S62 engine replacement/ failed connector rod bushing. - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 12th July 2009, 12:30   #1
alarm9
Garage: 2002 M5/ Dinan S package
Soooooo. It finally happened; you always hear about that guy who had his engine eat itself. Well here I am! Connecting rod bushing disintegrated into two large parts and many shavings and circulated through the oil system. (@49650 miles and Dinan S package by Chris Welch) Car is now at Irvine BMW awaiting an after-market rep to 'o.k.' or 'decline' the recommendation to replace the motor after conducting a 'investigation'. (Millenium warranty- Platinum Plan) Total estimated cost of repair= $35K. Needless to say, Millenium is attempting to find any reason to not perform this claim. Does anyone else have any experience with Millenium or any other warranty company and/or info on failed connecting rods, such as, how many E39/S62 engines have experienced this? Maybe after I drink myself to sleep, I'll wake up and find one of you has everything figured out on this... or has a f'ing magic wand!
alarm9 is offline   Reply With Quote
Old 12th July 2009, 12:49   #2
Michael_s
Michael_s's Avatar
Garage: 2010 X5M
No experience with the warranty company and hope that it works out for you. Curious how the car was driven over its 50K life. I suspect there are a lot of members with well over 50K miles without a warranty and are thinking, how did this happen? Any input you can offer would be cool. If you are not comfortable due to the open warranty claim, I understand. Either way, good luck!!
2007 M5
2007 Range Rover Sport SC
Michael_s is offline   Reply With Quote
Old 12th July 2009, 12:54   #3
Neil.D
Neil.D's Avatar
Garage: E39 M5 - Titanium Silver
Wow thats awful . Keep us updated...
2000 M5 Titanium silver
Neil.D is offline   Reply With Quote
Old 12th July 2009, 13:51   #4
doug
doug's Avatar
Garage: 2003 Sterling Grey M5
I don't suppose you are the original owner?
2003 M5 Sterling Grey/Black Full-leather, M-Audio, PDC
Day 1, Blue Ridge Mountains
Day 1, Biltmore Estate
OEM Brake Duct Upgrade
OEM 9.5" rims x 4 with 275/35ZR18 Pilot Sport PS2, metal value stems
OEM MP3 CD Changer, Bluetooth (12th Generation), Sirius Satellite radio, DVD Nav 2007.2
V1/StealthOne
Ultimate Pedals Titanium
Dinan Adjustable Rear Swaybar
Supersprint Cat-back race exhaust
UUC Evo 3 SSK/DSSR/Black Tranny Mounts
doug is offline   Reply With Quote
Old 12th July 2009, 14:03   #5
kindanutz
kindanutz's Avatar
Garage: 03 M5 Jet black
35K that sounds very steep.... get them to find a low milage replacement and swap...
kindanutz is offline   Reply With Quote
Old 12th July 2009, 15:28   #6
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
$35k? Sounds like a new crate motor, with plenty of profit margin thrown in!
Raza may have a spare used engine or two, contact him (razahyde).
Good luck!
Old 12th July 2009, 15:35   #7
wilsodh
wilsodh's Avatar
Rob bearing failures are the most common catastrophic issue with the engine. As has been written about fairly extensively here, one culprit is excessive rpm from an elevated engne speed limiter with a chipped engine, but other members have experienced spun bearings for no apparent reason. Of course one can always destroy an engine from an unintended downshift during 10/10's operation.
What the investigation will entail is interrogating the ECU for engine speed data. They will probably try to nail you on this if they don't nail you for the chip.
Lots of used engines out there.
Good luck -
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 12th July 2009, 15:58   #8
Lscman
Garage: E39
Extensive threads and detail here pertaining to connecting rod bearing failure. It would be impossible to regurgitate this info, so plz search.
Resolve never, screw genuine.
Lscman is offline   Reply With Quote
Old 12th July 2009, 16:41   #9
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
Sorry to hear about your motor being toast, I have less than 100% faith in warranties but good luck with yours. If you get a new motor out of the deal, don't mess around with mods, just go straight forced induction!
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline   Reply With Quote
Old 12th July 2009, 16:54   #10
Flybot
Flybot's Avatar
Garage: 2000 M5, 98 528i, 75 911S
How in hades can the engine repair cost 35K!? How much is the S pkg?
Flybot is offline   Reply With Quote
Failed smog test from no communication with OBDII connector any ideas? lwebb12 E39 M5 and E52 Z8 Discussion 31 30th June 2012 06:20
Differential Subframe Bushing Replacement VetteRacer E39 M5 and E52 Z8 Discussion 3 13th April 2009 20:25
Thrust Rod Bushing Kit Replacement- May have caused issues lemansmiami E39 M5 and E52 Z8 Discussion 2 5th June 2008 22:41
Help with Stock Shifter Bushing Replacement... rhouse181 E39 M5 and E52 Z8 Discussion 2 17th December 2007 04:10
Thrust arm bushing replacement question Qship5 E39 M5 and E52 Z8 Discussion 7 29th April 2007 00:29
