Thank you for taking the time to read my problems. I have an 01 with 47K. I have had the car put away for the winter and wanted to get an oil change and new plugs.
Before I put the car away I had SES light. I pulled the code and saw a misfire at start up. I wasn't worried cuz the car was running good.
I stopped by mi Indie today to see what was going on and I have the following:
code 72 "Exhaust VANOS BANK 2" (33 times)
"CPS Exhaust BANK 1" (222 times)
"Camshaft BANK 1 synchronized to crank shaft" (209 times)
"E8 tank ventilation" (2 times)
I spent the last few hours reading through some very technical posts. It seems that the first step is replacing the CPS Exhaust BANK 1 Is there and DIY instructions? (I looked be couldn't find)
Could the CPS cause the "Camshaft synchronized to crank shaft" fault??
If not, what do I have to replace to fix that problem??
I also saw a few comments that the CPS could also throw the Exhaust VANOS BANK 2 code..is that possible?
"The E8 code" do I have to replace the carbon canister? Can this repair wait until I have more funds available?
thank you for your help, I want to have as much info as possible when I talk to my mechanic tomorrow.
I need a drink
