Old 4th July 2009, 01:42   #1
slowcar
slowcar's Avatar
Garage: 2000 m5 blue
factory software in perf car?
Can you use factory software safely with headers,factory cats back in, cams, ?
Finally got car all fixed had to get new dme because of issues, i am selling
car to a guy now that wants factory software. Is this safe will the
computer compensate for extra fuel needed for cams and headers?
thanks for help
3.91 koala ms quaife diff
supersprint headers, cats, mufflers
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
relocated temp sensor
ss brake lines
schrick cams
ground control coilovers
strong strut brace
zionnsville rad w elec fan
slowcar is offline
Old 4th July 2009, 01:49   #2
blackxs
blackxs's Avatar
Garage: Black M5
With headers and an intake or exhaust, you would probably be ok with the stock computer.
With cams I would not. Either uninstall them or explain that the software allows the cams to work as they should
blackxs is offline
Old 4th July 2009, 02:03   #3
slowcar
slowcar's Avatar
I think i am going to hook up air / fuel meter like in my 930 and just see if between 12.5-14 will be good to go.
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
ss brake lines
schrick cams
strong strut brace
slowcar is offline
Old 4th July 2009, 02:13   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
in my car, i got an ses light and the car ran poorly. I had to run factory software for a short period of time for a bmw software update that was being mandated by the california dmv. Got the software update, then drove the car to dinan to get the software back.
why would a buyer of a heavily modified car want factory software that doesn't match the mods? That makes no sense.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
The Following User Says Thank You to mottati For This Useful Post:
jclyman (5th July 2009)
Old 4th July 2009, 03:01   #5
slowcar
slowcar's Avatar
Headers, gears these things dont mess with reliability like software.
I told him to just get factory cams i am giving him put back in factory cats which i am putting back in for him...I found another post on this forum where guy had mods and software he put factory software and made more power and af ratio was a lot better. Who knows, i think once you start changing nothing is same. Just save and buy faster car. I have a 930 but old school no computer easy to make go fast no place for check eng lite. I would bet that saftware would only give my car maybe 20hp anyhow. The computer must be able to compensate for cams and headers. I had bully dog in my excursion diesel you install works great for about 45-60 days then shifting starts to act up. Uninstall software drive for 5 min then download bully and you are fing for another 2 months, why? With all the lies out there about aft hp claims you totally trust software guys. I watched a guy guy a aem computer and try and make his own saftware and this dude was a smart buy everynight for 2 months finally got idle,cold,hot starts right rest was barely livable. I think manufacturers have huge rd in software, and too many places to screw up..i just want to get car going and sell
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
ss brake lines
schrick cams
strong strut brace
slowcar is offline
Question regarding Dinan S2 software with factory intake? Jasper E39 M5 and E52 Z8 Discussion 4 8th August 2006 01:30
Supercharger comparo - perf bmw mag racer_xbr E39 M5 and E52 Z8 Discussion 2 15th April 2006 07:26
Free M-Experience at BMW Perf. Ctr in SC trippstadt E60 M5 and E61 M5 Touring Discussion 9 3rd February 2006 17:32
M5 clutch vs. Other hi-perf. clutches?? HotRod E39 M5 and E52 Z8 Discussion 5 16th November 2001 17:18
Interesting Perf. Info KKelly E39 M5 and E52 Z8 Discussion 7 2nd November 2000 05:31
Page generated in 0.10797 seconds with 11 queries
