Parking Sensor Fault?? - BMW M5 Forum and M6 Forums
post #1 of 8 Old 22nd May 2009, 12:28 AM Thread Starter
Mr.Devere
Mr.Devere's Avatar
Hi Guys, after some help. I knew I had an issue with the PDC as when I put the car in reverse it gives the continuous beep. Checked all the rear sensors and the passenger side is clicking, luckily the one in the trim. Disconnected the sensor and I still get the tone, guessing it detects no sensor as well as faulty sensor. Bought a new sensor, checked compatibility on RealOEM, when it arrived it is not the same as the one on the car. The sensor conector is identical so I thought I'd plug it it to see if the issue corrected. When it was plugged in still get the tone and the new sensor is clicking so I'm stumped. Anyone ever heard of this? Could it be the cable or PDC unit itself, anyone any ideas on how I would check this?
Car is 99M5, rear PDC only, BJ10364
Any help is appreciated.
M5 (black)........
Audi S6 V10 (Stolen)...:
Career Path:
330ci Sport Conv (silver)
Escort Cosworth (silver)
Sapphire Cosworth (2wd) (magenta)
MKI XR4x4 (white)
MKI XR2 (white)
Mr.Devere is offline
post #2 of 8 Old 22nd May 2009, 01:36 PM
andy777
andy777's Avatar
If is clicking then it's working, try swapping the new sensor with the other sensors.
I'll see you, if you catch me
andy777 is offline
post #3 of 8 Old 22nd May 2009, 01:39 PM Thread Starter
Mr.Devere
Mr.Devere's Avatar
Oh dear, there was only 1 sensor clicking the other 3 were quiet..........thanks for the input, of course it was never going to be that easy..........
M5 (black)........
Career Path:
MKI XR4x4 (white)
MKI XR2 (white)
post #4 of 8 Old 22nd May 2009, 03:28 PM
DouglasABaker
DouglasABaker's Avatar
I concur, sounds like you have 3 bad sensors, not 1. Swap the new sensor in place of the other 3 to determine if the sensors are broken or if you have a wiring issue.
d-
DouglasABaker is offline
post #5 of 8 Old 22nd May 2009, 05:32 PM
b757236
b757236's Avatar
b757236 is offline
post #6 of 8 Old 22nd May 2009, 07:09 PM Thread Starter
Mr.Devere
Mr.Devere's Avatar
Sensor compatibility
Cheers Doug, I'll try that to see where the fault is. To have 3 sensors gone is unlucky. My inital joy at having 1 easy repair sensor faulty was a tad hasty as it's looking more like 3 are going to need replacing so its bumper off.
Adam, the trim mounted sensors are an easy repair. To remove the plastic trim look underneath the trim itself on the edge nearest the rear door, you will see a cut out. Get a flat tip driver and prize off the trim. Suggest you mask the paint underneath the trim, I built up a couple of layers of masking tape to help protect the bumper if I slipped. My trim was quite tricky to remove, I guess it has not been off in 10years so fair enough, you just need to be quite forceful without bending it at too sharp an angle, it will come off, just takes a bit of effort, or mine did anyway.
I ordered a replacement sensor from e-bay (66 21 6 938 739), confirmed on RealOEM that it was a compatible part and when it arrived turns out it is not the same. See pics when I removed the sensor the part number on it is (66 21 6 902182).
I was wondering if these sensors are cross compatible, i.e will the complete round one work in my vehicle, I have also read the original ones require painting. If this is the case I might just order another couple of the full round sensor (938 739) as my car is black they will look OK.
M5 (black)........
Career Path:
MKI XR4x4 (white)
MKI XR2 (white)
post #7 of 8 Old 22nd May 2009, 07:20 PM
felstmiester
I had my two inside one's go and i managed to do mine without removing the rear bumper, its a bit tricky but it can be done.
I also had trouble getting replacements without paying the ridiculous dealer prices, according to the information i had the sensors are not necessarily the same to a particular year of manufacture. My one's are square but the ones i purchased are exactly the same, just made round the other way, so they now detect the ground lol.
felstmiester is offline
post #8 of 8 Old 22nd May 2009, 08:14 PM Thread Starter
Mr.Devere
Mr.Devere's Avatar
Seriously you managed to do it without removing the bumper, I have read quite a few post saying the bumper needs to come off, I'll have go without the surgery first.........any tips??
I just made a guy an offer on e-bay, he's got an auction for 4 of the oblong/square type sensors that are on my car, I'm sure the round ones will work, but I don't want to get 3 new sensors and a dented bumper to find out that there are some compatibility issues............mm ground detection is that a whole new retrofit? I could phone the main dealer and ask if they stock them.............
M5 (black)........
Career Path:
MKI XR4x4 (white)
MKI XR2 (white)
Replacing rear Parking Distance Control sensor? M5MJ E39 M5 and E52 Z8 Discussion 2 28th September 2006 07:11 PM
Does front PDC sensor detect parking blocks? msdsman E60 M5 and E61 M5 Touring Discussion 11 11th July 2006 06:47 AM
Problem with Parking Sensor SWP E60 M5 and E61 M5 Touring Discussion 6 23rd June 2006 05:04 PM
Parking sensor/laser blocker!! Hogie E60 M5 and E61 M5 Touring Discussion 0 12th March 2006 12:01 AM
CPS Exhaust Sensor Fault - $400 Repair? intense321 E39 M5 and E52 Z8 Discussion 4 18th January 2006 09:29 PM
