Old 17th February 2002, 18:04   #1
racerX
racerX's Avatar
Garage: 2000 M5 Jet Black
My fan switch just fell off! Would that happen in an MB?
The rocker switch to increase/decrease the blower fan speed just fell in my hand! I tried to "snap" it back on somehow, but no go. It looks like it was held only by a small plastic tab in the center and that has broken off. I was travelling with a friend (an MB fan) who remarked, "see, that's the thing about BMWs. The build quality of the interior components has always seemed a little cheesy compared to MB. A Benz switch would never just fall off like that." Anyone have both BMW and MB with an opinion?
racerX is offline
Old 17th February 2002, 18:46   #2
JetBoy
JetBoy's Avatar
Garage: .
Send a message via MSN to JetBoy
Re: My fan switch just fell off! Would that happen in an MB?
That could happen to anyone. Never happened anything like that to me and my E34 is already 13 years but runs like the first day.
JetBoy is offline
Old 17th February 2002, 19:18   #3
basil
basil's Avatar
Garage: Anthracite
.Interesting, this must be somewhat of an issue with E39's - maybe other models as well.
My sister arrived the other day in her '99 540. The switch was lying below on the little black self. I took it and easily snapped it back on. In fact I didn't feel a snap but it seems to be fine. The car hasn't seen much use since though.
My own '98 540 had a similar problem when the switch was askew. With a few repeated pushes during the day, the switch reseated itself.
Check the rocker switch underside tabs for any breakage. If it's fine then who knows. It may snap back in on a subsequent the try. Good luck
Ps. I think I asked myself the same question regarding the quality of the two great German marques
basil is offline
Old 17th February 2002, 19:56   #4
robert47
robert47's Avatar
Garage: 2000 M5 LeMans Blue
B.S. - The fan button in my wifes former car (1995 MBZ E320 Wagon) would not just fall off, it would "eject" itself at ~25 mph, hit the center armrest, and end up hidden under one or another front seat so you had to crawl around and hunt for it! I would list all the other problems the car had, including 3 head gaskets, but it would exceed the limits of the server on this web site! Quality control in newer MBZ's has fallen drastically - hence their lowly rankings in J.D. Power Customer Satisfaction rankings (well below BMW'S and even Cadillac!!!)
robert47 is offline
Old 17th February 2002, 20:32   #5
MJ
MJ's Avatar
Garage: 2008 Space Gray M5
I have had 4 E39's and no problems with that button or any other interior component.
MJ
'02 Sterling
MJ is offline
Old 17th February 2002, 21:32   #6
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
Does this guy have a fleets of Mercedes and BMWs that he has done actual testing on, or doesn't he believe the market research that shows BMW ahead in quality?
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
Old 17th February 2002, 22:10   #7
Aussie2U
Aussie2U's Avatar
Garage: 2000 Avus Blue M5
RacerX, does your MB friend frequent MBNZ.ORG much?
I loved how the left hand turn signal / windshield wiper / high beam stalk snapped away on our '97 E420. I wasn't sure what was worse as we drove to the dealer to get it fixed - flashing people for no reason, squirting water until there was no more, or random turn signals staying on while driving straight. (Ok the last one is normal for Florida drivers...)
If I remember correctly it even needed a fan regulator put it in as the fan speed decided to stay constant one day. Of course the dash had to be removed to get at it, so that meant I got the added bonus of a "speedometer cable squeal" after it came back to us. It was kinda cool though I guess, as it would alter it's pitch the faster you would go! Sounded like a hamster on a treadmill.
Believe it or not, my wife & I feel our Alabama built ML430 is a better built vehicle than the german E420. Not sure if it means we got a lemon or what, but in our expierience, our '97 & '99 540i's were much better made cars than the Mercedes Benz E.
Aussie2U is offline
Old 18th February 2002, 01:21   #8
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
first off, relative to most cars either MB or BMW are excellent choices.
now as between the two.
I used to believe MB had better quality. But when I checked them out in the mid 90s I discovered that MB was beginning to make cars more towards what customers wanted and less to what their engineers thought their customers wanted. As a result I found that BMW interiors had better materials- and I believe this to this day. I also found out that BMW had actually better safety!
dont believe me, check this out:
http://www.highwaysafety.org/vehicle...html/97005.htm
now for 2000 MB made some changes to improve their ratings.
http://www.highwaysafety.org/vehicle...html/00027.htm
the thing I want to note here is that the conventional wisdom is BMW=performance and MB=safety was challenged by BMW a long time ago.
compare the 1997-2000 MB to the same for BMW
http://www.highwaysafety.org/vehicle...html/96029.htm
I never thought Id see MB playing catch up for safety. even their SUV doesnt get the best marks:
http://www.highwaysafety.org/vehicle...html/99012.htm
it does better than most but head and neck get an acceptable. a typical MB customer believes that MB= uncompromising safety. turns out to be not true. compare to the X5:
http://www.highwaysafety.org/vehicle...html/00023.htm
now to be fair, compare these to a common American car like the Trailblazer, which is sold to us as family transportation:
http://www.highwaysafety.org/vehicle.../html/0119.htm
overall it is marginal- for my family marginal dont cut it.
finally, between MB and BMW I dont think you can really make a bad choice, except in failing to do some research.
I know I left out the audi A6, but to check out how it did:
http://www.highwaysafety.org/vehicle...html/99017.htm
which is shocking given the money Audi charges.
All the best,
MEnthusiast is offline
Old 18th February 2002, 02:41   #9
Aussie2U
Aussie2U's Avatar
Wow ME, very informative! I know those tests are always there for looking, but I for one forget to go back to them for several years. I especially liked the Trailblazer test as I really liked the look of that thing with it's I6 engine. Oh well, now I know it's off my list.
Aussie2U is offline
Old 18th February 2002, 04:39   #10
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
I agree with ME and aussie2u about the comparisons, many repeat MB customers I've talked to over the last few years have commented on the decline in quality of the Mercedes.
I've owned both and the older mercs were built better than the technology of their times and the new ones are not. When I look at a merc today I see a nice car but not the great car it once was.
The quality is on the level of any other expensive luxury car like Toyota or Cadillac. I think Lexus(I don't like saying this) is probably better.
At the same time BMW has been increasing quality, design, materials, safety and growing as a car company, surpassing IMHO Mercedes.
I think Mercedes is aware of this and the next generation E-class may be better but it surely will cost more. I like their wagon and would like to get one. Their wagon is better than BMW in design.
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray
Jim Dolan is offline
Tech: Lidatek Installation - Lighted Rocker Switch? JFB M5 E39 and E60 tips & tricks 10 11th September 2002 03:23
Tech: Lidatek Installation - Lighted Rocker Switch? JFB E39 M5 and E52 Z8 Discussion 15 11th September 2002 01:07
BMW recalls for faulty fan motor switch AndyMenard E39 M5 and E52 Z8 Discussion 7 16th July 2001 01:02
Page generated in 0.16891 seconds with 11 queries
