Old 14th June 2009, 03:23   #1
HDClown
HDClown's Avatar
Garage: 2002 M5
Cooling fan fell off and cooling fan clutch
I came home and pulled in the garage and heard an unusual noise from the motor. I got out with the car running and radiator cooling fan wasn't spinning, something wrong there. It's 90F out and it should be spinning. Shut off the car and discover:
Fortunately, the fan landed perfectly between the radiator and the shroud. Zero damage to the radiator fins, cooling hoses, or intake plumbing, YAY. The threads are fine and I was able to thread the fan back on fine. So it had just come loose.
I unthreaded the fan and pulled it out to check on the fan clutch, as I know thiese are known to seize up on higher mileage cars. I can free spin the clutch in both directions, but it seems tight to me. I'm not sure if this is normal or not. Should it require a little bit of force to move, or should it be very free spinning? Car only has 64k miles.
The clutch itself is $160 and I have an order into Tischer already waiting to be shipped due to some backorder items. So I think I may just play it safe and add a new clutch to the order. $160 would be well spend if the clutch seizes and the fan causes radiator and cooling hose carnage from "exploding".
2002 LMB/LMB M5 - Alcantara Headliner, Electric Shades, Folder Down Seats, M-Audio
-Britalman Exhaust, Brembo GT 355f/345r Big Brake Kit, Centric Posi-Quiet Pads, AA CAI
-UF IATS Relocation, UUC Evo3 SSK + DSSR, UUC Clutch Stop 19" Breyton Spirit Rims
-TCD Rear Sway Brackets, Euro Angel Eyes, Angel iBright v3.0, Stealth Bulbs, Stealth One
-Valentine One, Roof Spoiler, OEM Voice Control, OEM Trunk Storage Bin, 13% Solar Gard HP Tint
-http://gallery.slipoftime.com/m5
HDClown is offline
Old 14th June 2009, 03:30   #2
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 Titanium Silver E39
Sales Feedback: (12)
Send a message via MSN to Hdhntr23 Send a message via Yahoo to Hdhntr23
Fortunately, the fan landed perfectly between the radiator and the shroud. Zero damage to the radiator fins, cooling hoses, or intake plumbiny, YAY. The threads are fine and I was able to thread the fan back on fine. So it had just come loose.
That is one of my nightmares. The clutch siezing at speed and it shooting thru my hood and motor.
Glad to see that you were lucky and it fell without damage.
One can be spelled as NEO.
There is no spoon.
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77), C-Fiber Kidney Grills, ACS C-Fiber Roof Spoiler, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece door sills, 7 Piece C-Fiber Blue/Grey Roundels.
Current Performance Mods: Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan)
Planned Exterior Mods:
Stainless vented custom Fog-Light frames (Awaiting fabrication), C-Fiber ACS Flipper style Front Splitters (Awaiting delivery and install), PIPEDREAM.... Vorstiener vented CF double sided hood
Planned Interior Mods:
Scosche BlueTooth 2.0 A2DP Adapter, Backlit Door Sills, Hardwire V-1, Stealth One, Replace instrument cluster (Pixels dropping out), Add a dedicated amp for the "M" Subs, Euro-Style Armrest
Planned Performance Mods:
Dinan Front Tower Brace, Headers (Looking for input)
Hdhntr23 is offline
Old 14th June 2009, 04:53   #3
Lawaia
Lawaia's Avatar
Garage: '02 M5 /// Sterling Gray
The clutch fan should spin with a bit of resistance, and will fluctuate based on temperature. Did you have the fan removed recently?
'02 M5 Sterling Gray / Black
UUC EVO3 w/DSSR
Supersprint Cat Back Exhaust
Lawaia is offline
Old 14th June 2009, 05:08   #4
HDClown
HDClown's Avatar
Garage: 2002 M5
Fan shouldn't have been removed for any work I've ever had done on the car since I purchased it 4 years ago. Based on prior service history to that, I can't see anything that would have required the fan to be removed.
HDClown is offline
Old 14th June 2009, 18:06   #5
HDClown
HDClown's Avatar
Garage: 2002 M5
Thought about work done on the car last night and remembered the starter was replaced, would the fan have been removed for that job?
HDClown is offline
Old 16th June 2009, 04:55   #6
chowdah
Garage: sweetness
Sales Feedback: (3)
Engine fan fallen off
chowdah is offline
Old 11th July 2009, 20:10   #7
HDClown
HDClown's Avatar
Garage: 2002 M5
I've got a new fan clutch now and installed it back into the fan blades.
In terms of properly securing the fan clutch nut to the water pump, is jamming the pulley/having a special tool so it doesn't spring the only safe way to secure it? I've got it on right now just using a wrench and my body weight as well as a rubber mallet, but since the pully springs, I don't reallly know how tight it's on there.
HDClown is offline
Old 12th July 2009, 16:36   #8
nightkrawler
nightkrawler's Avatar
Garage: Lemans Blue M5
its probably toast at 60k. easy way to test these, get a newspaper and roll it up. make sure the engine is cold, like first start of the day. with the engine idling try to stop the fan from spinning with the newspaper. it should take very little effort to stop it, if it dosent stop easily then its shot. fan clutches locking prematurely im sure is another reason why some of these cars run too cool.
nightkrawler is offline
Old 12th July 2009, 22:46   #9
HDClown
HDClown's Avatar
Garage: 2002 M5
I already replaced the fan clutch, question was in regards to re-securing the fan clutch nut onto the water pump. Some additional research indicates that spinning it on hand tight until it stops is adequate, and it will self tighten itself as it runs. I actually tightened down with a wrench some as well.
HDClown is offline
Old 13th July 2009, 04:43   #10
Need4Spd
Need4Spd's Avatar
In theory it should "self-tighten" because of the reverse thread direction, BUT, it did fall off all by itself the first time, right? Probably the pressure you put on it is enough to keep it from happening again. FWIW, I replaced mine recently and found it quite tight, so taking it off required a special tool that holds the pulley from rotating. I also read how others had managed to remove theirs by jamming the pulley with a large screwdriver but I couldn't find quite the right angle to do that. I found that trying to hold it that way met with the "rubbery" feel you describe. I was also concerned about damaging the pulley or the take-up idler. So, I bought a tool that holds the pulley from turning from Pelican parts. Because the original unit was held "tool-tight," I tightened on the new one with similar torque.
Need4Spd
Need4Spd is offline
Cooling System JohnR E34 M5 Discussion 4 11th January 2008 19:40
cooling problem again.... nerio02 E39 M5 and E52 Z8 Discussion 22 19th December 2007 02:12
Cooling system bay E34 M5 Discussion 2 14th February 2006 22:46
Brake Cooling Kit BMWM5Driver For Sale or Wanted 2 18th October 2004 07:27
electric cooling fan Yves E34 M5 Discussion 0 23rd April 2000 01:07
Page generated in 0.15289 seconds with 11 queries
