Subtraction by Addition: CHECK! Sometimes I hate my car
So last month (maybe 2 months ago?) I dynoed a low 326whp and 330ftlbs when I had Dinan intakes, Magnaflow Mufflers and Dinan Tune.
Today I dynoed (granted it was over 90 degrees) 321whp and 338ftlbs at the wheel. Since the last dyno I went with Borla straight-thru mufflers, delete my resonator's, TMS Race tune and Magnaflow high-flow race cats.
I'm simply at a loss as to what is wrong with my car (if there is even anything wrong). Maybe I'm reading into the dyno too much but I like to see results after spending over 1k on upgrades.
A buddy on here and I raced our M5s against each other and we were basically even. His mods are Dinan 3.45, AA Intake, TMS Tune, SS Cans/XPipe. Here is the footage from that night. BMW E39 M5s Comparing Their Cars on Vimeo
We will be doing another race tonight from a 1st gear roll as all of these took place from 2nd and 3rd gear rolls.
2001 Carbon Black on Black M5 (140k)
Dinan Intakes SOLD
TMS Race Tune
Borla Turbo Muffler
Resonator Delete
Magnaflow Race Cats
Rogue SSK
Dinan Rear Swaybar
Dunlop Z1 275s on all corners
BFG R1 265s for Auto Cross on all corners (FOR SALE)
StopTech Slotted Rotors
Axxis Ultimate Pads
TMS SS Brake Lines/ATE Super Blue Fluid
Absent Splitter
Auto Cross or HPDE your M5 and want to protect the front bumper? Let me know! Absent Splitters for $75 Shipped. 3 left.
The WHP, while slightly lower than published specs, is still well within the "normal variance" for our beasts. Numbers I have seen around here foe expected variance in the S62 motor are +/- 10%. It could be the dyno...or just the fact that your beast is closer to the lower end of the specturm. None of the mods you describe reliably contribute HP...especially on a dyno. The just improve the driving experience.
Hope this helps (and didn't just make you feel worse)
Brian
__________________ 2003 Sterling Grey M5
Dinan Free Flow Exhaust, Dinan Rear Sway Bar Super Sprint Headers Custom tuned by ESS
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around) Supercharged by ESS!! (Kit number 01)
What numbers were you expecting? If you were expecting 400, like factory specs, then that's crank HP, not wheel HP (which is what a dyno reads).
How are your mafs? How's your fuel filter? Did you pull the fuses that control ABS?
hehe I know about BHP and WHP lol.. I was expecting at least 330 or 340.
MAFs are OEM with about 3k on them from Bimmerzone. Fuel filter gets replaced twice a year and this one has about 5k on it.
Pulled fuse 17 and 30.
Dinan Intakes SOLD
TMS Race Tune
Borla Turbo Muffler
Resonator Delete
Magnaflow Race Cats
Rogue SSK
Dinan Rear Swaybar
Axxis Ultimate Pads
Absent Splitter
Brian
I understand it's within that 10% range but I would have figured adding those mods would have helped, not hurt my WHP on a dyno. The dyno was a dynocomm. Same one I previously did 326 on.
Oh I should note too that my car has nearly 137k on it
Dinan Intakes SOLD
TMS Race Tune
Borla Turbo Muffler
Resonator Delete
Magnaflow Race Cats
Rogue SSK
Dinan Rear Swaybar
Axxis Ultimate Pads
Absent Splitter
Did you dyno the car before the mods? If not, then you can't really be sure that those items actually hurt your dyno numbers.
Yes I did... I did 326whp 2 months ago. Not to be an ***, but did you read my first post or was I unclear? Because I'll correct it if needed
Dinan Intakes SOLD
TMS Race Tune
Borla Turbo Muffler
Resonator Delete
Magnaflow Race Cats
Rogue SSK
Dinan Rear Swaybar
Axxis Ultimate Pads
Absent Splitter
DOn't lose too much sleep over SMALL changes on a dyno. Read Steve Dinan's white paper on dynoing modern cars. He basically shows that an operator can pretty much choose what HP to come in on.
5 whp change on a dyno is VERY insignificant. That's why many laugh when an aftermarket company clains 5 or 10 HP from a mod...it's literally impossible to show a difference.
In this case...it is possible that the exhaust mods actually hurt your performance. The loss COULD be real.
Cheers,
Brian
Ultimate Pedals
Cheers,
Brian
And that's what I'm afraid of...Looking at the Borla mufflers, they're basically straight-thru so I would have thought torque loss as a possibility not HP like it was. And removing the resanator's and adding the high flow cats to replace my OEM 135k cats I again thought would have helped and certainly not hurt. Maybe a stock car is a healthy car haha.
Dinan Intakes SOLD
TMS Race Tune
Borla Turbo Muffler
Resonator Delete
Magnaflow Race Cats
Rogue SSK
Dinan Rear Swaybar
Axxis Ultimate Pads
Absent Splitter
The temperature difference between 2 months ago, late spring, and now, summer, would probably be enough to give that 5hp difference.
If not, I would blame lack of backpressure in the exhaust system from your new exhaust setup and the tune could be less than ideal.
If you dynoed them back to back, making sure the temperatures were the same, I would blame the mods. But from the sounds of it the temperature variance is to blame.
