4th February 2002, 17:10
#2
You may want to check into you roof drain that is in the panel right next to where the roof panel meets the door panels. This can become clogged and cause a leak into the car. I read this on another 5 series board awhile back. Could be your problem. Let us know how you make out, good luck.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
