13th June 2009, 23:21
#1
Strong-Strut front brace installed...
After owning a Strong-Strut front tower brace for my M-Roadster, I decided to try their brace for my e39 M5. I think this is one of the finest engineered aftermarket products. Unlike other braces, this is CNC machined to precisely fit completely around the top of the shock tower, with recesses in all the right places underneath. It's made from cold-rolled steel and there are no pivot joints anywhere. They only make these type of braces, so they obsess about it. You can find them at www.strong-strut.com. I don't work for them nor have they paid me to promote them - I just like what I got. They charge $485 - not cheap, but I think you get what you pay for. They include the acorn nuts and washers.
13th June 2009, 23:28
#2
2KM5CB/B
Looks good. Did you feel any difference in body stiffness?
13th June 2009, 23:33
#3
It's easier to tell the difference on an M-Roadster, but I will be "feeling" for differences as I put some miles on the car. I like the fact that it is so rigid you can grab hold of it and shake the car with it! This is not just a cosmetic dress-up, but it does look nice IMHO.
14th June 2009, 01:09
#4
2003 M5 Titanium Silver
+1
Hi BVHBMW! I have this same strut bar and it is fantastic!! Thanks for posting and enjoy....
Modifications:
Engine Tuning: ESS Tuning VT550 Supercharger w/91.44mm pulley
Exhaust: Supersprint headers, Supersprint high flow cats, Supersprint X-pipe, Meisterschaft GT2 Racing Performance exhaust w/matte black 83mm tips
Powertrain: Koala Motorsport 3.45 differential w/30/60 asymmetrical ramps w/40% limited slip, UUC V12 Segmented Kevlar Clutch, UUC Ultimate V8 Flywheel, UUC Clutch Stop, UUC SSK, UUC DSSR, ZHP weighted/illuminated shifter
Suspension: H&R sway bars (front and rear), Beastpower rear sway bar brackets, Strong Strut strut brace, Koni shocks, H&R springs, Dinan monoball thrust arm bushings, Powerflex upper/lower control arm bushings, Ground Control adjustable camber plates
Wheels: 19" VMR V710 w/custom matte black finish
Brakes: Brembo Gran Turismo BBK: 8-piston front calipers w/380 mm cross-drilled rotors, 4-piston rear calipers w/340 mm cross-drilled rotors, Active Autowerke CAI front brake ram air cooling
Miscellaneous: radar-mirror.com AEM boost gauge & AEM wideband AFR gauge, Rogue Engineering Power Pulleys, 16" electric fan w/temp control switch
Aesthetics: Slimm's custom CF Splitters, Vorsteiner CF vented hood, Vorsteiner CF diffuser, CF kidney grills, CF side view mirrors, CF rear spoiler, CF BMW roundels, matte black M5 badge, Ultimate Pedals aluminum race pedals & footrest, BMW foot-well mounted umbrella
Horns: Relayed Stebel Compact Truck Horn (300 Hz at 118 dB at 3M) & Stebel Compact Tuning Horn (480 & 630 Hz at 118 dB at 3M)
Fuzz Busters: Beltronics STi Driver Radar Detector, Blinder M47 laser jammer
Euro-spec Accessories: BMW front seat mounted Fire Extinguisher, BMW front seat mounted First Aid Kit, BMW Emergency Triangle
14th June 2009, 08:15
#5
M5 - Titanium Silver '01
I have one, too, and also knew Strong Strut from previously having one on my (long sold) M Roadster. This is one of the best on the market, IMHO. Not the lightest, but a few extra pounds on this 4000 lb. car really won't make any difference, and the rigidity and strength more than make up for any weight gain. And it looks really good.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Future - F10 M5?
14th June 2009, 18:42
#7
540i Orient Blue
What was the biggest difference you felt when you installed it? Does it corner flatter, less body roll, etc? I'm thinking of going with this brace or the racing dynamics one, but I'm leaning toward the strong strut. It looks like a high quality brace and I like the fact that it's made here in the good ol U.S. of A.
14th June 2009, 19:04
#8
The main difference I felt on my M-Roadster was much less body flex when going over uneven surfaces. There was no discernible difference in cornering flatness or body roll.
I suggest trying the Strong-Strut. They have a money-back guarantee.
14th June 2009, 19:10
#9
540i Orient Blue
Do you feel it was worth the price?
14th June 2009, 19:31
#10
Back when I bought my '99 M-Roadster, the price of the strut was under $300. Almost 10 years later, his prices have increased but compared to the alternative products I think this is still the best value out there. Nothing else is built to this level of precision, IMHO. Look at the photo of the strut rings and look at the quality of the welds - this is aircraft-level work.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
