GUIBO $#@! - BMW M5 Forum and M6 Forums
post #1 of 13 Old 14th April 2009, 08:49 PM Thread Starter
UKNOWHO
UKNOWHO's Avatar
GUIBO $#@!
Fans of the awesome E39
last week I was given a diagnose that my BABY’s GUIBO was in need of replacement, I went to panic mode the whole GUIBO operation can lead to stress if your drive shaft was effected, but fortunately the technicians caught the inflamed GUIBO before any damage happened.
I had to take a long road trip over the weekend to SC in a rental (Pontiac Grand Prix). Made me appreciate my BABY even more, so I am glad to say that we shall be back together after work today and we can bond together as one, Man and Machine…
I would like to give props to the M5 board for their history that is easy to check on just about anything that is related to the E39/M5, and lastly to my surgeons of the S62 engine and its components (J & F Motors Arlington VA) it is guys like them that do great work for a fair price for guys like me…Thanksfficeffice" />
"we are what we repeatedly do. Excellence, therefore, is not an act but a habit." Aristotle
UKNOWHO is offline
post #2 of 13 Old 14th April 2009, 09:22 PM
arotished
arotished is offline
post #3 of 13 Old 14th April 2009, 09:36 PM
ps4570
ps4570's Avatar
Probably never happen to anyone else, but after I had the Guibo replaced, I developed a rattle. Sounded like a loose heat shield. Took three return visits to the dealer before the "M tech" figured out he put the resonator clamps on backwards. Just a heads up for others seeing this thread.
Probably time for me to find a good local indy in the Research Triangle area of NC.
Phil
ps4570 is offline
post #4 of 13 Old 14th April 2009, 09:57 PM
ps4570
ps4570's Avatar
Originally Posted by arotished View Post
GUIBO? The bushing inside the gearbox?
"A common wear item on BMWs over a period of time is the drivetrain guibo. The guibo serves as an interface between the transmission and the driveshaft. Since the guibo is primarily made from rubber, it acts as a damper when shifting and engaging into gears, so that the transfer of power to the driveshaft is smooth and dampened, instead of abrupt and harsh. Replacement of the guibo depends on age and driving style."
ps4570 is offline
The Following User Says Thank You to ps4570 For This Useful Post:
Favinha (15th April 2009)
post #5 of 13 Old 14th April 2009, 10:08 PM
arotished
Ahhh, thanks
post #6 of 13 Old 14th April 2009, 10:41 PM
gsfent
gsfent's Avatar
Ahhh, thanks
BMW calls it a flex disc.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
post #7 of 13 Old 15th April 2009, 12:08 AM
malexgcab
malexgcab's Avatar
malexgcab is offline
post #8 of 13 Old 15th April 2009, 12:53 AM
billyg
Originally Posted by malexgcab View Post
What are the tell tale "signs/sounds" of a worn guibo?
Just replaced mine a a few months ago. Sympton was a strong vibration felt on on the actual stick shift while car was in gear and moving, caused by a crack in guibo/flex disc which caused the drivetrain to vibrate.
My Mechanic put the car on the lift and the crack was clearly visible.
billyg is offline
post #9 of 13 Old 15th April 2009, 02:11 AM
EM5PWR
EM5PWR's Avatar
Just some moaning and heavy breathing is all..
EM5PWR is offline
post #10 of 13 Old 8th May 2009, 08:43 PM
Dove5
Dove5's Avatar
Phil,
I'm having the same "rattle" especially on accelerating on 1st and occasionally hard 2nd. Where is this resonator clamps? Would you let me know?
RealOEM.com BMW E39 M5 Exhaust system, rear
It maybe "guibo" as i noticed the rattle is not evident when driving under cold engine. Anyway, I would like to check this resonator clamps first.
Thanks,
Phil
Terry
00 M5 Apine White/Silverstone
Clear "Angel Eyes", Celi LED tail lights, Axxis Deluxe pads, SS Stop Tech brake lines, Strong Strut, BSW Stage1 Audio, ACS Pedals, 16:9 Nav, DINAN SSK, Straight pipe w/Timmay's etched tips, DICE BMW Ipod (Silverline Pro), BP rear sway bar brackets,
Dove5 is offline
what the heck is a guibo? Jeuprx-8 E39 M5 and E52 Z8 Discussion 5 19th March 2009 03:27 PM
guibo help!!!! stilov E39 M5 and E52 Z8 Discussion 1 29th September 2008 07:04 PM
Bad Guibo murph550 E39 M5 and E52 Z8 Discussion 2 30th March 2008 07:47 AM
Check your guibo! HDClown E39 M5 and E52 Z8 Discussion 11 4th May 2007 11:48 PM
Bad Guibo??? x703jko E39 M5 and E52 Z8 Discussion 11 13th April 2004 11:23 PM
