Hard to put into first gear - BMW M5 Forum and M6 Forums
post #1 of 19 Old 10th May 2009, 03:25 AM Thread Starter
Perrodulce
Perrodulce's Avatar
I am finding it difficult to put the car into 1st gear - a lot of resistance. All other gears are fine. I am somewhat new to manual transmission problems, so I defer to the experts on the board. Thanks for any help!
Perrodulce is offline
post #2 of 19 Old 10th May 2009, 04:00 AM
wxl1988
wxl1988's Avatar
wxl1988 is offline
post #3 of 19 Old 10th May 2009, 01:02 PM
agregatM5
agregatM5's Avatar
Originally Posted by wxl1988 View Post
Shifting in and out of 1st and 2nd is getting very tight
That thread might give you some insight on why there's resistance.
In addition to the information in the above thread, I would like to share some personal experience.
Correct me if I'm wrong, but the M5's 6-speed gearbox is exactly the same that is used in E36 M3 Evo (i.e. the European version of M3 released in 1995 which had 321 bhp opposed to E36 M3 of 1993-1995 which had 5-speed gearbox and 286 bhp).
I had the same problem with my M3, that the first and sometimes second gears were very difficult to engage. The car had 90k on the odometer. Also, I didn't like the fact that to disengage the clutch you had to press the clutch pedal not only all the way down to the floor but even further, by which I mean that you had to press it really hard as if IN the floor otherwise it would be impossible to change gears. So the biting point was so low, that if you left at least one millimeter before the floor it wouldn't disengage fully.
Now I thought then that the clutch is so worn that it causes the problem. I've changed the clutch, but everything stayed the same. As you know the clutch on M3 and M5 is hydraulic, so the indy which changed the clutch explained to me that the stock hose where the tranny fluid goes when you press the pedal to disengage the clutch, is constantly exposed to heat, and with the time it can't hold the same shape, so when you press the clutch some of the luquid instead of being transffered stays IN the hose, the hose as if swells up a little. He replaced this hose with a custom made braided one, and the problem dissappeared, I could change the gears with two fingers after that!
It is a well known problem on M3s and M5s, and not fully disengaged clutch still allows you to change gears providing the syncromesh is new. With the time the syncromesh especially on the first and second gear are getting worn and it's harder and harder to change gears. However if you change the stock hose for the braided one, providing the tranny is more or less in a good health, you will save yourself the clutch change and a tranny overall.
Tony
agregatM5 is offline
The Following 2 Users Say Thank You to agregatM5 For This Useful Post:
M5CCIE (10th May 2009), Perrodulce (10th May 2009)
post #4 of 19 Old 10th May 2009, 01:25 PM
gsfent
gsfent's Avatar
In addition to the other advice, try rev matching. With the clutch pedal out, blip the throttle lightly, then push clutch pedal in and slide in the gear lever. The blip should help line up the synchros.
If you can't do it with the car stopped, try shifting to 3rd, then back to 1st. Also helps line everything up.
1st is a little stiffer in this car than any other car I have driven. You have to be firm on your shifts, but never force it!! If you have to force it, something is wrong!
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is offline
post #5 of 19 Old 10th May 2009, 06:38 PM
M5CCIE
M5CCIE's Avatar
Good info to know, however I think it may also be the bleeding of the system after the hose was changed that helped fix this issue.
2003 M5 Sterling Gray
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
post #6 of 19 Old 10th May 2009, 08:27 PM
wxl1988
wxl1988's Avatar
Board member lscman took apart the Getrag transmission and found that the difference is the M5's tranny has no plastic parts inside, the M3 Evo does.
6 Speed Getrag Transmission Lube Issues
wxl1988 is offline
The Following User Says Thank You to wxl1988 For This Useful Post:
post #7 of 19 Old 10th May 2009, 09:34 PM Thread Starter
Perrodulce
Perrodulce's Avatar
Just to clarify, I am not having trouble going into 2nd or any other gear, just from a stop, trying to put it into first is difficult...
post #8 of 19 Old 10th May 2009, 11:06 PM
agregatM5
agregatM5's Avatar
Didn't know that, thanks for the info, however in terms of changing gears they are identical, hard to put the first in, clonky for the second, and fine afterwards.
Perrodulce, is this problem with putting the first gear in is always there or just time to time? If always, then the syncromesh on the first gear is probably worn, if time to time then try to simply release the clutch and press it fully down again, it might be that your clutch is not disengaging properly, as I described before. or it could be both together
Lining up the syncros as gsfent advised is also a very good idea, it should not necessarily be the 3 gear, can be the 2nd and then you just move the gearstick forward and voila! you are in the first gear.
Tony
The Following User Says Thank You to agregatM5 For This Useful Post:
post #9 of 19 Old 11th May 2009, 04:22 PM
e39power
I'm having this exact issue when weather is warm and have been looking for a braided steel line...any ideas where I can get one? I might just have to replace with a stock line.
2002 M5 Lemans Blue
e39power is offline
post #10 of 19 Old 12th May 2009, 02:09 PM
agregatM5
agregatM5's Avatar
It's custom made: you could just try to find a braided hose of the same diameter and cut it so it's the same length, at least that's what my indy did then. It is worth the hassle, as it vastly improves the gearchange feel, and also 'box's syncromesh will last for much longer.
Tony
Hanging revs when clutch depressed; but only when gear shift is in a gear CSBM5 E39 M5 and E52 Z8 Discussion 37 17th June 2017 05:22 PM
Hard gear changes Johnnym5 E28 M5 Discussion 4 8th March 2010 08:28 PM
New Clutch grabbing hard in 1st & 2nd gear Goody4 E39 M5 and E52 Z8 Discussion 6 19th November 2005 10:37 PM
Royal Purple Max-Gear Synthetic Gear Oil Tom Burns E39 M5 and E52 Z8 Discussion 21 19th October 2005 02:42 AM
what is the max speed in each forward gear? and how do u guys like the gear ratios? 2001M5Titanium E39 M5 and E52 Z8 Discussion 12 26th March 2002 03:21 AM
