Old 9th July 2009, 06:31   #11
troym
Garage: 2002 M5 Ti Silver
I use the extractor as well. So much easier!
troym is offline
Old 9th July 2009, 07:50   #12
blackxs
blackxs's Avatar
Garage: Black M5
Have you considered having it going downhill on a driveway or similar surface so that the raised front will be balanced out and the car will sit level?
blackxs is offline
Old 9th July 2009, 07:56   #13
reds2
reds2's Avatar
Garage: 01' Anthracite Beast
Pour a little new oil in when the bolt is out and when it comes out the bottom, you new it's clean.
reds2 is offline
Old 9th July 2009, 08:20   #14
chowdah
Garage: sweetness
Sales Feedback: (3)
Originally Posted by MrCrashRR View Post
over- filling the engine can cause increased crankcase preasures that do more harm than having the oil slightly under. I would really try to not make it a habbit to over-fill. Not trying to give you a hard time, but I've seen far far more problems as a result of an over full engine than I've ever seen on an under filled engine. You can always pull the plenum and see if you are spitting the extra into the intake.
To be doubly clear: I stated "just over top line" which is to say barely over. Moreover, I qualified that with the remainder of my post. Perhaps a re-read is in order; it could have saved us both some typing.
No one is advocating an effective overfill, which ironically is more likely when a typical "professional" oil change vendor puts in the wrong amt of oil by +1qt (e.g. ignorant to M62 vs S62 configuration). That's the real scare. Never mind the additional concern that a "professional" is also more likely to strip your pan with the bolt.
chowdah is offline
Rhino Ramps Review chowdah E39 M5 and E52 Z8 Discussion 53 6th May 2009 17:49
Backing Up on Ramps kosmo E39 M5 and E52 Z8 Discussion 8 27th March 2009 21:36
Screw ramps... kris Off Topic Forum 3 24th May 2008 11:42
Car ramps that won't slip M5CCIE E39 M5 and E52 Z8 Discussion 53 12th November 2007 19:51
Rhino Ramps for M5 V-10 4 Me E39 M5 and E52 Z8 Discussion 1 16th November 2002 09:35
Page generated in 0.09770 seconds with 11 queries
