AC not blowing cold. - BMW M5 Forum and M6 Forums
post #1 of 22 Old 1st April 2009, 04:18 AM Thread Starter
RUFM5
Shill account for CNS Racing
The AC temps came to a point where I needed a R134 fill up. It is now a few months later and I am back with AC temps not being as cold as usual. Does anyone know of any common components that may leak? Has anyone used any stop leaks that work?
Shark Injector RACE Version 93 (Tuned By Jim Conforti)
CNS Racing Power Clutch kit - Oversized 10.5 Inch Carbon Metallic disk w/ lightweight Dualmass flywheel(DINAN S3 Design w/ zero gearlash noise)
Supersprint Headers with JETHOT coating (Extreme Sterling)
CNS Racing Cat-Back Exhaust
OZ Racing Superleggera III Bright Silver Wheels 19x9-2.5"lip, 19x10-4"lip - three piece forged.
Evosport Under-Drive Audiophile Pulley Kit
Custom Magnaflow High Flow Metallic CATS (#59926)
Innovative LM1 Wideband Air/Fuel ratio kit
Powerflex Front Thrust Arm and Sway Bar bushings
Cool Ride Thermal Reflective Panel under Air Plenum
Stoptech/SportStop slotted rotors with Axxis Deluxe pads
Bavauto Teflon Stainless steel brake lines
MB Quart Reference RUA213 Component Speakers, 12inch Kicker Subwoofer, RF AMP and XM Radio
Peake R5/FCX(II), Compaq PDA PocketPC OBDII realtime OBDpro Serial Scantool
Euro Clear headlights, 8K Xenon, Predator Angel Eyes Rings, Clear bra, Lamin-x, Euro Smoked tail lights
UFM IATS Relocator
Pro BEL RX65 Radar Detector direct wired and BLINDER Laser Jammer.
AFE Pro Dry S Intake with custom RAM air ducts
UMNITZA sink drain brake cooling grill
Carbon Fiber rear diffuser, front kidney grill and front Hamann look lip spoiler
Hamann DTM rear spoiler
Solargard 5% Tints, Ultimate Cup Holder, Full LED interior lights and exterior blinkers, Clear Bra
CNS Racing 3.62 Differential, suspension and sway bar upgrade
Royal Purple Synchromax.
CNS Racing Oil Separators/10W60
UUC RK6A-L knob
Alutec Strut Bar
RUFM5 is offline
post #2 of 22 Old 1st April 2009, 05:14 PM
M5TX
M5TX's Avatar
In my previous 02' M5 I had the same problem. It turned out the schrader valves in the charging ports were leaking.
M5TX is offline
post #3 of 22 Old 1st April 2009, 05:20 PM
Silent
Silent's Avatar
I have the same issue in my 02. There is a leak somewhere... so every summer it cost me $45 for a refill.
Da Machine
02 Blue WM Sport, S/C'd mofo - 566rwhp/462trq on 91 octane
Da Rocket
08 M5 SMG Alpine White/Black & Titanium Trim w/all options <-- For Sale
Sold
11 Alpine White/Black F10 550i ///M Package M Sport
09 Alpine
White/Black E60 550i ///M Package M Sport
08 Alpine White/Black E60 550i ///M Package M Sport
06 LMB/Black 4.8is
03 Imola Red/Black 4.8is
Silent is offline
post #4 of 22 Old 1st April 2009, 06:33 PM
Stevewall968
Could be a hole in the heat exchanger rad or quite common is the rubber 'o' rings in the screw in connector joints perish with time and start to leak(Speaking here with experience of a leaking 911 system, but guess BMW AC system has very similar components.)
Steve
Stevewall968 is offline
post #5 of 22 Old 1st April 2009, 11:18 PM
chrisdaph
chrisdaph's Avatar
Air Con gas leak
There are two schrader valves on the air conditioning system, one on the low side and one on the high side. One usually has a blue cap and the other a red cap. They are usually found close together and close to the coolant reservoir(s) under the hood.
Here's an image of a blue one. Other than tightening these schrader valves, I would not recommend fiddling with them-leave it to an air conditioning expert.
The ports are a little more inaccessible, where the in (low) and out (high) pressure lines connect to the compressor, which itself is usually well down in the engine bay, just like the alternator.
The low pressure line runs from the evaporator behind the instrument panel in the car to the condenser at the front of the car, near the radiator, back to the compressor, where the pressure is increased and the gas enters the high pressure line, back to the evaporator.
Hope this helps.
Chrisdaph:
2001 740iA Sport-still have-wife won't let me drive it!
1989 E34 M5-summer driver
1991 ALPINA E32 B12 5.0 -summer driver as well
2010 Sequoia-winter driver
chrisdaph is offline
The Following User Says Thank You to chrisdaph For This Useful Post:
chowdah (3rd April 2009)
post #6 of 22 Old 2nd April 2009, 01:45 PM Thread Starter
RUFM5
I checked the PSI and it is about 35. I noticed that the AC temps are fine if I use the air recirculation button but when recirc is disabled(air enters from cabin filters) the AC temps increase and the air flow from the vents decrease. Any ideas? Also what is the function of the AC button with an "a" and circle around it...I assume it is automatic air recirculation but is there a sensor to detect pollution?
UFM IATS Relocator
UUC RK6A-L knob
Alutec Strut Bar
RUFM5 is offline
post #7 of 22 Old 2nd April 2009, 05:56 PM
Eric Giles
Eric Giles's Avatar
When was the last time that you replaced the microfilters? If they are very dirty, they will definitely affect a/c operation.
Eric Giles
'88 M3 Diamantschwarz/Black
'00 M5 Lemans Blue/Black
'87 325is Delphin/Black
Eric Giles is offline
post #8 of 22 Old 3rd April 2009, 10:10 PM
bimmernut1
bimmernut1's Avatar
Do you notice whether the a/c temp rises when the car comes to a stop at a red light then cools off again when you accelerate? (Not in recirc mode)
2003 Titanium Silver BMW M5
1996 Guards Red Porsche 993 C4S
1979 Tobacco Metallic 911SC
2013 Carbon Black BMW X3 35i M sport
2005 Seal Gray Porsche TurboS
bimmernut1 is offline
post #9 of 22 Old 4th April 2009, 12:06 AM
DouglasABaker
DouglasABaker's Avatar
Automatic re-circ has nothing to do with pollution - it is a simple timed cycle to prevent a buildup of humidity. Your other choices are manual re-circ or off. An increase in air temp with re-circ off is completely normal since the incoming air is warmer.
As for diagnosis, your best bet is to go to a shop that can inject a dye into the system and then use a blacklight to determine the leak point. Anything other than that is pure guessing as R-134 will dissipate faster than you can detect it.
d-
DouglasABaker is offline
post #10 of 22 Old 4th April 2009, 01:01 AM
kindanutz
kindanutz's Avatar
d-
actually there is a sensor that detects some sort of pollutants in the exterior air entering the vehicle... i was reading it in the owners manual not even 2 hours ago...
the "A" with the circle means that air will be pulled from the exterior of the car until undesired pollutants are detected in the exterior air, then the flaps will close and air will be recirculated until those pollutants are no longer detected... at which point air will be pulled from the exterior of the vehicle again....
the circle without the "A" means air will be continuously recirculated within the cabin no matter what...
kindanutz is offline
Cold - cold - cold start in the mighty ASR M5 M5 Junky E60 M5 and E61 M5 Touring Discussion 24 8th December 2008 08:02 PM
Cold - cold - cold start in the mighty ASR M5 M5 Junky Owners Gallery 4 2nd December 2008 11:04 PM
A/C sys not blowing hot enough? beegeezy E39 M5 and E52 Z8 Discussion 12 15th February 2008 06:56 AM
Blowing a Fuse felip E39 M5 and E52 Z8 Discussion 15 2nd October 2007 04:13 PM
M5 Blowing Oil..... ?? Bagger E39 M5 and E52 Z8 Discussion 7 30th July 2004 01:57 AM
