Old 15th June 2009, 08:48   #1
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
rear wheel bearing removal, semi diy w/ tips
knocked out both rear bearings along with the pss9, and wow were the bearings a pita. one issue lead to another issue. i knew removing the outer bearing race from the flange would be a pita, but those 2 lower bolts were a REAL pita. i had to drop remove the axles so i could get to the bolts, so to have enough clearance i had to drop the exhaust, i undid everything but the connections at the headers and the exhaust hung enough to where i could slide the axles over. removing the bolts even then was a real hassle. had to get the wrench on there just right, and you cant use an extremely long wrench to get leverage on the bolt. no power tools will get into the area either.
finally get them all off and the race off as well, assembly was straight forward, but you have to keep in mind that the lower bearing bolts have to be bolted on first, install the axle, then install the upper bolts. getting the exhaust bolts lined up turns into a pita but its doable.
took me 4 hours to do the first side since i was basically guessing at what i should remove and how to remove that race. once i figured out exactly what had to come off i got the second bearing done in roughly 2 hours. this was with my cordless snap on impact drill. if i had not had that, it would have easily taken an extra hour removing and installing the long list of bolts involved.
i didnt take pics but i have to readjust my pss9 so i can slam my car, so ill take pics when i do that.
-R
razahyde is online now
Old 15th June 2009, 08:54   #2
razahyde
razahyde's Avatar
oh yea i forgot to add, my "whomp whomp whomp" and "click click click" are gone now too, i had a feeling it was my rear bearings, car is silent now, there is a slight electronics buzzing noise as i accelerate, ill look into that tomorrow.
Old 18th June 2009, 10:20   #3
timmay77
timmay77's Avatar
Garage: M CINCO
Sales Feedback: (3)
Nice, how about those pics?
__________________________________________________ ____________________
Originally Posted by Hdhntr23 View Post
I like strippers.
Current Mods
~Complete Alpine/Memphis aftermarket stereo system w/ Navi-Bluetooth-Ipod-DVD-HD Radio (Thanks Jun)
~E60 SSK ~ Illuminated ZHP Shift Knob (Thanks Starscream) ~ Ebay Ebrake Handle
~Euro Headlights (Thanks Raza) ~ Angel iBright V.3 ~ French Fogs ~ DRL Angel Eyes ~ Silverstar turn signals
~Full LED interior light upgrade
~Muffler delete with custom made Timmay77's "Signature" ///M5 - MCINCO etched staggered tips
~OEM 18x9.5" rear wheels at all 4 corners (Thanks Surge709) with 3mm Ebay spacers on the front.
~Dunlop SP Sport 9000's 275/35/18 (Thanks killer diller)
~B&G Suspension lowering springs
~Hardwired Valentine 1 (Thanks hdhntr23)
Timmay77's complete aftermarket stereo build thread: http://www.m5board.com/vbulletin/e39...et-system.html
2001 Jet Black/Black ///M5 ("M CINCO")---07 Infiniti G35S (POS) /SOLD---02 E46 TiAg Cabrio/SOLD and dearly missed
timmay77 is online now
Old 18th June 2009, 11:21   #4
M-Alex
M-Alex's Avatar
Garage: 2001 Maxima SE
Send a message via AIM to M-Alex Send a message via Yahoo to M-Alex
Let me get this straight, we get detailed pics of your 2hr engine swap and no pics of a little 6hr wheel bearing job?
M-Alex is offline
Old 18th June 2009, 17:26   #5
razahyde
razahyde's Avatar
pretty much...lol
i had to do this outside in the texas heat, which really takes a toll on you quickly. last thing i wanted to do was take pics. it didnt help that i thought i would only have to put out the axles, not remove them, which only got worse when i had to drop the exhaust. thats when i started dropping F bombs left and right.
to make it worse, i had everything put back together and forgot i didnt tighten those bottom bolts enough. so i had to remove the damn axle again to get to those bolts.
im going to have a 4 wheel alignment done today so ill take plenty of pics while its being knocked out.
and i honestly would rather swap motors, before doing those wheels bearings again. they suck that much.
Old 18th June 2009, 18:06   #6
jt2ma71
jt2ma71's Avatar
Garage: Alpine White E39 M5
Originally Posted by razahyde View Post
pretty much...lol
Hahah, go figure! Atleast 90% of the time, engine swapping is pretty straight forward with not many obstacles. Wheel bearings, can be hit and miss. Ive seen wheel bearings go for thousands of miles with no grease and fuse themselves to the hub. Even with a 10lb slide hammer i was not able to get it out lol.
If you dont mind me asking, how much did the wheel bearings set you back?
2000 Alpine White M5
Performance: Custom CAI, Tubi Exhaust, Open Brake Ducts, UUC Evo3 + DSSR
Exterior: Euro Mirrors, Black kidney grilles, MY01+ Updated, Mtec 3W AE, Altec retractable license plate
Interior: 16:9 Nav, MK3 Navigation, MY01+ dash, Silverstone Leather
Wheels: Volk CE28N Time attacks 19x10.5 275/30/19, 19x8.5 245/35/19 Pilot Sport PS2
1999 Ranger XLT 4x4
2" Lift, 33's, 4.10LSD, Locked front hubs
jt2ma71 is online now
Old 18th June 2009, 18:10   #7
razahyde
razahyde's Avatar
the slide hammer got the flange off, but with the flange the outer race was still on. getting the race off with a chisel was a pita since i didnt want to ruin the flange. the actual bearing once i removed the bolts came off easily, another perk of a cali car.
i dont know how much i paid, i get my parts at cost, so i just put orders in and the department charges my CC.
Old 18th June 2009, 18:11   #8
jt2ma71
jt2ma71's Avatar
Awesome. Damn, that last line, if the same went with my dealer, id be in a lot of debt LOL.
1999 Ranger XLT 4x4
Old 18th June 2009, 18:19   #9
razahyde
razahyde's Avatar
yea it does end up being bad, i have a tendency to order new parts when i think there is something wrong...or ill just change things out for the hell of it.
Rear Wheel Bearing Replacement? timmay77 E39 M5 and E52 Z8 Discussion 14 24th April 2009 19:35
FS BMW E39 /E38/E60/E65/E66 Rear Axle Wheel Carier Bushing/Balljoint Removal Tool omid For Sale or Wanted 1 27th November 2008 05:45
Rear seat removal tips? Osodog E39 M5 and E52 Z8 Discussion 4 18th August 2005 05:09
Rear Wheel Bearing Noise Bob Uenaka E39 M5 and E52 Z8 Discussion 6 6th March 2005 07:34
Tips/instructions on rear E39 M5 bumper removal? Tin E39 M5 and E52 Z8 Discussion 5 24th May 2004 10:45
Page generated in 0.15217 seconds with 11 queries
