Old 8th July 2009, 05:27   #1
Tortuga
Garage: 2000 E39 M5 Silver/Black
Oil change on Ramps
How much (if any) oil do you miss draining if the operation is done with the front wheels on rhino ramps?
00 E39 M5
Sunshades Ti Silver Black Interior
Inspection II Done; Replaced CPS; Plugs; Lambda Sensors;Fuel Filter; Goodyear F1 GS D3s; Beastpower rear sway brackets; X5 Thrust Bushes; Hella Angel Eye upgrade; IATS Relocation Kit; iBrite v3.0 installed; 10w60 ONLY; Supersprint Magnum Mufflers; Supersprint Cats, Supersprint Headers, Conforti 'Shark' Software, MKIV Nav, 16:9 Wide Screen. Bilstein HD Shocks. '02 steering wheel, ABS Module Replaced 80k, Alternator 78k; NXT OIL @88k; F1 DS G3s replaced with Goodyear F1s MUCH better. F1 DS G3s were disappointing, were great on the roadster.
Ex Bimmers
03 325 xiTA (Ex W...)
99 MZ3
90 M3
73 2002 tii (miss this one goofy linkage and all)
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...holy
Sh*t . . . what a ride!"
Tortuga is offline
Old 8th July 2009, 11:51   #2
midtwnman
Garage: 2000 M5 Silverstone Metallic
Do you mean how much oil is still left in the pan? Or how much oil do I miss getting into the drain pan and onto my driveway? Either way it's not much
midtwnman is offline
Old 8th July 2009, 14:16   #3
Beemer Guy
Beemer Guy's Avatar
Garage: 2003 LMB Beastie
Sales Feedback: (6)
You will miss 0.6391124 liters of oil.
So, seriously, you expect an answer on this when we don't know the height of the ramps, if the surface upon which the ramps are placed is itself level, what kind of wrench you are using to remove the drain plug and most importantly, what color is the car?
What I do is change the oil on on a slight hill so that when I drive the car onto the ramps, it's basically level.
Ever notice that when you drain the oil, it can take an hour before it stops dribbling out? Either the car has an enlarged prostate, or it's all of the oil that was in the upper end of the engine making its way through all the passageways and channels down into the sump. Do you think when the dealership or a quick-change place changes the oil, they wait for all that to come through? Hell no. So you're not doing any worse than they are, as far as leaving that old nasty disgusting dirty oil in your engine.
HTH,
Michael
2003 LMB M5 R.I.P. 01/02/08
2008 Jet Black 335 Coupe (replaced the M5)
2008 Namibia Orange R1200GS (hence the handle "Beemer Guy")
Beemer Guy is offline
Old 8th July 2009, 16:44   #4
chowdah
Garage: sweetness
Sales Feedback: (3)
Short answer: Not much more than if the car was perfectly level.
Long answer: Anecdotal evidence.
I change my oil the way you have described. Each change, I measure how much comes out, and how much I put in. Typically I drain 6.0-6.5qt, and fill 7qt. Before I commence my change my dipstick generally reads <1/3rd. After my change I like my dipstick to read just over top line. Why? I'm quite paranoid about stripping my drain bolt, so I torque lightly, and diligently monitor dipstick (by the book) and bolt (tighten as needed) for subsequent trips. Once satisfied by enough samples, I siphon/pump via dipstick tube to bring to top line.
chowdah is offline
Old 8th July 2009, 18:32   #5
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Not a lot, but if you are worried about it, lift the car using a jack, put it in the ramps while you remove the plug, lift it to remove the ramps and then drain it level.
I can't imagine it would make more than an ounce of difference...
d-
DouglasABaker is online now
Old 8th July 2009, 19:59   #6
jjc1843
jjc1843's Avatar
Garage: 2000 M5 Carbon Black
Send a message via AIM to jjc1843
The flat oil pan on the S62 engine needs to be drained with it horizontal. Any angle will capture some oil in the pan. It will be more than an ounce-probably closer to 4-8 ounces. All a matter of geometry.
ARD's method for draining is ideal--jack on side, pull the drain bolt, lower car back down. Need a low profile drain pan.
I also pass a rag through the oil filter cannister bottom to get every drop out. Over the top--yup, thats just me.
Joe
'00 E39 S62 ///M5 Carbon Black/Caramel
AA CAI
UFM IATS Relocation Kit
SuperSprint Headers
Bassani Racing Cats-Custom Tubing
Tubi Cat Back System
Powerchip 93
UUC Lightweight Flywheel
UUC Stage III Clutch
Rogue Engineering Tranny Mounts
3.45 Diff KMS Ring & Pinion Swap
TC Designs Rear Swaybar Brackets
Royal Purple Syncromax Tranny Fluid
UUC SSK
UUC DSSR
'95 525i Black/Parchment 195K Eibach/Billstien/Power Chip [Sold!!!!]
jjc1843 is offline
Old 8th July 2009, 20:18   #7
DouglasABaker
Poor choice of words - I meant it wouldn't matter at all, not that it literally would only leave 1 physical ounce. You could leave a quart and it wouldn't matter (unless you were changing your oil every 50K miles, in which case you better not miss any).
Rag around the oil filter bottom, huh? I'd be worried about leaving particulate behind in the chamber, but you are obviously a bit more anal about it than I am so I suspect this is not a risk for you
d-
Old 8th July 2009, 20:30   #8
jjc1843
jjc1843's Avatar
Doug:
Exactly. I am ridiculous when it comes to some things--call it OCD. I get what you mean about oil replacement--a few ounces of 4500 mile oil ain't gonna hurt.
Joe
AA CAI
SuperSprint Headers
Powerchip 93
UUC SSK
UUC DSSR
jjc1843 is offline
Old 8th July 2009, 22:16   #9
-BEASTMW-
-BEASTMW-'s Avatar
Garage: Silverstone '01 M5
Why not just use an extractor? Easier job and car stays level.
2001 M5 - Silverstone/Blk
Dension iPod Link
mk4 Nav
E60 SSK w/UUC DSSR
Magnaflow 14816s
-BEASTMW- is offline
Old 9th July 2009, 05:10   #10
MrCrashRR
Garage: 2003 Alpine White M5
over- filling the engine can cause increased crankcase preasures that do more harm than having the oil slightly under. I would really try to not make it a habbit to over-fill. Not trying to give you a hard time, but I've seen far far more problems as a result of an over full engine than I've ever seen on an under filled engine. You can always pull the plenum and see if you are spitting the extra into the intake.
2006 Phantom Grey Tundra 4dr
2004 La Mans Blue CBR1000rr track bike
MrCrashRR is offline
Rhino Ramps Review chowdah E39 M5 and E52 Z8 Discussion 53 6th May 2009 17:49
Backing Up on Ramps kosmo E39 M5 and E52 Z8 Discussion 8 27th March 2009 21:36
Screw ramps... kris Off Topic Forum 3 24th May 2008 11:42
Car ramps that won't slip M5CCIE E39 M5 and E52 Z8 Discussion 53 12th November 2007 19:51
Rhino Ramps for M5 V-10 4 Me E39 M5 and E52 Z8 Discussion 1 16th November 2002 09:35
Page generated in 0.15487 seconds with 11 queries
