11th April 2009, 01:01
#1
2000 M5 Alpine White
ESS VT550/570 VS. CA RK550 Superchargers
Ok guys we need detailed feedback on this. Which one would you pick, and WHY???
CA: CA rk550 E39 M5 Supercharger Conversion
ESS Tuning - BMW Supercharger Kits
'00 BMW ///M5 Alpine White
Mods
Evolve stage 3 tune
Schrick cams
Hamann Headers (High temperature coated inside and out)
Custom made exhaust (cat delet)
KW Coilovers V3
WP Pro BBK (360 mm rotors, 8 pot calipers front, 6 pot calipers rear)
11th April 2009, 06:37
#2
Banned
I would go ESS. The CA product looks like crap to me. They use common metal, zip ties to hold the oil cooler in place and the a dryer hose router under the car to transfer boost. I just do not like the quality of the kit. The ESS kit looks top notch.
Buy one already!
Ryan
11th April 2009, 07:03
#3
Sold&missed - 2001 M5
I agree I think the ESS kit looks cleaner, closer to OEM appearance. What I also like about the ESS kit is that it seems to do more with less and for less - which tells me it is better put together.
2001 ///M5 - SOLD
Eisenmann Sport | Supersprint headers | SuperSprint X-pipe | Ground Control | Stoptech ST-40 front brakes | Powerchip | Rogue 280mm clutch | JB Racing lightweight flywheel | Rogue short shift | Dinan rear Swaybar | OEM 9.5" all around with Star Specs | Cosmo Racing CAI | Opened brake ducts
11th April 2009, 18:49
#4
Buy one already!
Ryan
You sure about this?
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore,
UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis
19" Hamann PG2īs, Strongstrut front Strut Brace, BMW fire extinguisher, Phatbox MP3 player, CF interior trim, Voltphreaks battery
http://www.cardomain.com/ride/2417213/1
1989 E30 M3 White - track toy
S50B32 with a supercharger - 500+ hp, 1300kg rocket for the Ring
11th April 2009, 23:44
#5
Banned
I am going off the picture. The metal bracket under the car is rusted so.. yes it is common metal, meaning not stainless, aluminum etc. And in every picture the oil cooler is hanging by zip ties and yes the long plastic hose that runs from the air filter to the blower is a horribly cheap idea. So... yes! I am sure about this. If you compare the two pictures you will see a vast difference in quality and design.. Good day!
Ryan
12th April 2009, 00:14
#6
Ryan
+1.
But it seems like the ESS SC has no extra oil cooler, no IC, and no CNC MACHINED MANIFOLD PLATES
12th April 2009, 01:59
#7
2003 Sterling Gray M5
Originally Posted by alquazi
+1.
Keep in mind also, that the ESS kit is ONLY running 5.5 psi. That's pretty low boost for a pretty good amount of return on the power.
Bri
2003 Sterling Grey M5
ESS kit #1 with RK AUTOWERKS Upgrade! (RK/EVO software, Injectors, Fuel Pump)
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Aquamist HFS3/Howerton Engineering Tank (pre/post SC nozzles)
RK Autowerks CNC Plenum Plates
12th April 2009, 03:11
#8
2000 m5 silverstone
Just got some stoptechs so I can brake sooner now Im ready for some FI
2013 Subaru wrx Cobb tuned Daily beater
2009 135 "Worlds First Frozen 1ER" ESS Tuned stage 2
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
12th April 2009, 09:47
#9
2008 E60 M5 SC White
Hi All
I see what you mean, by looking at the pictures and i guess its my fault! because i have never made any pictures of the final kit..
So whats on the pictures are what the test car had fitted during development! sorry about that...
All parts in the kit comes coated black.. and with black silicone!
We dont sell rusty plates  .. However its true that our SC bracket isnt made from 7075alu like all the other parts! And its not that we didnt want too use alu, but by calculating the amount of stress on the bracket i ment it wasnt safe.. see the small amount of stress on the metal bracket in the pic.
http://rumatuning.co.uk/publicdownloads/?file=2&sort=1
As for the oilcooler..  Sorry about that too... But at the time i was playing around with the amount of cooling needed, to keep the SC oil on a 80degree celcius level.. And because the SC sits down low, it gets alot of cooling from the air, so the oilcooler fitted is acctualy too big.. But by turning it around it will only flow in the top of the oilcooler and then the temp. were perfect... Plus with an extra bracket I can turn it around for max. cooling if a customer would need it.. so both options are there without any big changes...
http://rumatuning.co.uk/publicdownloads/?file=7&sort=1
When im back home again i will make some pictures of the out of the box kit, so you can see the coating..
Best regards and drive you M's safe..
Ruben
The Following 2 Users Say Thank You to Master Yoda For This Useful Post:
12th April 2009, 13:26
#10
+1.
You can purchase the plenum plates from CA separately. Pricey, but probably worth it.
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
