The following story was recently brought to my attention. I don't know the author (or even who it is), but it is priceless.
Hi guys,
Last weekend I spent two days wrestling with my GT-350 replica, which you may
recall is now running after a one-year period of dormancy while the motor was
in pieces. While dealing with some subsequent problems, I learned some
lessons that can all be directly applied to working on our cars.
* Upon startup of a new engine, if you hear a distinctive tic-tic-tic sound
from your header-to-cylinder head junction, you will be told by all your
friends that it is an exhaust leak caused by using the cheap manifold gaskets
which come as part of the entire engine-overhaul gasket set, and you should
have opted for high-quality $35 Fel-Pro header gaskets instead. The only
solution is to remove and replace the lame gasket with a quality unit.
* The header bolts which didn't allow enough clearance to get a wrench or
socket on them when you were installing them, haven't shrunk any, so removing
the eight bolts will take an hour.
* Your hopes of simply backing the header away from the head, slipping the
two-week-old, cheap gasket out and installing the new, $35 gasket will be
dashed when you realize the existing gasket has adhesed itself firmly to the
head. It will need to be scraped off.
* Immediately after commencing the scraping activities, you will be struck
with both a revelation and a recollection. The revelation is that the
header-to-fenderwell interference won't allow you enough clearance to scrape
the entire gasket, so the header will have to completely come off the car.
The recollection will be that you were smart enough to trash the cheap gasket
that came with the engine rebuilder kit, and the $35 Mr. Gasket like-new
gasket you forgot you had installed, and have now just destroyed, is of
similar quality to the new $35 Fel-Pro gasket you bought to replace it.
* Spray-on gasket remover is highly effective stuff, but it is also highly
democratic in its application. In this instance, it will make no
differentiation whatsoever between the like-new $35 gasket you're trying to
remove, and the new Ford blue engine paint you're not trying to remove--both
will fall away from the motor in equal amounts.
* In order to remove the header so you can scrape the gasket, you will have
to disconnect it from the collector. The collector bolts which were too long
when you installed them have, like the header bolts, failed to shrink any in
the ensuing two weeks, and the mechanical locking nuts (stove nuts) have, if
anything, increased their tenacious grip upon the too-long bolts.
Furthermore, the inadequate clearance to swing a wrench hasn't grown any
either, meaning that you will be able to turn the nut about 1/32nd of a
revolution before the wrench strikes something solid, and needs to be removed
and flipped around for another swing. The upshot is that it will take about
15-20 minutes to remove each bolt.
* After the header is finally removed, while lying underneath the car and
scraping the gasket, when a piece of gasket-remover-laden gasket falls onto
your forehead, you will instantly determine that the democratic nature of the
gasket remover extends to human flesh as well, and the forehead is
particularly sensitive to extremely caustic chemicals.
* When extremely caustic chemicals are suddenly applied to a large section
of your forehead, the result is an instant and involuntary muscle contraction
in the torso, causing you to suddenly sit up, normally about 24 inches or so.
* The average Mustang chassis, when raised on jackstands, is approximately
22 inches off the garage floor.
* The sudden and violent application of 2900 pounds of steel to a burning
forehead does not, surprisingly, lessen the effect of the extremely caustic
chemical reaction taking place, but instead augments the pain with a deep
pounding inside the skull as your brain takes a good shellacking from the
inside.
* When it comes time to open the exhaust gasket package, the expeditious way
is to use a screwdriver to make a small tear in the plastic, then run your
finger along the underside of the gasket, neatly opening up the package from
one end to the other.
* Exhaust gaskets are made of various layers of fibers and steel, and as
you're opening the package, an exposed and sharp steel wire will neatly open
up your finger from one end to the other.
* 1966 Mustang Red and Human Blood Red are remarkably alike when the blood
is wet and liberally sprayed across the top of the fender. However, when it
dries it darkens considerably and thus can't be used as touch-up paint as you
had perhaps hoped.
* Gasket remover is remarkably resilient stuff, and although you took great
pains to wipe down the cylinder head with lacquer thinner before installing
your new gasket, the forgotten gasket remover still coating the flange of the
header will immediately go to work the minute the header is placed against
the gasket. Fortunately the gasket makers are thoughtful enough to include a
pair of gaskets in each package for just such contingencies.
* As you are holding the gasket-remover-soaked header in your hand and
removing your now-ruined new gasket, you will feel that the skin on your
fingers isn't nearly as sensitive to the effects of extremely caustic
chemicals as the skin on your forehead. However, when you have sliced your
finger open and the gasket remover gets in the open wound, the effect is much
the same.
* Once the second new gasket is in place, the header bolts and
header-to-collector bolts will be just as difficult to install as they were
to remove, as they were to install the first time, as they were to remove the
first time.
But the final, and undoubtedly the most important lesson learned from this
two-day exercise is this:
* A clever engine-building trick is to loosely install the spark plugs on a
new motor; if the head gasket leaks into the cylinders, this will allow the
water to leak and spray past the threads on startup instead of potentially
blowing up the motor with hydrostatic lock. However, if the engine builder
then forgets to tighten the plugs once the engine has successfully started,
then exhaust gasses may leak past the threads, making a distinctive
tic-tic-tic sound from the neighborhood of your header-to-cylinder head
junction. You will be told by all your friends that it is an exhaust leak
caused by using the cheap manifold gaskets which come as part of the entire
engine-overhaul gasket set, and you should have opted for high-quality $35
Fel-Pro header gaskets instead, and you will spend the next two days removing
and replacing a perfectly good exhaust gasket when all you had to do was
simply tighten the spark plugs!
Sigh.....
Hi guys,
inside.
had perhaps hoped.
the same.
first time.
Sigh.....
