Old 13th May 2009, 10:36   #1
rassi
rassi's Avatar
Garage: '02 BMW M5 (Carbon black / black leather)
Ticking sound: wheel bearings...?
A few other threads have described a ticking sound, and concluded that it is most likely wheel bearings. I have the same sound, a bit like if a stone was stuck in the tyre and gets worse (almost like a groaning power-steering pump) when in a hard corner - to those that had wheel bearings replaced, is this consistent with your symptoms?
Also, I get a rumbling sound that I noticed when I changed from winter to summer tyres. The fronts are Michelin PS (originals) with about 4 mm left (after 50.000 km!!!) and the rear PS2 with about 4 mm too (30.000 km!!) - would the wheel bearing be the culprit for this rumbling sound, or is it not more likely to be the PS that I understand start to rumble when worn?
Anders
Stock apart from Eisenmann Sport, E60 545 short shifter mod, MKIV nav and Intravee II
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
rassi is offline
Old 13th May 2009, 12:36   #2
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
I thought wheel bearing made a whining noise when they were going bad.
I'll see you, if you catch me
andy777 is offline
Old 13th May 2009, 22:17   #3
Need4Spd
Need4Spd's Avatar
Worn tires often make rumbling sounds, which can easily be mistaken for bad wheel bearings. Jack up and support the car so that the front wheels are off the ground. Spin the wheels and pull on them to see if there is any roughness or play. If not, I would look elsewhere for the problem.
Need4Spd
Need4Spd is offline
Old 14th May 2009, 18:53   #4
gbogh3
gbogh3's Avatar
Garage: 02, M5 Sterling Grey
Send a message via Yahoo to gbogh3
last time I had a ticking sound on the wheels, it was a lug nut. I had just had the wheels rotated, so it was pretty easy to find.
good luck
02 Sterling Grey with Extended Caramel Leather
AA Cold Air/ Brake Ducts, SS Headers, Mystery Short Shift, Dinan Stage III w/ JRZ, Tubi Competition Exhaust, Dinan Stage 4 software, Hardwire V1, XM, Clear Bra.
2004 X5 4.8is (for sale, PM if Interested)
2010 X5 Diesel Ordered
2005 X5 RIP
1995 E36 325i Sold
1989 E30 325i RIP
1972 3.0s Sold
gbogh3 is offline
Old 15th May 2009, 01:13   #5
KLehmann
KLehmann's Avatar
Garage: '01 Carbon Black/Caramel
Send a message via Yahoo to KLehmann
Rumbling sound that appears when switching tires is likely the tires. But I will say that sometimes different tires will communicate problems to you better. On a previous AWD car I had, the winter tires did a nice job of masking the drivetrain lash that was always there for as long as i'd owned the car (9 yrs). Still, well-worn tires that have seen some hard use can rumble. I've had some nasty noisy tires (old generation Yokohama A032R Rcompounds) on my 911 that were so rumbly and noisy I thought there was something wrong with my transmission. I put on my other set of track tires and presto-change-o the transmission was fixed!!
Wheel bearings commonly do not click when they need replacement. They do typically groan like you mention. How many miles do you have on them (I assume they're the originals)? If you're in the 70,000 mile range, that's when they are commonly going bad on these M5s. Need4Spd's advice on how to check is spot on. You need to do some diagnosing/testing to confirm your suspicion of the wheel bearings.
2001 M5 Some sort of dark blue/Caramel
2006 X3- Light Bloo
1987 Porsche 911 Carrera IROC wannabe
KLehmann is offline
ticking sound when turning m5_chris E39 M5 and E52 Z8 Discussion 6 19th May 2009 20:52
Low Rumbling Sound But NOT Wheel Bearings Need4Spd E39 M5 and E52 Z8 Discussion 17 11th March 2008 08:12
ticking sound when driving madm5 E34 M5 Discussion 8 30th June 2005 00:02
Ticking sound from valves johann E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 19 27th April 2002 16:25
Strange Ticking Sound - 540 *and* M5! Chris Foote E39 M5 and E52 Z8 Discussion 7 9th June 2001 18:38
Page generated in 0.10309 seconds with 11 queries
