Old 27th April 2009, 15:31   #1
m5_chris
m5_chris's Avatar
Garage: Titanium Silver E39 M5
Wandering steering
Okay, next question
I've noticed that occasionally the car can seem quite light at the front and wander off to the side slightly as though its been hit by a gust of wind. This happens more if under acceleration or over an uneven road surface, on the motorway last night and at some roadworks I changed lanes and the car tramlined quite badly.
What I described above isn't noticeable when in Sport mode...
Any ideas chaps?
Chris
m5_chris is offline
Old 27th April 2009, 16:48   #2
chowdah
Garage: sweetness
Sales Feedback: (3)
Likely candidates: tires, sway brackets, and/or thrust arm bushings.
chowdah is offline
Old 27th April 2009, 17:27   #3
m5_chris
m5_chris's Avatar
Okay, tyres is an easy one to check.
Sway brackets - is this just a case of checking where the bars are attached to the body, to see if they are loose?
m5_chris is offline
Old 27th April 2009, 18:28   #4
chowdah
Garage: sweetness
Sales Feedback: (3)
Yes, in particular: ~1ft inside of each rear wheel. Pictures of these have been posted before.
chowdah is offline
Old 27th April 2009, 18:58   #5
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
I get LOTS of tramlining.. it's pretty overbearing sometimes. Most of mine is attributed to my shot tires (275's all the way around) which are badly scalloped on the inside edges. (the rears are definitely scalloped from worn ball joints, not sure about the front end) But new tires/suspension/bushings are coming this summer.
You should hear these tires though right around 20mph, they make a terrible racket from the scalloping. they sound like big aggressive offroad tires.
Lancefitzgiben is offline
Old 27th April 2009, 21:06   #6
Neil.D
Neil.D's Avatar
Garage: E39 M5 - Titanium Silver
When was the last time you get a 4 wheel lazer alignment. In my M3 my car would wander at quite high speed. After the 4WA it was totally gone.
2000 M5 Titanium silver
Neil.D is offline
Old 27th April 2009, 23:18   #7
exigtis4m5(?)
exigtis4m5(?)'s Avatar
Garage: LMB 2002 M5
Sales Feedback: (5)
i have had better luck with the stock tire preasure 44/48 v/s running lower. If your tires are good then try different tire pressures. Also, my tramlining did go up after getting 275s across all 4. However, it went down after getting an alignment.
exigtis4m5(?) is offline
Old 28th April 2009, 00:21   #8
Lancefitzgiben
when I went to 275's I didn't notice any extra tramlining (nothing like what I experienced in the old z3)
I can't wait to feel the transformed car with new tires/bushings/suspension installed.
Old 28th April 2009, 01:31   #9
jselig
Garage: 03 M5 Silver
Sales Feedback: (3)
This is not stock presures. Unless your running with 5 people and a trunk full of gear. Read your manual or door plate very carfully. This must ride very harsh with these settings not to mention you will go through your tires very fast. You should be at 35 psi front and 38 rear. I run 35 all around because the rears tend to wear out the centers at the higher psi. Also the higher rear psi is just a safety for BMW for less oversteer.
jselig is offline
Old 28th April 2009, 11:30   #10
m5_chris
m5_chris's Avatar
Thanks for the replies folks.
I've got 245 40 at the front and 275 35 at the rear. The rears have plenty of tread (at the moment ) but the fronts are getting a bit worn in my opinion.
First things first, new tyres and 4 wheel alignment... and whilst its on the ramp can take a look at the anti roll bars.
Cheers!
m5_chris is offline
The "wandering" side view mirror.... (and 1 other question) avi8tir E60 M5 and E61 M5 Touring Discussion 16 24th September 2009 07:26
Wandering problem? Close Encounter E39 M5 and E52 Z8 Discussion 4 16th September 2007 08:42
No fix yet for the wandering CD player Wolverine E60 M5 and E61 M5 Touring Discussion 1 6th January 2006 22:48
Paddle Shift: Steering Wheel or Steering Column Mount? DonGargon E60 M5 and E61 M5 Touring Discussion 17 23rd December 2005 06:08
Wandering steering/good mechanic Hocuspocus E34 M5 Discussion 11 1st September 2004 13:04
Page generated in 0.14635 seconds with 11 queries
