Old 3rd July 2009, 21:15   #1
Craig T
Garage: E39 M5 in Carbon Black with Caramel Interior
Oil Temp Running High
Hi
My engine oil temp is running too high.
I had to replace the Oil Level Sensor at the end of Feb during an Oil Service because the sensor was shot. After a week or 2 car threw it SES because it was running to cold. So, I replaced the Thermostat.
Since replacing the thermostat the Engine Coolant Temp has been fine, remaining at the 12 o'clock position when cruising but the oil temp varies from 100degC to approx 115degC. When the oil temp gets above 105/110degC I then receive a warning that to "check engine oil level" - of course when I check the oil level is fine.
Due to the car running to cold for a prolonged period of time, looking back it had probably been running too cold for a couple of months. I decided to replace the oil 4 weeks ago (approx 2000miles). But the engine oil is still too hot.
From what I recall, the Oil Temp used to run at about 85-90degC.
Any ideas what could be causing this?
Blockage to the Oil Cooler?
Stuck Valve within the Cooler?
Bad sensor?
cheers
Craig
PS: Please note that I did use the search facility first, but could see any posts that seemed similar.
Craig T is offline
Old 3rd July 2009, 22:00   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
You replaced the oil level sensor / thermostat and now your car is running too hot. Replace your oil level sensor again, since it is also the temperature sensor. I suspect you got a bad one.
the thermostat is unlikely to be involved. It could make your water run a bit warmer, but not much (a few C).
IF it is NOT the sensor / temperature sender, then you probably don't want to think about the alternative, as it will involve replacing some combination of radiator, water pump, and oil intercooler. Which one would be difficult to diagnose.
d-
DouglasABaker is online now
Old 3rd July 2009, 22:15   #3
Cemessi
Cemessi's Avatar
Garage: The 39th M5
I've had 3 M5's. All have run at the 80-85C position when driving normally. The highest I've had any of them is 125 on a track.
Cemessi is offline
Old 5th July 2009, 17:36   #4
nightkrawler
nightkrawler's Avatar
Garage: Lemans Blue M5
you have another bad oil level/temp sesnor. the level part of the sensor works on heating/cooling of the sensor. the dme heats the sensor to a temp higher than the surrounding oil, then measures the time it takes for it to cool back down. if there is not enough oil in the crankcase it wont cool correctly and hence you get the check oil level message. i doubt you have a blockage in the oil system as then you'd have a host of other problems. these cars dont really have an oil "cooler" in the conventional terms. its an oil to coolant heat exchanger under the intake.
nightkrawler is offline
The Following 3 Users Say Thank You to nightkrawler For This Useful Post:
100%Cocoa (7th July 2009), chowdah (5th July 2009), m5 ver (18th July 2009)
Old 6th July 2009, 23:26   #5
E55AMG2
E55AMG2's Avatar
+1, I had the same thing happen.
E55AMG2 is online now
Old 11th July 2009, 19:57   #6
Craig T
Thanks Guys,
My first thought was just a faulty sensor, but wanted to bounce it off those more experienced.
I'll order myself a replacement.
cheers
Craig
Craig T is offline
Old 14th July 2009, 15:13   #7
noxcape
Garage: Hellrot M5 E39
Make sure the coolant level (when cold) is at the mark. If it is 2-3 cm lower than normal you can have the oil temp higher. That happend to me. Now the coolant is at correct level and .... smiles ... everything goes right!
My 2003 BMW M3 E46 SMG - Imola Red
My 2003 BMW M5 E39 (BMW Individual - Fueller Hellrot)
Ich liebe mein Europa!
noxcape is offline
Old 24th July 2009, 18:24   #8
Craig T
Thanks noxcape,
Checked the coolant level a couple of days ago, it's fine, dead on the cold mark.
cheers
Craig
Craig T is offline
95c oil temp... too high? WMWNWMN E34 M5 Discussion 9 8th August 2008 20:25
Oil temp running high doug E39 M5 and E52 Z8 Discussion 13 6th September 2007 06:33
Proper Oil Running Temp ncaldiero E34 M5 Discussion 8 1st August 2007 00:04
Cutting out with high outside temp JohnR E34 M5 Discussion 0 12th August 2005 01:00
Is my oil temp too high? Deanger E39 M5 and E52 Z8 Discussion 4 14th January 2002 21:03
Page generated in 0.12763 seconds with 11 queries
