Hello,
While I was driving, my car developed a strange noise in the engine compartment - it sounded as if something was very loose (lots of parts cranking or banging against each other) and as if the entire front end was about to fall apart. The car is now significantly slower and makes very loud cooling fan noise at the same time as if I am driving a tank.
There was no check engine light and the coolant temperature remained neutral.
If I remember correctly, this happened on the day when I first turned on the A/C.
Any help would be appreciated.
