Old 5th April 2009, 17:04   #1
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
Strange Exhaust Sound - not CPS
Before I say anything else, I must point out that I have 4 almost brand new CPS and NO codes.....
So about 6 weeks or so ago, I was hammering home in a very heavy rainstorm. I came off the M25 onto the A3 and there was a huge pool of water at the bottom of the sliproad. I accelerated hard as I came out of the 'puddle' and spun up the RHS rear wheel. Next thing I know the exhaust note has changed, a bit like when the CPS goes bad. It stayed like it for about 4 miles then slowly but streadily cleardd itself and everything went back to normal. I checked with the Peake and got nothing. I put it down to the exhaust having been immersed in cold water for a bit, or one of the O2s or temp sensors getting an odd reading from having a bath.
I thought no more about it until Wednesday, when I had a special M5 'moment' at the local Polish/Eastern European car wash... The guys were very excited by the M and as I was paying one of them said it would be a 'great honour' if I would 'give it some gas please' as I left. Well how could I say no! The thing is that having just been sitting in pools of soapy water, the rear wheels spun up like they were on ice. Luckily it didn't slew sideways so the DSC didn't trigger, and the wheels just kept on spinning and the next thing I know there are 2 HUGE clouds of white tyre smoke behind me..... and then it gripped. Awesome. I couldn't possibly have planned a better exit if I'd tried! BUT..... having spun the wheels, this strange exhaust note returned. It stayed for a bit then slowly wore off again like last time. For the next 20 miles or so there was a distinct hesitation if accelerating from 3 or 4k rpm. I stopped, turned her off and on again and everything was totally fine and has been since. Again - no codes.
Anyone had anything similar?!
100%Cocoa is offline
Old 5th April 2009, 18:33   #2
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
...with the RPM comment, sounds like limp mode to me...
MarkQC is offline
Old 5th April 2009, 21:17   #3
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Both times it happened after the car was around large amounts of water. I am not a big believer in coincidence, so I would guess something is getting wet and the heat of driving a few miles dries it up.
Could be CPS on one side, perhaps a wire is getting wet and CPS works intermittantly until dry? Not all CPS malfunctions throw a CEL/SES. Did you check for codes with a Peake or equivalent?
gsfent is offline
Old 6th April 2009, 00:30   #4
slayer1974
slayer1974's Avatar
Garage: 2001 M5 in Metallic Carbon Black & 1992 E34 M5 in Avus Blue.
What is a CPS?
///M5
slayer1974 is offline
Old 6th April 2009, 07:49   #5
MarkQC
MarkQC's Avatar
Camshaft Position Sensor...
MarkQC is offline
The Following User Says Thank You to MarkQC For This Useful Post:
slayer1974 (6th April 2009)
Old 6th April 2009, 08:58   #6
KevN23
KevN23's Avatar
Garage: E39 M5
Sales Feedback: (3)
This has happened to me as well, same symptoms... I have not found the problem
KevN23 is offline
Old 6th April 2009, 16:16   #7
Carzzi
Carzzi's Avatar
Garage: M5 Anthracite/Caramel & M3 Arctic/Dove
I'd agree, it's the CPS. Before one of my CPS' died, I would get these exact intermittent gravelly exhaust moments with torque loss that would go away without throwing an SES light or any codes. Finally after a month, it threw its first SES. Man... there are four of these damn sensors on this car!
Carzzi
E39 M5 Anthracite/ Caramel, stock, SOLD
E36 M3 Arctic/ Dove, Supersprint/ Sharked, SOLD
190E 2.6 Sportline 5-sp, AMG Headers
Carzzi is offline
Old 6th April 2009, 19:04   #8
MarkQC
MarkQC's Avatar
I don't think a CPS symptom would go away just by switching the car off and restarting, I might be wrong, but this is what normally happens when the car goes into limp mode - at least this is the way I "cleared" the limp mode several times...
-BTW - I never found the cause, and haven't had it for more than a year now - knock on wood...
MarkQC is offline
Old 6th April 2009, 23:33   #9
100%Cocoa
100%Cocoa's Avatar
Cheers for the help all, but I must stress, as I did at the beginning of the thread, that I have NO CODES and all 4 NEW CPS! I guess a new one could go faulty, but I have had the Exhaust CPS go on me twice since I got this car over 4 years ago. I know the symptoms very well and the noise is not quite as deep or rich sounding and the car loses no power. I also always had codes before, even when it went bad for just 2 minutes when the fault first started. Another difference is this hesitation. That didn't happen with either of the 2 previous CPS failures.
I'm kind of with the water theory but I have had it washed a few times since and been in very very heavy rain since too.
The only truly common thing between the 2 incidents is the wheels spinning - I don't tend to do that very often.
Hmmmm......
Old 7th April 2009, 02:57   #10
nightkrawler
nightkrawler's Avatar
Garage: Lemans Blue M5
i've noticed something somewhat similar, and i also have 4 new cps. its a change in the exhaust tone, almost sounds like a slight exhaust leak or gurgleing exhaust tone. i cant explain it and it only happens intermittently.
nightkrawler is online now
Strange sound ccm241 E39 M5 and E52 Z8 Discussion 18 25th January 2008 01:59
strange buzzing sound? HELP! phillygoat E34 M5 Discussion 11 5th November 2007 20:58
Strange Sound vitaman E39 M5 and E52 Z8 Discussion 1 17th February 2004 02:34
Strange Clutch (?) Sound x703jko E39 M5 and E52 Z8 Discussion 9 22nd August 2003 19:40
Strange Ticking Sound - 540 *and* M5! Chris Foote E39 M5 and E52 Z8 Discussion 7 9th June 2001 18:38
Page generated in 0.13861 seconds with 11 queries
