Old 24th May 2009, 01:48   #1
bng4god
bng4god's Avatar
Garage: M5
LOTSA PICS!!! Hamann Replica Lip Installed with Dinan Springs and Koni Yellows
Finally got around to a wash and wax. Pics of the custom painted Hamann Replica Front lip installed with Dinan Springs and Koni Yellows.
And some gratuitous Rear and Side Shots:
01 Black on Black M5: Custom Exhaust with Straight Pipe & Magnaflow 14816 Mufflers, Angel iBright v3.0, 19x9.5/15mm All Four Beyern Mesh Custom Painted Silver Gray Metallic w/ Kumho Ecsta SPT's 275/30/19's, Dinan Springs, Koni Yellows, Hamann Replica Front Lip custom painted
bng4god is offline
Old 24th May 2009, 02:18   #2
kimdyIN
kimdyIN's Avatar
Garage: Imola/Caramel E39 M5
Very Nice!
kimdyIN is offline
Old 24th May 2009, 02:33   #3
shamus_mcd
shamus_mcd's Avatar
Garage: E39 M5 in Titanium Silver
Those wheels look superb
The 2 tone works very well
Life is not Measured in the amount of breaths you take,
BUT in the amount of times it takes your breath way....
///M5
I'm off to the ASTHMA CLINIC now!!!!!!
shamus_mcd is offline
Old 24th May 2009, 04:17   #4
cknaak
cknaak's Avatar
Garage: 2000 M5-Anthracite Grey
Looks good. Also, nice exhaust, just put the Magnaflows on my M5 and love them!!
_______________________
Anthracite M5
DINAN Stage 1 suspension
DINAN Stage 2 software
DINAN Short Shift Kit
DINAN Front Strut Brace
DINAN Pedal Set
CF Intakes w/ DINAN filters
Euro brake duct mod
CF front splitter/Kidney Grill/Trunk spoiler
Magnaflow 14186's with custom X-pipe and resonator delete
Linea Corse Lemans wheels wrapped with Toyo T1R's
cknaak is offline
Old 24th May 2009, 18:15   #5
daiyst9
Garage: 2003 M5 LeMans Blue
Very nice! Couple of questions. Are you running 275/30/19 on all corners? If so, did you have to mod the fenders or use spacers? Also, where can you get the brake cooling grill?
Congrats and thanks for sharing!
daiyst9 is offline
Old 24th May 2009, 18:16   #6
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
That's a nice stance!
Cristian
Anthracite///Black
For Sale: Sumitomo HTRZ III for 19s
For Sale: 2 GoPro Motorsports Wide Cameras
Diny is online now
Old 24th May 2009, 18:48   #7
bng4god
bng4god's Avatar
Garage: M5
Yes.
No Spacers or rolling of fenders needed IF you run a stock suspension. You will have issues if you lower the car. Coilovers are near impossible without spacers and even using Dinan Springs and Koni Yellows which is a mild drop, I had to roll the fenders a little bit to prevent rubbing of the tires.
Do a search on "Halo" or "Sink Drain Mod". Here is a link to get you started: "Sink Drain" mod, hole placement
The rings were bought from Lowe's it's part of the reflecting cone assembly for recessed lighting. I have to give props to the original poster for the creativity on this one!
bng4god is offline
Old 24th May 2009, 19:34   #8
daiyst9
Thanks! Your set up is very close to where I'm going. I gonna go with the Dinan Stage II. So bottom line is be prepared to roll the fenders in the front a bit ONLY when lowering, but NO SPACERS needed, right?
daiyst9 is offline
Old 24th May 2009, 21:55   #9
bng4god
bng4god's Avatar
Garage: M5
It all depends on what wheels you plan to get. IF you are going with my exact wheels, then the answer is yes and you will need to roll all four fenders. Any other wheel is a completely different issue that you will need to find out and unfortunately I cannot answer.
bng4god is offline
Old 25th May 2009, 12:30   #10
Ken@exoticstuning.com
Company Representative for Exotics Tuning
Ken@exoticstuning.com's Avatar
Garage: Avus E39 M5
Send a message via MSN to Ken@exoticstuning.com
How's the ride ?? Any before/after drop pictures ?? Thinking of doing this instead of going Coilovers.
Ken@exoticstuning.com is offline
e39 M5 Koni yellows vs. E39 540I Koni yellows? TopEnd E39 M5 and E52 Z8 Discussion 28 21st January 2009 07:06
Koni Yellow and Dinan Springs....cost savings boostmiser E39 M5 and E52 Z8 Discussion 12 29th June 2008 03:53
Anyone deleted rear SLS with Koni / Dinan springs? Need help! CWY_M5 E34 M5 Discussion 5 23rd May 2008 07:48
Dinan springs and koni yellow shocks setup like new mishkinm5 For Sale or Wanted 5 23rd September 2007 21:28
Final suspension question, how many turns on rear koni yellows? Close Encounter E39 M5 and E52 Z8 Discussion 5 27th April 2007 04:49
Page generated in 0.14666 seconds with 12 queries
