Old 26th April 2009, 23:19   #1
ortontom
Garage: M3 blue E46 convert, E39 M5
An oil question
we are having a debate as my 2001 M5 e39 is starting to show signs of buring oil under hard acceleration, its done 89k miles and has never shown the dreaded blue smoke before.....friends now say the mobil one oil I put in it is to blame, I think its a max of 40w, I should have used 10-60w edge oil from castrol which replaces RS....
Has this ever happened to anyone? and are they correct? Should I change my oil to the edge oil to prevent blue smoke....
t
ortontom is offline
Old 27th April 2009, 01:22   #2
E55AMG2
E55AMG2's Avatar
Maybe you've developed an oil leak?
E55AMG2 is offline
Old 27th April 2009, 05:19   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Blue smoke is unrelated to Mobil1 vs TWS - I'd get myself a compression test pretty darn quick.
d-
DouglasABaker is offline
The Following User Says Thank You to DouglasABaker For This Useful Post:
stevie sam (27th April 2009)
Old 27th April 2009, 06:10   #4
V8 empowered
Garage: 1996 E39 535i V8 Sport (black on black)
I think minimum compression variation between cylinders is no more than 10% according to the BMW leakdown test procedure?
In any case, rule out the rings first by doing as Doug says.
1996 Black-on-black BMW ///M535i E39 (euro):
Owned for 1 year.
250,000km odometer, Baby M62 3.5L V8, Steptronic trans, NO VANOS, Nav, moonroof, rear fogs, tv-in-motion enabled, 17" BBS wheels, lowered suspension, shadowline side trim.
Replaced 90% of the car in either broken/worn out parts, or as preventative maintenance. But at least it drives great
"The E39 has an uncanny ability to sense when there's money in my wallet, & quickly drain it in random repair costs"
V8 empowered is offline
Old 27th April 2009, 15:38   #5
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Are you sure it's blue smoke? Mine smokes and use's a lot of oil if I drive her hard. My problem is a bit strange though, if I use the gears to slow down coming up to junction or roundabout then when I pull away I get a puff of smoke, if I don't use the gears then no smoke. My mechanic says it's something to do with the recirculation of the oil vapour into the air box via the oil seporators. BMW compression tested the engine and found no problem.
So if this sounds like your problem then don't get to worried. All M car smoke a bit even the new M3 does as I have seen a white one with black spec on the rear bumper.
I'll see you, if you catch me
andy777 is offline
Old 27th April 2009, 15:58   #6
DouglasABaker
Black = carbon = normal. Blue = unburned oil = bad. Oil consumption to some degree is normal, but oil out the tailpipe has always been, at least in my experience, an indicator of a problem.
jclyman (26th October 2009)
Old 27th April 2009, 18:39   #7
Bluerumble
Bluerumble's Avatar
Garage: 2003 M5 Carbon Black Metallic
Mr. Baker is spot on. How much are you burning? How much smoke are you seeing? In any case a compression leakdown is in order to properly diagnose oil burning. One thing to check first is to take the plenum cover off and see if there is an abundance of oil in the plenum, if so it may just be oil separator hoses or something simple. Always check the simplest things first. I doubt it is related to Mobil 1. I personally think people make a much bigger deal out of the oil choice thing, than needs to be made. I do however only run TWS in my beast.
2003 M5 Carbon Black Metallic, Black Napa Full Leather
Dinan Intake, MAFs, Exhaust, and software, E60 SSK,
K40 stealth radar detection front and rear
Speed is question of money, How fast do you want to go?
Bluerumble is offline
The Following User Says Thank You to Bluerumble For This Useful Post:
Old 27th April 2009, 20:42   #8
ortontom
thanks for the note - a cylinder leakdown test has been suggested by the guys that service the car, its burning - I only know because of a weekend blap with a V8 m3, c63 amg, 911 and a couple of boxsters.......i had to work it hard to get even close to the c63, what a car...
these same guys followed me to tuscany before - last year and it wasnt doing it then...
t
ortontom is offline
Old 27th April 2009, 20:43   #9
ortontom
whats the plenum?
ortontom is offline
Old 27th April 2009, 20:46   #10
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
Plenum? - - that would be that large black thing / cover over the entire intake //
...when you remove all those nuts holding it in place (without dropping any) you'll see these twisted horns in the plenum area. If this area is all full of oil, check the oil seperators - probably never changed. If just a light film of oil, well, this is normal over time...
what is the year/month build date for your car?
it needs TWS 10-60 if older than, what was it now, damn memory, uh, March 2000?
(don't worry, it's an oil thread, plenty to come with more answers than mine...)
oh, and my '99 burns a liter every 1000km, or 600ish miles - of course, I drive her like she's stolen (required)
- I love oil threads...
MarkQC is offline
Upgrading. SS question and Angel Eyes question, pls!? Finnishfan E39 M5 and E52 Z8 Discussion 2 7th October 2005 17:44
Page generated in 0.10720 seconds with 11 queries
