships are not always the best place for a repaint or body repair. To be honest they are no better then an independent shop, and in many cases the independents are better. Most people for some reason always think dealer shops are better. Find a shop that is owner operated, that is where you will be the best deal and best quality work.
The way paint and body guys jump around you never know who is going to be painting your car when you decide to have it painted. Just do some research before you decide where to have the work done.
I would find an independent owner operated shop that uses top quality paint like ICI autocolor or PPG Global. Then I would find one that has nice equipment like a full down draft paint booth that is heated, one that keeps the shop fairly clean.
Here are a couple of things that some people have misconceptions about when it comes to painting a car.
1.First cars that are repainted are very rarely stripped down to the bear metal before repainted, most are just scuffed really good taped off and painted. The paint only needs to be striped when you have clear flaking and paint peeling off the car.
2. It doesn’t cost $4000.00 to repaint a car. A car the size of an M5 should be able to be repainted for about 2200 – 2500 dollars. It should look as good or better then new once completed. Now that is if there is no bodywork include in the job or if the car is staying the same color. Bodywork and changing color increase the amount for the job drastically. I would never recommend changing the color it take way to much work to have it done right and isn’t worth the cost.
Here would be a break down on an estimate to repaint an M5. This is just an example labor plays a big part in the cost. This is GA labor rate.
Paint labor time 30 - 34 hours x 34 dollars = 1020 - 1156
Paint Materials 30 hours x 22 dollars = 660
Wet sanding and buffing time = 250
About 6 hours R&I time = 204
There would be additional cost for striping the car. And other misc things
I would paint an M5 that need no striping or body work for about 2200 – 2300 that includes a lifetime warranty on the paint as long as you own the car.
BTW I own a shop in the Kennesaw, GA area, if anyone is interested in having his or her car painted
