Old 27th April 2009, 05:45   #1
lemansblue00
Garage: 2000 M5 Lemans Blue
Battery dead/trunk won't open to charge it
I just went to unlock my 2000 M5, and the battery is dead. I want to charge the battery, but can't get in the trunk to access it. I tried using the key in the trunk, but it does help. Does anyone have any knowledge about this one. I sure would appreciate some help. I quickly did a search, but could not find an appropriate thread/comment.
Thanks,
Clay
lemansblue00 is offline
Old 27th April 2009, 05:47   #2
MfiveLeo
MfiveLeo's Avatar
Garage: 00 ///M5, Black
You can charge it from the engine bay. There is a positive terminal on the front driver side of your intake plenum. Also you can open the trunk with your key but it is kind of tricky from what I remember. I believe you must make the key turn all the way to the left, and the trunk will pop open.
Leo
00 M5
-iats relocation
-magnaflow x pipe and cans
-conforti shark
-uuc lightweight flywheel w/ v12 clutch
03 Cobra
-wider wheels
-lowered
-440 whp
MfiveLeo is offline
Old 27th April 2009, 05:59   #3
Suro
Suro's Avatar
Garage: 2003 Carbon Black M5
I freaked out a couple days ago because I had disconnected the battery and then accidentally shut the trunk. I was really relieved to be able to open the trunk with the key. It was a bit tricky and it took a couple tries.
Suro is online now
Old 27th April 2009, 06:02   #4
V8 empowered
Garage: 1996 E39 535i V8 Sport (black on black)
I had this happen to me because my trunk actuator solenoid died- put the key in the lock & twist it all the way to the left (hard anti-clockwise), past the point of resistance- the lid will pop open.
The trunk lock actually has a mechanical steel rod linkage from the lock barrel to the lock mechanism, in case of an electrical malfunction- so it will always open regardless of if the battery is dead. (It says this in your owners manual & I have actually seen the rod linkage myself)
1996 Black-on-black BMW ///M535i E39 (euro):
Owned for 1 year.
250,000km odometer, Baby M62 3.5L V8, Steptronic trans, NO VANOS, Nav, moonroof, rear fogs, tv-in-motion enabled, 17" BBS wheels, lowered suspension, shadowline side trim.
Replaced 90% of the car in either broken/worn out parts, or as preventative maintenance. But at least it drives great
"The E39 has an uncanny ability to sense when there's money in my wallet, & quickly drain it in random repair costs"
V8 empowered is offline
Old 27th April 2009, 06:21   #5
lemansblue00
Thanks, for the posts on the trunk opening with the key. I will disconnect the battery before charging. It is totally dead, but is one of those dry batteries(forget the name now) and is supposed to be good for bringing it up again with very little degradation. I took it out last weekend and drove it for a while, but let the back door ajar.
Clay
Old 28th April 2009, 03:46   #6
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
that sucks! hope you get it...
rneedham1979 is offline
Old 28th April 2009, 04:04   #7
midtwnman
Garage: 2000 M5 Silverstone Metallic
I had the same exact problem. It caught me completely off guard. What I did was I hooked up another car to the battery terminals up front and then hit the unlock button on my key fob. Basically, hook up your car to another as if you were going to jump start it so your car is using power coming from the other car's battery. Then just make sure you don't shut the trunk all the way until you have your new battery .
midtwnman is offline
Old 28th April 2009, 04:08   #8
Terabass
Terabass's Avatar
Garage: M5 Black
Push the car and jump start it by popping the clutch in 2nd gear, my battery just died but i live on a 16% incline hill so i had no problem getting moving.
Terabass is online now
Is there a way to open trunk whilst battery dead?? Up E39 M5 and E52 Z8 Discussion 6 5th September 2008 15:29
Maintaining battery charge dwasifar E39 M5 and E52 Z8 Discussion 32 3rd December 2007 22:50
Opening trunk with dead battery? djtroy E39 M5 and E52 Z8 Discussion 28 4th August 2006 20:58
Battery acid "odor" in trunk? Feedback on Optima battery? mottati E39 M5 and E52 Z8 Discussion 26 23rd March 2006 02:02
Battery not holding charge... Greco E39 M5 and E52 Z8 Discussion 25 23rd November 2004 02:23
Page generated in 0.12215 seconds with 11 queries
