I am trying to wire up my Angel Eyes to turn on when I turn on the ignition but can not find an ignition voltage when the key is ON for my relay. I can find PLENTY of 2,3,4, and 12v+ when the key is off. I can not find any that are 0v when off and any voltage + when on. I just need a turn on lead for my relay which will pull virtually no amperage. I am getting my power and ground elsewhere.
I will explain how I plan on doing so WITHOUT an error light on the dash once I figure out how to get my ignition voltage. I will do a full write up on this.....
Hey, Tim. I recently wired the 12v ignition wires for the relays in my Zionsville radiator/electric fan setup to the large gauge red wire in the stand alone plug on the far left side of the ECU. Tested it with a multimeter to ensure that it was switched 12v power. I know that's a bit far from the headlights!
__________________ The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Dinan 3.45 Differential, GC Coilovers (550 Front/325 Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Wheels (18 x 9 Front/18 x 9.5 Rear), Bridgestone RE050 RFTs (275 Front/285 Rear), UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauge, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, and Various Other Bits and Pieces
Coming Soon!
Stoptech "Trophy" Brakes, TC Designs Roll Bar, TC Designs Rear Sway Bar Brackets, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement and Dinan Foglight Deletion Kit.
That would work perfect, thanks, except I have NO CLUE where the ECU is . Forgive me, is it under the hood? Would you happen to have a picture of the location?
Current Performance Mods: Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan)
It's not that big of a deal really, we can do the programming anytime. This shouldn't be too bad of a deal really. Now that I know where I can get an ignition signal from, along with the Battery + and a ground, wiring will be a snap. I am picking up some wire, fuse holders, a few more relays, and fuses tomorrow. I also bought some loom to protect everything. I just need to go buy myself a new soldering iron, I seemed to have miss placed mine in my last move it seems.
