Lifetime Fuel Filter....I Think Not. - Page 2 - BMW M5 Forum and M6 Forums
Old 13th July 2009, 21:27   #11
gzig5
Garage: 2000 M5 Carbon Black
Craig,
I'm missing the jack pad on the left front so I make sure the block of wood is not touching the cover. I haven't taken off the RF cover so I am not familiar with how the pad interfaces with the cover. Off the top of my head, I would say that if you removed the plastic plugs along the outside and the screws at front in the wheelwell, you should be able to slip the cover out from under the jack pad if it is restrained. Make sense?
Rountad, Thanks for the link!
Greg
gzig5 is offline   Reply With Quote
Old 13th July 2009, 21:33   #12
gregh86
gregh86's Avatar
Garage: M5 Sapphire Black
Originally Posted by captain_anonymous_2003 View Post
I've been reading about the fuel filter a lot and have one in my garage with the copper washer ready to go on. I've read the FAQ but I am not sure how you guys are jacking the car up. If you use the jacking point you can't remove the flap. Could someone please give me some detail as to how exactly you're lifting and supporting the car while you do this job. I have axle stands and a trolley jack in my garage. Are you jacking and supporting using the rear jacking point? Or somehow removing the cover before lifting?
Cheers
Craig
Before jacking the car up you need to pull out the flap of the filter cover that is tucked under the jacking block, it comes out fairly easy. Jack the car up as normal and place axle stand under front cross member. When job done and you have run the car to check for leaks put the cover back on let car down off the jack and tuck the flap back in.
Greg
gregh86 is offline   Reply With Quote
Old 13th July 2009, 21:36   #13
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
to swap the pad, all you need is 2 flathead scrwdrivers. One small one to pry the center plug out, and one larger one to pop the pad off the car. then pop it on the corner you need and replace the center plug. Very simple.
E55AMG2 is offline   Reply With Quote
Old 13th July 2009, 21:42   #14
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
I changed mine out at 50K - it actually looked pretty clean, but I definitely agree with changing it out at this interval.
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is online now   Reply With Quote
Old 13th July 2009, 21:47   #15
rountad
rountad's Avatar
Garage: LeMans Blue 2001 M5
Greg, you're welcome!
Changed Transmission and Differential Fluid today [Pictures]
I don't know if you've seen it, but Timmay's post above has a lot of good information in it. The main thing about the transmission fluid change is that you definitely need some type of pump to fill it.
The RP fluid, as many others have reported, is great!
Allen
Greg
Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated Ipod Touch, Rogue Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
rountad is offline   Reply With Quote
Old 14th July 2009, 01:10   #16
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
gzig5,
Good deal on the ff change...sounds like it was WAAAAY overdue. Don't be too shocked if your fuel pump gives up the ghost anytime soon. Fighting that filter for so many miles has surely shortened its lifepsan as many here have learned the hard way. Plenty of threads here re: drivabilty issues just like yours caused by failing fuel PUMP. So if your symptoms return...or car just won't start...the FP should be your prime suspect. Especially without codes or SES light present.
TMcNasty is offline   Reply With Quote
Old 14th July 2009, 02:06   #17
gzig5
Originally Posted by TMcNasty View Post
gzig5,
Good point on the filter. The stumble when cold seems a bit better so far, but I'm sure the pump was working overtime. I'll put that on the list. Gonna have to sell a kidney to get this thing up to snuff!
Old 14th July 2009, 19:48   #18
NogginM5Beast
NogginM5Beast's Avatar
Garage: 2002 M5 - Titanium Silver
changed at 64k, definite driveability improvement. Labeling this part as a lifetime part is absolute nonsense. Especially considering how easy it is to change. Why can't they include this part in the scheduled maintenance program on a car as special as this one? BMW should be ashamed of themselves.
NogginM5Beast is offline   Reply With Quote
Old 14th July 2009, 19:52   #19
NogginM5Beast
Allen
You do not. I filled mine using a tube I fed through the engine compartment and into the transmission fill hole. Gravity took care of the rest.
Old 14th July 2009, 19:56   #20
rountad
rountad's Avatar
Good suggestion! I hadn't considered that.
Changed your FUEL FILTER Lately? (filter cut open pic) SehrSchnell E39 M5 and E52 Z8 Discussion 64 23rd October 2011 17:37
Fuel filter B8 CSB ALPINABoard.com | BMW Alpina Discussion 1 29th November 2008 09:01
Bad Fuel / Filter everycredit E39 M5 and E52 Z8 Discussion 4 16th February 2008 16:33
Fuel filter analysis and help with fuel filter hose issue please KevinM E39 M5 and E52 Z8 Discussion 30 6th January 2008 01:55
Fuel Filter - A DIY? Nabio E39 M5 and E52 Z8 Discussion 14 7th August 2006 07:24
