Old 16th June 2009, 07:47   #1
slowcar
slowcar's Avatar
Garage: 2000 m5 blue
misfire fixed
Finally after changing everything, talking to a lot of people. Well my mechanic which since installed said the new flywheel was the issue he was somewhat correct. The reluctor ring is just a tiny bit larger in diamater than a uuc and factory which are the same size. The cns
flywheel reluctor ring was just a little larger so when you reved up or heat got into unit it just barely hit the bmw sensor. The smart mechanic Viteks auto (cALGARY ALTA) will finish putting car together tomorrow and i will get car back. I hope this helps everyone else that runs into this 1356 misfire. Yeah now i get car back, lets see what it can do at the track in a week or so have to break in new clutch...
3.91 koala ms quaife diff
supersprint headers, cats, mufflers
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
relocated temp sensor
ss brake lines
schrick cams
ground control coilovers
strong strut brace
zionnsville rad w elec fan
slowcar is offline
Old 16th June 2009, 08:06   #2
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel
No wonder that was so hard to resolve! Congrats and best wishes with your new clutch.
Kevin
2007 M Coupe, Silver/Black
KevinM is offline
Old 16th June 2009, 16:00   #3
captiva
Garage: 01 M5 Carbon Black
Which track, Race City, we'll be there in 2 weeks
captiva is offline
Old 16th June 2009, 16:16   #4
slowcar
slowcar's Avatar
Yes are you going for event or friday night stuff
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
ss brake lines
schrick cams
strong strut brace
slowcar is offline
Old 16th June 2009, 18:25   #5
captiva
Circuit racing on Sat/Sun
captiva is offline
S38 B38 Misfire fredminary E34 M5 Discussion 19 14th August 2008 12:08
Misfire cyl. #7. which one is this. jcdavis E39 M5 and E52 Z8 Discussion 2 5th April 2008 17:34
Help with misfire richie_rvf E39 M5 and E52 Z8 Discussion 23 16th January 2008 13:27
Misfire (Again) e34m5uk E34 M5 Discussion 29 25th June 2003 19:35
Misfire mikek E34 M5 Discussion 7 28th December 2002 22:37
Page generated in 0.10858 seconds with 11 queries
