Old 10th July 2009, 23:14   #1
CMBeamerM5
CMBeamerM5's Avatar
Garage: M5 / Titanium Silver
Dealer installing parts but problem still remains...what would you do?
My oil temp was getting up to around 250 degrees and my water temp was getting near the red. Did a search on the board and found a simular issue with the oil sensor in the bottom of the oil pan. So I took the beast to my local dealer for an oil change and explained the problem and told the to check the oil sensor. They check it out and told me it was the pusher fan or electronic fan, so I told them to fix it. The next day they called me and told me the problem still was not corrected and now the problem was with the fan clutch, so I told them to fix it. They called me and told me the beast was fixed, I want to pick it up and paid them $1,300. Drive about 5 miles and both temp were up and the problem was not fixed. I brought her back and once again suggested that they look at the sensor. Now 5 days later the beast is still in the shop.
My question is, should I have to pay for parts when the dealer is not able to identify the problem? What would you do?
CMBeamerM5 is offline
Old 10th July 2009, 23:18   #2
churious
churious's Avatar
Garage: 2001 E39 M5, Imola Red
Sales Feedback: (6)
I would tell them you will cover the parts but not there labor. They should make it right if they miss diagnosed your vehicle. Although... stealers seldom make anything right.
2001 Imola Red on Black Lux with Titanium Trim
AFE CAI & AA CAI
TMS/Conforti Tune
SS Headers
OEM Cats
SS Xpipe
GTHaus Meisterschaft Cans
Dinan 3.45
Dinan S2 Suspension
Dinan Strut Tower Brace
Dinan Rear Sway W/ Beastpower Brackets
Rogue SSK w WSR
PS2's
churious is online now
Old 10th July 2009, 23:37   #3
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
1300 for sensor install and electric fan...wow
razahyde is online now
Old 10th July 2009, 23:43   #4
CMBeamerM5
CMBeamerM5's Avatar
They did not replace the sensor nor have they identify that the sensor is the problem. I just suggested that they check the sensor because that was the fix for a simular problem that someone has on this board.
Old 10th July 2009, 23:58   #5
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Is this Hendrick? Ouch. For $1300, instead of a new stock fan and fan clutch, you could have had a new Zionsville radiator set up. I'd tell them to stop throwing parts at it and diagnose/fix the problem.
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 11th July 2009, 00:04   #6
CMBeamerM5
CMBeamerM5's Avatar
Yes, ECB...it is Hendrick. They have always done a great job and they have serviced my BMW's for more than 10 years now. I still feel they will do the right thing, but I don't feel I should have to pay for parts that have not corrected the problem. If not, I will start to look of a good indy here in Charlotte.
Old 11th July 2009, 00:14   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
They are the pros and they misdiagnosed (unless you believe all those parts were also bad).If you don't have an agreement quickly about how to handle it, I would contest the credit card charge. It will get their attention.
And then as mentioned by churious, you can agree to pick up the parts for the things that didn't help (which is still generous, but reasonable).
BTW, most states require a signed off work order for the dealer to get paid. Never sign a blank estimate. Don't know what the rules are in your state.
Good luck getting it sorted.
gsfent is offline
Old 11th July 2009, 01:28   #8
android604
Garage: 2000 M5 Silver
Hi,
I would guess your water cooling system doesn't have pressure - replace rad cap. Or your thermostat is stuck partially or fully closed - replace thermostat. Third possibility is the water pump is dead.
If both Oil temp and water temp climbing, it isn't a sensor because the chances of two seperate sensors failing at once is low. So the conclusion is the problem is cooling system.
As for the Fan's... one fan is enough to cool the engine. So again, the chances of both fans dying at the same time is pretty slim.
I would present these arguments to the SA or the manager and ask for a refund and re-diagnosis of the problem... really bad service.
Andrew
android604 is offline
Old 11th July 2009, 10:39   #9
jt2ma71
jt2ma71's Avatar
Garage: Alpine White E39 M5
Its hard to diagnose without more information. Is the car indeed overheating or is it showing it is? I would have reasons to believe the oil temp and coolant temperature to be unrelated, but it seems a little to convienent. Maybe your Thermostat is toast!
Im not sure if these things have internal oil coolers, I know on 05 Pathfinders a common issue is the tranny cooler to leak and because its internal it leaks eitehr into the radiator or the coolant leaks into the tranny. Both of which is not a good mix.
Working at a dealership, if we mis-diagnose the problem we will either
A). Charge for parts only that were replaced because of the mis-diagnose
B). Remove the parts at the company cost and install the old part.
Its the only right thing to do, why should the customer be held responsible for the technicians lack of diagnosing skills? If he properly invesitaged the issue, and tested the old part to verify it was indeed not in working order, really there should be very little mis-diagnosing. Personally for any car that has an over heating complaint, check to see if theres coolant in there, if there is, check the thermostat. Some are fail-safe meaning they stay open, some fail in the closed position. Yours sounds like it could be a thermostat issue, because it normally takes about 5 minutes to fully warm up, right when the thermostat should be opening, perhaps the coolant temp is getting that high, the oil temp is soaring up because of it!
2000 Alpine White M5
Performance: Custom CAI, Tubi Exhaust, Open Brake Ducts, UUC Evo3 + DSSR
Exterior: Euro Mirrors, Black kidney grilles, MY01+ Updated, Mtec 3W AE, Altec retractable license plate
Interior: 16:9 Nav, MK3 Navigation, MY01+ dash, Silverstone Leather
Wheels: Volk CE28N Time attacks 19x10.5 275/30/19, 19x8.5 245/35/19 Pilot Sport PS2
1999 Ranger XLT 4x4
2" Lift, 33's, 4.10LSD, Locked front hubs
jt2ma71 is offline
Old 11th July 2009, 20:08   #10
ard
ard's Avatar
Comments on covering your butt in the future:
1. I am VERY specific at what I have the SA write in the "Complaint" on the work order. They usually employ vague language, I like to be more specific.
2. When I sign a work order I add "No verbal approvals permitted, written approval required- fax to xxx-xxxx".
3. Then, when they call you and give you the old "well, we've got bad news" you can discuss it, then say 'fax me the document to approve the increase." At this point, one can then add "Approval only valid if work fixes reported complaint" onto the page, sign it and fax back. What will they say? "No, we won't do the work under those conditions"? ...proceed from there.
At the end of the day, all the verbal discussions with the dealer are worthless- in court, or with the dealership management, or with BMWNA, the written documents will prevail. I make sure **I** control what goes onto the docs.
Unless the SA is a bud....
A
ard is offline
The Following User Says Thank You to ard For This Useful Post:
gsfent (11th July 2009)
problem since installing new mafs oltarmac E39 M5 and E52 Z8 Discussion 9 18th June 2009 02:44
Problem installing Angel iBrites Olyar15 E39 M5 and E52 Z8 Discussion 8 20th June 2008 02:22
DYNO sheets after installing performance parts? KingM5 E39 M5 and E52 Z8 Discussion 17 13th May 2006 11:32
Installing Hartge parts? khalid E60 M5 and E61 M5 Touring Discussion 4 15th February 2006 00:12
Vanos problem...an obvious problem which dealer says aint there..help needed Adam E39 M5 and E52 Z8 Discussion 10 24th July 2002 22:15
Page generated in 0.15457 seconds with 11 queries
